Staging: speakup: Remove unused variable
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch removes variable that was used to store only the return value of a function call.
The issue was detected and resolved using the following coccinelle script:
expression ret;
identifier f;
 -ret =
 +return
    f(...);
 -return ret;
Signed-off-by: Haneen Mohammed
 drivers/staging/speakup/kobjects.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/speakup/kobjects.c b/drivers/staging/speakup/kobjects.c
index 3708bc1..0211df6 100644
--- a/drivers/staging/speakup/kobjects.c
+++ b/drivers/staging/speakup/kobjects.c
@@ -840,12 +840,10 @@ static ssize_t message_show(struct kobject *kobj,
 static ssize_t message_store(struct kobject *kobj, struct kobj_attribute *attr,
 	const char *buf, size_t count)
-	ssize_t retval = 0;
 	struct msg_group_t *group = spk_find_msg_group(attr->attr.name);
 	BUG_ON(!group);
-	retval = message_store_helper(buf, count, group);
-	return retval;
+	return message_store_helper(buf, count, group);
