staging: speakup: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operation.
The case handled is  when the resultant value is assigned to
a variable. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/speakup/main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/speakup/main.c b/drivers/staging/speakup/main.c
index e9f0c15..1249f91 100644
--- a/drivers/staging/speakup/main.c
+++ b/drivers/staging/speakup/main.c
@@ -1527,7 +1527,7 @@ static void update_color_buffer(struct vc_data *vc, const char *ic, int len)
 	int i, bi, hi;
 	int vc_num = vc->vc_num;
-	bi = ((vc->vc_attr & 0x70) >> 4);
+	bi = (vc->vc_attr & 0x70) >> 4;
 	hi = speakup_console[vc_num]->ht.highsize[bi];
 	i = 0;
BtrLinux
Privacy Overview
