staging: speakup: remove multiple assignments
Author: Alison Schofield <amsfield22@gmail.com>
Remove multiple assignments by factorizing.
Coccinelle semantic patch used:
@@ identifier x,y; constant z; @@
- x=y=z;
+ x=z;
+ y=z;
Signed-off-by: Alison Schofield
 drivers/staging/speakup/main.c | 29 +++++++++++++++++++----------
 1 file changed, 19 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/speakup/main.c b/drivers/staging/speakup/main.c
index eb8d65a..a87224c 100644
--- a/drivers/staging/speakup/main.c
+++ b/drivers/staging/speakup/main.c
@@ -1188,7 +1188,8 @@ static void do_handle_latin(struct vc_data *vc, u_char value, char up_flag)
 	spin_lock_irqsave(&speakup_info.spinlock, flags);
 	if (up_flag) {
-		spk_lastkey = spk_keydown = 0;
+		spk_lastkey = 0;
+		spk_keydown = 0;
 		spin_unlock_irqrestore(&speakup_info.spinlock, flags);
 		return;
@@ -1662,7 +1663,8 @@ static void cursor_done(u_long data)
 	if (win_enabled) {
 		if (vc->vc_x >= win_left && vc->vc_x <= win_right &&
 		    vc->vc_y >= win_top && vc->vc_y <= win_bottom) {
-			spk_keydown = is_cursor = 0;
+			spk_keydown = 0;
+			is_cursor = 0;
 			goto out;
@@ -1672,7 +1674,8 @@ static void cursor_done(u_long data)
 	if (cursor_track == CT_Highlight) {
 		if (speak_highlight(vc)) {
+			spk_keydown = 0;
+			is_cursor = 0;
 			goto out;
@@ -1682,7 +1685,8 @@ static void cursor_done(u_long data)
 		say_line_from_to(vc, 0, vc->vc_cols, 0);
 	else
 		say_char(vc);
+	spk_keydown = 0;
+	is_cursor = 0;
 out:
@@ -1862,8 +1866,10 @@ static void speakup_win_set(struct vc_data *vc)
 static void speakup_win_clear(struct vc_data *vc)
-	win_top = win_bottom = 0;
-	win_left = win_right = 0;
+	win_top = 0;
+	win_bottom = 0;
+	win_left = 0;
+	win_right = 0;
 	win_start = 0;
 	synth_printf("%s\n", spk_msg_get(MSG_WINDOW_CLEARED));
@@ -1998,10 +2004,13 @@ static u_char key_speakup, spk_key_locked;
 static void speakup_lock(struct vc_data *vc)
-	if (!spk_key_locked)
-		spk_key_locked = key_speakup = 16;
-	else
-		spk_key_locked = key_speakup = 0;
+	if (!spk_key_locked) {
+		spk_key_locked = 16;
+		key_speakup = 16;
+	} else {
+		spk_key_locked = 0;
+		key_speakup = 0;
 typedef void (*spkup_hand) (struct vc_data *);
BtrLinux
Privacy Overview
