staging: unisys: Remove unnecessary OOM message
Author: Quentin Lambert <lambert.quentin@gmail.com>
This patch reduces the kernel size by removing error messages that duplicate
the normal OOM message.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
identifier f,print,l;
expression e;
constant char[] c;
e = \(kzalloc\|kmalloc\|devm_kzalloc\|devm_kmalloc\)(...);
if (e == NULL) {
-  print(...,c,...);
  ... when any
  goto l;
  return ...;
Signed-off-by: Quentin Lambert
 drivers/staging/unisys/uislib/uislib.c              |  2 --
 drivers/staging/unisys/virthba/virthba.c            | 21 ++++++---------------
 drivers/staging/unisys/virtpci/virtpci.c            |  1 -
 .../unisys/visorchannel/visorchannel_funcs.c        |  1 -
 drivers/staging/unisys/visorchipset/parser.c        |  2 --
 .../staging/unisys/visorchipset/visorchipset_main.c |  4 ----
 drivers/staging/unisys/visorutil/memregion_direct.c |  4 +---
 drivers/staging/unisys/visorutil/procobjecttree.c   | 21 +++++----------------
 8 files changed, 12 insertions(+), 44 deletions(-)
diff --git a/drivers/staging/unisys/uislib/uislib.c b/drivers/staging/unisys/uislib/uislib.c
index a9eedde..77bf247 100644
--- a/drivers/staging/unisys/uislib/uislib.c
+++ b/drivers/staging/unisys/uislib/uislib.c
@@ -172,7 +172,6 @@ create_bus(struct controlvm_message *msg, char *buf)
 	    (dev_count * sizeof(struct device_info *));
 	bus = kzalloc(size, GFP_ATOMIC);
 	if (!bus) {
-		LOGERR("CONTROLVM_BUS_CREATE Failed: kmalloc for bus failed.\n");
 		POSTCODE_LINUX_3(BUS_CREATE_FAILURE_PC, bus_no,
 				 POSTCODE_SEVERITY_ERR);
 		return CONTROLVM_RESP_ERROR_KMALLOC_FAILED;
@@ -357,7 +356,6 @@ static int create_device(struct controlvm_message *msg, char *buf)
 	dev = kzalloc(sizeof(*dev), GFP_ATOMIC);
 	if (!dev) {
-		LOGERR("CONTROLVM_DEVICE_CREATE Failed: kmalloc for dev failed.\n");
 		POSTCODE_LINUX_4(DEVICE_CREATE_FAILURE_PC, dev_no, bus_no,
diff --git a/drivers/staging/unisys/virthba/virthba.c b/drivers/staging/unisys/virthba/virthba.c
index e6ecea5..e7af285 100644
--- a/drivers/staging/unisys/virthba/virthba.c
+++ b/drivers/staging/unisys/virthba/virthba.c
@@ -695,10 +695,8 @@ forward_vdiskmgmt_command(enum vdisk_mgmt_types vdiskcmdtype,
 	cmdrsp = kzalloc(SIZEOF_CMDRSP, GFP_ATOMIC);
-	if (cmdrsp == NULL) {
-		LOGERR("kmalloc of cmdrsp failed.\n");
-		return FAILED;	/* reject */
+	if (cmdrsp == NULL)
+		return FAILED;  /* reject */
 	init_waitqueue_head(&notifyevent);
@@ -758,10 +756,8 @@ forward_taskmgmt_command(enum task_mgmt_types tasktype,
@@ -929,10 +925,8 @@ virthba_queue_command_lck(struct scsi_cmnd *scsicmd,
 		return 1;	/* reject the command */
 	/* now saving everything we need from scsi_cmd into cmdrsp
 	 * before we queue cmdrsp set type to command - as opposed to
@@ -1064,10 +1058,8 @@ virthba_slave_alloc(struct scsi_device *scsidev)
 			return 0;
 	tmpvdisk = kzalloc(sizeof(*tmpvdisk), GFP_ATOMIC);
-	if (!tmpvdisk) {	/* error allocating */
-		LOGERR("Could not allocate memory for disk\n");
+	if (!tmpvdisk)
 		return 0;
 	tmpvdisk->channel = scsidev->channel;
 	tmpvdisk->id = scsidev->id;
@@ -1342,7 +1334,6 @@ process_incoming_rsps(void *v)
 	/* alloc once and reuse */
 	cmdrsp = kmalloc(SZ, GFP_ATOMIC);
-		LOGERR("process_incoming_rsps ****FAILED to malloc - thread exiting\n");
 		complete_and_exit(&dc->threadinfo.has_stopped, 0);
 		return 0;
diff --git a/drivers/staging/unisys/virtpci/virtpci.c b/drivers/staging/unisys/virtpci/virtpci.c
index 8fdfd6f..edaf43f 100644
--- a/drivers/staging/unisys/virtpci/virtpci.c
+++ b/drivers/staging/unisys/virtpci/virtpci.c
@@ -931,7 +931,6 @@ static int virtpci_device_add(struct device *parentbus, int devtype,
 	/* add a Virtual Device */
 	virtpcidev = kzalloc(sizeof(*virtpcidev), GFP_ATOMIC);
 	if (virtpcidev == NULL) {
-		LOGERR("can't add device - malloc FALLED\n");
 		POSTCODE_LINUX_2(MALLOC_FAILURE_PC, POSTCODE_SEVERITY_ERR);
 		return 0;
diff --git a/drivers/staging/unisys/visorchannel/visorchannel_funcs.c b/drivers/staging/unisys/visorchannel/visorchannel_funcs.c
index 4d11b51..01b0b20 100644
--- a/drivers/staging/unisys/visorchannel/visorchannel_funcs.c
+++ b/drivers/staging/unisys/visorchannel/visorchannel_funcs.c
@@ -59,7 +59,6 @@ visorchannel_create_guts(HOSTADDRESS physaddr, ulong channel_bytes,
 	p = kmalloc(sizeof(*p), GFP_KERNEL|__GFP_NORETRY);
 	if (p == NULL) {
-		ERRDRV("allocation failed: (status=0)\n");
 		rc = NULL;
 		goto cleanup;
diff --git a/drivers/staging/unisys/visorchipset/parser.c b/drivers/staging/unisys/visorchipset/parser.c
index 9edbd3b..686fe64 100644
--- a/drivers/staging/unisys/visorchipset/parser.c
+++ b/drivers/staging/unisys/visorchipset/parser.c
@@ -69,8 +69,6 @@ parser_init_guts(u64 addr, u32 bytes, BOOL isLocal,
 	ctx = kzalloc(allocbytes, GFP_KERNEL|__GFP_NORETRY);
 	if (ctx == NULL) {
-		ERRDRV("%s (%s:%d) - failed to allocate %d bytes",
-		       __func__, __FILE__, __LINE__, allocbytes);
 		if (tryAgain)
 			*tryAgain = TRUE;
 		rc = NULL;
diff --git a/drivers/staging/unisys/visorchipset/visorchipset_main.c b/drivers/staging/unisys/visorchipset/visorchipset_main.c
index cad036c..4b5def8 100644
--- a/drivers/staging/unisys/visorchipset/visorchipset_main.c
+++ b/drivers/staging/unisys/visorchipset/visorchipset_main.c
@@ -1113,8 +1113,6 @@ bus_create(struct controlvm_message *inmsg)
 	pBusInfo = kzalloc(sizeof(struct visorchipset_bus_info), GFP_KERNEL);
 	if (pBusInfo == NULL) {
-		LOGERR("CONTROLVM_BUS_CREATE Failed: bus %lu kzalloc failed",
-		       busNo);
 		POSTCODE_LINUX_3(BUS_CREATE_FAILURE_PC, busNo,
 		rc = -CONTROLVM_RESP_ERROR_KMALLOC_FAILED;
@@ -1263,8 +1261,6 @@ my_device_create(struct controlvm_message *inmsg)
 	pDevInfo = kzalloc(sizeof(struct visorchipset_device_info), GFP_KERNEL);
 	if (pDevInfo == NULL) {
-		LOGERR("CONTROLVM_DEVICE_CREATE Failed: busNo=%lu, devNo=%lu kmaloc failed",
-		     busNo, devNo);
 		POSTCODE_LINUX_4(DEVICE_CREATE_FAILURE_PC, devNo, busNo,
diff --git a/drivers/staging/unisys/visorutil/memregion_direct.c b/drivers/staging/unisys/visorutil/memregion_direct.c
index f4ecac0..aa52a6f 100644
--- a/drivers/staging/unisys/visorutil/memregion_direct.c
+++ b/drivers/staging/unisys/visorutil/memregion_direct.c
@@ -86,10 +86,8 @@ visor_memregion_create_overlapped(struct memregion *parent, ulong offset,
 		return NULL;
 	memregion = kzalloc(sizeof(*memregion), GFP_KERNEL|__GFP_NORETRY);
-	if (memregion == NULL) {
-		ERRDRV("%s allocation failed", __func__);
+	if (memregion == NULL)
 		return NULL;
 	memregion->physaddr = parent->physaddr + offset;
 	memregion->nbytes = nbytes;
diff --git a/drivers/staging/unisys/visorutil/procobjecttree.c b/drivers/staging/unisys/visorutil/procobjecttree.c
index 82279ca..0672e8c 100644
--- a/drivers/staging/unisys/visorutil/procobjecttree.c
+++ b/drivers/staging/unisys/visorutil/procobjecttree.c
@@ -146,10 +146,8 @@ MYPROCTYPE *visor_proc_CreateType(struct proc_dir_entry *procDirRoot,
 		goto Away;
 	type = kzalloc(sizeof(MYPROCTYPE), GFP_KERNEL | __GFP_NORETRY);
-	if (type == NULL) {
-		ERRDRV("out of memory\n");
+	if (type == NULL)
 		goto Away;
 	type->name = name;
 	type->propertyNames = propertyNames;
 	type->nProperties = 0;
@@ -164,10 +162,8 @@ MYPROCTYPE *visor_proc_CreateType(struct proc_dir_entry *procDirRoot,
 	type->procDirs = kzalloc((type->nNames + 1) *
 				 sizeof(struct proc_dir_entry *),
-	if (type->procDirs == NULL) {
+	if (type->procDirs == NULL)
 		goto Away;
 	parent = procDirRoot;
 	for (i = 0; i < type->nNames; i++) {
 		type->procDirs[i] = createProcDir(type->name[i], parent);
@@ -231,10 +227,8 @@ MYPROCOBJECT *visor_proc_CreateObject(MYPROCTYPE *type,
 		goto Away;
 	obj = kzalloc(sizeof(MYPROCOBJECT), GFP_KERNEL | __GFP_NORETRY);
-	if (obj == NULL) {
+	if (obj == NULL)
 		goto Away;
 	obj->type = type;
 	obj->context = context;
 	if (name == NULL) {
@@ -245,7 +239,6 @@ MYPROCOBJECT *visor_proc_CreateObject(MYPROCTYPE *type,
 		obj->name = kmalloc(obj->namesize, GFP_KERNEL | __GFP_NORETRY);
 		if (obj->name == NULL) {
 			obj->namesize = 0;
 			goto Away;
 		strcpy(obj->name, name);
@@ -257,17 +250,13 @@ MYPROCOBJECT *visor_proc_CreateObject(MYPROCTYPE *type,
 		kzalloc((type->nProperties + 1) *
 			sizeof(struct proc_dir_entry_context),
-	if (obj->procDirPropertyContexts == NULL) {
+	if (obj->procDirPropertyContexts == NULL)
 		goto Away;
 	obj->procDirProperties = kzalloc((type->nProperties + 1) *
-	if (obj->procDirProperties == NULL) {
+	if (obj->procDirProperties == NULL)
 		goto Away;
 	for (i = 0; i < type->nProperties; i++) {
 		obj->procDirPropertyContexts[i].procObject = obj;
 		obj->procDirPropertyContexts[i].propertyIndex = i;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
