staging: Use available error codes
An error code is stored in a variable, but 0 is returned instead.  Use the
variable instead of 0.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
local idexpression x;
constant C;
if (...) { ...
  x = -C
  ... when != x
  return <+...x...+>;
  return NULL;
  return;
* return ...;
Signed-off-by: Julia Lawall
 drivers/staging/lirc/lirc_sasem.c | 2 +-
 drivers/staging/vt6655/iwctl.c    | 2 +-
 drivers/staging/vt6656/iwctl.c    | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lirc/lirc_sasem.c b/drivers/staging/lirc/lirc_sasem.c
index 73166c3..856487e 100644
--- a/drivers/staging/lirc/lirc_sasem.c
+++ b/drivers/staging/lirc/lirc_sasem.c
@@ -512,7 +512,7 @@ exit:
 	mutex_unlock(&context->ctx_lock);
 	mutex_unlock(&disconnect_lock);
-	return 0;
+	return retval;
diff --git a/drivers/staging/vt6655/iwctl.c b/drivers/staging/vt6655/iwctl.c
index 4322761..4009c0b 100644
--- a/drivers/staging/vt6655/iwctl.c
+++ b/drivers/staging/vt6655/iwctl.c
@@ -1900,7 +1900,7 @@ int iwctl_siwgenie(struct net_device *dev,
 	out://not completely ...not necessary in wpa_supplicant 0.5.8
-	return 0;
+	return ret;
 int iwctl_giwgenie(struct net_device *dev,
diff --git a/drivers/staging/vt6656/iwctl.c b/drivers/staging/vt6656/iwctl.c
index 9c855f0..0004be8 100644
--- a/drivers/staging/vt6656/iwctl.c
+++ b/drivers/staging/vt6656/iwctl.c
@@ -1719,7 +1719,7 @@ int iwctl_siwgenie(struct net_device *dev,
-	return 0;
+	return ret;
BtrLinux
Privacy Overview
