staging: unisys: use schedule_timeout_interruptible()
Author: Nicholas Mc Guire <hofrat@osadl.org>
API consolidation with coccinelle found:
./drivers/staging/unisys/visorbus/periodic_work.c:196:3-19:
consolidation with schedule_timeout_*() recommended
This is a 1:1 conversion with respect to schedule_timeout() to the
schedule_timeout_interruptible() helper only - so only an API
consolidation to improve readability. The hard coded timeout of 10
jiffies is HZ dependent which it should not be, so it is converted
with msecs_to_jiffies.
Patch was compile tested with x86_64_defconfig + CONFIG_STAGING=y,
CONFIG_UNISYSSPAR=y, CONFIG_UNISYS_VISORBUS=m
Patch is against 4.1-rc5 (localversion-next is -next-20150529)
Signed-off-by: Nicholas Mc Guire
Signed-off-by: Benjamin Romer
drivers/staging/unisys/visorbus/periodic_work.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/unisys/visorbus/periodic_work.c b/drivers/staging/unisys/visorbus/periodic_work.c
index 3562e8b..5e56088 100644
--- a/drivers/staging/unisys/visorbus/periodic_work.c
+++ b/drivers/staging/unisys/visorbus/periodic_work.c
@@ -192,8 +192,7 @@ bool visor_periodic_work_stop(struct periodic_work *pw)
if (pw->is_scheduled) {
write_unlock(&pw->lock);
- __set_current_state(TASK_INTERRUPTIBLE);
- schedule_timeout(10);
+ schedule_timeout_interruptible(msecs_to_jiffies(10));
write_lock(&pw->lock);
} else {
pw->want_to_stop = false; |
} else {
