staging: Use GFP_ATOMIC when a lock is held
In each case, the containing function is only called from one place, where
a spin lock is held.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock
    when any
  GFP_KERNEL@p
 ... when any
@locked@
identifier gfp.fn;
spin_lock(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
Signed-off-by: Julia Lawall
Cc: Jonathan Cameron
Cc: Marek Lindner
Cc: Martyn Welch
 drivers/staging/iio/ring_sw.c              | 2 +-
 drivers/staging/vme/bridges/vme_ca91cx42.c | 2 +-
 drivers/staging/vme/bridges/vme_tsi148.c   | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/iio/ring_sw.c b/drivers/staging/iio/ring_sw.c
index 1f14cd4..294272d 100644
--- a/drivers/staging/iio/ring_sw.c
+++ b/drivers/staging/iio/ring_sw.c
@@ -20,7 +20,7 @@ static inline int __iio_allocate_sw_ring_buffer(struct iio_sw_ring_buffer *ring,
 	if ((length == 0) || (bytes_per_datum == 0))
 		return -EINVAL;
 	__iio_update_ring_buffer(&ring->buf, bytes_per_datum, length);
-	ring->data = kmalloc(length*ring->buf.bpd, GFP_KERNEL);
+	ring->data = kmalloc(length*ring->buf.bpd, GFP_ATOMIC);
 	ring->read_p = NULL;
 	ring->write_p = NULL;
 	ring->last_written_p = NULL;
diff --git a/drivers/staging/vme/bridges/vme_ca91cx42.c b/drivers/staging/vme/bridges/vme_ca91cx42.c
index 0c82eb4..0f9ea58 100644
--- a/drivers/staging/vme/bridges/vme_ca91cx42.c
+++ b/drivers/staging/vme/bridges/vme_ca91cx42.c
@@ -523,7 +523,7 @@ static int ca91cx42_alloc_resource(struct vme_master_resource *image,
 	if (image->bus_resource.name == NULL) {
-		image->bus_resource.name = kmalloc(VMENAMSIZ+3, GFP_KERNEL);
+		image->bus_resource.name = kmalloc(VMENAMSIZ+3, GFP_ATOMIC);
 			dev_err(ca91cx42_bridge->parent, "Unable to allocate "
 				"memory for resource name\n");
diff --git a/drivers/staging/vme/bridges/vme_tsi148.c b/drivers/staging/vme/bridges/vme_tsi148.c
index abe88a3..f09cac1 100644
--- a/drivers/staging/vme/bridges/vme_tsi148.c
+++ b/drivers/staging/vme/bridges/vme_tsi148.c
@@ -828,7 +828,7 @@ static int tsi148_alloc_resource(struct vme_master_resource *image,
 		return 0;
 			dev_err(tsi148_bridge->parent, "Unable to allocate "
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
