Staging: vme: bridges: Add missing unlocks
Add a spin_unlock and mutex_unlock missing on the error path.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* spin_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* spin_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Martyn Welch
 drivers/staging/vme/bridges/vme_ca91cx42.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/vme/bridges/vme_ca91cx42.c b/drivers/staging/vme/bridges/vme_ca91cx42.c
index 0f9ea58..16cf53e 100644
--- a/drivers/staging/vme/bridges/vme_ca91cx42.c
+++ b/drivers/staging/vme/bridges/vme_ca91cx42.c
@@ -900,7 +900,8 @@ unsigned int ca91cx42_master_rmw(struct vme_master_resource *image,
 	/* Address must be 4-byte aligned */
 	if (pci_addr & 0x3) {
 		dev_err(dev, "RMW Address not 4-byte aligned\n");
-		return -EINVAL;
+		result = -EINVAL;
+		goto out;
 	/* Ensure RMW Disabled whilst configuring */
@@ -921,6 +922,7 @@ unsigned int ca91cx42_master_rmw(struct vme_master_resource *image,
 	/* Disable RMW */
 	iowrite32(0, bridge->base + SCYC_CTL);
+out:
 	spin_unlock(&(image->lock));
 	mutex_unlock(&(bridge->vme_rmw));
BtrLinux
Privacy Overview
