staging: unisys: kmalloc/memset to kzalloc conversation
Author: Silvio F <silvio.fricke@gmail.com>
This patch solves the Coccinelle warning: "kzalloc should be used
instead of kmalloc/memset"
This patch is a fixup for
	linux-next: 97a84f1203786985856a0d4b49b1d7cc387238ce
	"Staging: unisys: Replace kmalloc/memset with kzalloc"
The ALLOC_CMDRSP #define is after transformation to kzalloc only a
rename for kzalloc and was completly removed.
Signed-off-by: Silvio F
 drivers/staging/unisys/include/uisutils.h           | 7 -------
 drivers/staging/unisys/virthba/virthba.c            | 9 ++++-----
 drivers/staging/unisys/virtpci/virtpci.c            | 3 +--
 drivers/staging/unisys/visorutil/memregion_direct.c | 5 ++---
 drivers/staging/unisys/visorutil/periodic_work.c    | 5 ++---
 5 files changed, 9 insertions(+), 20 deletions(-)
diff --git a/drivers/staging/unisys/include/uisutils.h b/drivers/staging/unisys/include/uisutils.h
index 81b5d9b..effd893 100644
--- a/drivers/staging/unisys/include/uisutils.h
+++ b/drivers/staging/unisys/include/uisutils.h
@@ -189,13 +189,6 @@ struct chaninfo {
 	schedule_timeout((x)*HZ); \
-#define ALLOC_CMDRSP(cmdrsp) { \
-	cmdrsp = kmalloc(SIZEOF_CMDRSP, GFP_ATOMIC); \
-	if (cmdrsp != NULL) { \
-		memset(cmdrsp, 0, SIZEOF_CMDRSP); \
 /* This is a hack until we fix IOVM to initialize the channel header
  * correctly at DEVICE_CREATE time, INSTEAD OF waiting until
  * DEVICE_CONFIGURE time.
diff --git a/drivers/staging/unisys/virthba/virthba.c b/drivers/staging/unisys/virthba/virthba.c
index 8aefaa8..817b11d 100644
--- a/drivers/staging/unisys/virthba/virthba.c
+++ b/drivers/staging/unisys/virthba/virthba.c
@@ -402,9 +402,8 @@ process_disk_notify(struct Scsi_Host *shost, struct uiscmdrsp *cmdrsp)
 	struct diskaddremove *dar;
 	unsigned long flags;
-	dar = kmalloc(sizeof(struct diskaddremove), GFP_ATOMIC);
+	dar = kzalloc(sizeof(struct diskaddremove), GFP_ATOMIC);
 	if (dar) {
-		memset(dar, 0, sizeof(struct diskaddremove));
 		dar->add = cmdrsp->disknotify.add;
 		dar->shost = shost;
 		dar->channel = cmdrsp->disknotify.channel;
@@ -697,7 +696,7 @@ forward_vdiskmgmt_command(VDISK_MGMT_TYPES vdiskcmdtype,
 		return FAILED;
-	ALLOC_CMDRSP(cmdrsp);
+	cmdrsp = kzalloc(SIZEOF_CMDRSP, GFP_ATOMIC);
 	if (cmdrsp == NULL) {
 		LOGERR("kmalloc of cmdrsp failed.\n");
 		return FAILED;	/* reject */
@@ -759,7 +758,7 @@ forward_taskmgmt_command(TASK_MGMT_TYPES tasktype, struct scsi_device *scsidev)
 		return FAILED;
@@ -930,7 +929,7 @@ virthba_queue_command_lck(struct scsi_cmnd *scsicmd,
 		return SCSI_MLQUEUE_DEVICE_BUSY;
 		return 1;	/* reject the command */
diff --git a/drivers/staging/unisys/virtpci/virtpci.c b/drivers/staging/unisys/virtpci/virtpci.c
index 1b64632..8e34650 100644
--- a/drivers/staging/unisys/virtpci/virtpci.c
+++ b/drivers/staging/unisys/virtpci/virtpci.c
@@ -254,13 +254,12 @@ static int add_vbus(struct add_vbus_guestpart *addparams)
 	int ret;
 	struct device *vbus;
-	vbus = kmalloc(sizeof(struct device), GFP_ATOMIC);
+	vbus = kzalloc(sizeof(struct device), GFP_ATOMIC);
 	POSTCODE_LINUX_2(VPCI_CREATE_ENTRY_PC, POSTCODE_SEVERITY_INFO);
 	if (!vbus)
 		return 0;
-	memset(vbus, 0, sizeof(struct device));
 	dev_set_name(vbus, "vbus%d", addparams->busNo);
 	vbus->release = virtpci_bus_release;
 	vbus->parent = &virtpci_rootbus_device;	/* root bus is parent */
diff --git a/drivers/staging/unisys/visorutil/memregion_direct.c b/drivers/staging/unisys/visorutil/memregion_direct.c
index 82c651d..b9b61e8 100644
--- a/drivers/staging/unisys/visorutil/memregion_direct.c
+++ b/drivers/staging/unisys/visorutil/memregion_direct.c
@@ -41,13 +41,12 @@ MEMREGION *
 visor_memregion_create(HOSTADDRESS physaddr, ulong nbytes)
 	MEMREGION *rc = NULL;
-	MEMREGION *memregion = kmalloc(sizeof(MEMREGION),
-				       GFP_KERNEL|__GFP_NORETRY);
+	MEMREGION *memregion = kzalloc(sizeof(MEMREGION),
+				       GFP_KERNEL | __GFP_NORETRY);
 	if (memregion == NULL) {
 		ERRDRV("visor_memregion_create allocation failed");
 		return NULL;
-	memset(memregion, 0, sizeof(MEMREGION));
 	memregion->physaddr = physaddr;
 	memregion->nbytes = nbytes;
 	memregion->overlapped = FALSE;
diff --git a/drivers/staging/unisys/visorutil/periodic_work.c b/drivers/staging/unisys/visorutil/periodic_work.c
index cc1c678..fb1e894 100644
--- a/drivers/staging/unisys/visorutil/periodic_work.c
+++ b/drivers/staging/unisys/visorutil/periodic_work.c
@@ -56,13 +56,12 @@ PERIODIC_WORK *visor_periodic_work_create(ulong jiffy_interval,
 					  void *workfuncarg,
 					  const char *devnam)
-	PERIODIC_WORK *periodic_work = kmalloc(sizeof(PERIODIC_WORK),
+	PERIODIC_WORK *periodic_work = kzalloc(sizeof(PERIODIC_WORK),
 	if (periodic_work == NULL) {
 		ERRDRV("periodic_work allocation failed ");
 		return NULL;
-	memset(periodic_work, '\0', sizeof(PERIODIC_WORK));
 	rwlock_init(&periodic_work->lock);
 	periodic_work->jiffy_interval = jiffy_interval;
 	periodic_work->workqueue = workqueue;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
