drivers/staging/sm750fb/ddk750_chip.c | 6 +++---
drivers/staging/sm750fb/ddk750_display.c | 2 +-
drivers/staging/sm750fb/ddk750_dvi.c | 4 ++--
drivers/staging/sm750fb/ddk750_power.c | 2 +-
drivers/staging/sm750fb/ddk750_sii164.c | 14 +++++++-------
drivers/staging/sm750fb/sm750_hw.c | 4 ++--
6 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/sm750fb/ddk750_chip.c b/drivers/staging/sm750fb/ddk750_chip.c
index b71169e..3c77207 100644
--- a/drivers/staging/sm750fb/ddk750_chip.c
+++ b/drivers/staging/sm750fb/ddk750_chip.c
@@ -11,7 +11,7 @@ typedef struct _pllcalparam{
pllcalparam;
-logical_chip_type_t getChipType()
+logical_chip_type_t getChipType(void)
unsigned short physicalID;
char physicalRev;
@@ -91,7 +91,7 @@ unsigned int getPllValue(clock_type_t clockType, pll_value_t *pPLL)
-unsigned int getChipClock()
+unsigned int getChipClock(void)
pll_value_t pll;
#if 1
@@ -232,7 +232,7 @@ void setMasterClock(unsigned int frequency)
-unsigned int ddk750_getVMSize()
+unsigned int ddk750_getVMSize(void)
unsigned int reg;
unsigned int data;
diff --git a/drivers/staging/sm750fb/ddk750_display.c b/drivers/staging/sm750fb/ddk750_display.c
index a282a94..c84196a 100644
--- a/drivers/staging/sm750fb/ddk750_display.c
+++ b/drivers/staging/sm750fb/ddk750_display.c
@@ -273,7 +273,7 @@ void ddk750_setLogicalDispOut(disp_output_t output)
-int ddk750_initDVIDisp()
+int ddk750_initDVIDisp(void)
/* Initialize DVI. If the dviInit fail and the VendorID or the DeviceID are
not zeroed, then set the failure flag. If it is zeroe, it might mean
diff --git a/drivers/staging/sm750fb/ddk750_dvi.c b/drivers/staging/sm750fb/ddk750_dvi.c
index 1c083e7..f5932bb 100644
--- a/drivers/staging/sm750fb/ddk750_dvi.c
+++ b/drivers/staging/sm750fb/ddk750_dvi.c
@@ -62,7 +62,7 @@ int dviInit(
* Output:
* Vendor ID
-unsigned short dviGetVendorID()
+unsigned short dviGetVendorID(void)
dvi_ctrl_device_t *pCurrentDviCtrl;
@@ -82,7 +82,7 @@ unsigned short dviGetVendorID()
* Output:
* Device ID
-unsigned short dviGetDeviceID()
+unsigned short dviGetDeviceID(void)
diff --git a/drivers/staging/sm750fb/ddk750_power.c b/drivers/staging/sm750fb/ddk750_power.c
index 98dfcbd..cbb9767 100644
--- a/drivers/staging/sm750fb/ddk750_power.c
+++ b/drivers/staging/sm750fb/ddk750_power.c
@@ -15,7 +15,7 @@ void ddk750_setDPMS(DPMS_t state)
-unsigned int getPowerMode()
+unsigned int getPowerMode(void)
if(getChipType() == SM750LE)
return 0;
diff --git a/drivers/staging/sm750fb/ddk750_sii164.c b/drivers/staging/sm750fb/ddk750_sii164.c
index faf8250..3d224d6 100644
--- a/drivers/staging/sm750fb/ddk750_sii164.c
+++ b/drivers/staging/sm750fb/ddk750_sii164.c
@@ -34,7 +34,7 @@ static char *gDviCtrlChipName = "Silicon Image SiI 164";
* Output:
* Vendor ID
-unsigned short sii164GetVendorID()
+unsigned short sii164GetVendorID(void)
unsigned short vendorID;
@@ -51,7 +51,7 @@ unsigned short sii164GetVendorID()
* Output:
* Device ID
-unsigned short sii164GetDeviceID()
+unsigned short sii164GetDeviceID(void)
unsigned short deviceID;
@@ -264,7 +264,7 @@ long sii164InitChip(
* sii164ResetChip
* This function resets the DVI Controller Chip.
-void sii164ResetChip()
+void sii164ResetChip(void)
/* Power down */
sii164SetPower(0);
@@ -277,7 +277,7 @@ void sii164ResetChip()
* This function returns a char string name of the current DVI Controller chip.
* It's convenient for application need to display the chip name.
-char *sii164GetChipString()
+char *sii164GetChipString(void)
return gDviCtrlChipName;
@@ -375,7 +375,7 @@ void sii164EnableHotPlugDetection(
* 0 - Not Connected
* 1 - Connected
-unsigned char sii164IsConnected()
+unsigned char sii164IsConnected(void)
unsigned char hotPlugValue;
@@ -394,7 +394,7 @@ unsigned char sii164IsConnected()
* 0 - No interrupt
* 1 - Interrupt occurs
-unsigned char sii164CheckInterrupt()
+unsigned char sii164CheckInterrupt(void)
unsigned char detectReg;
@@ -409,7 +409,7 @@ unsigned char sii164CheckInterrupt()
* sii164ClearInterrupt
* Clear the hot plug interrupt.
-void sii164ClearInterrupt()
+void sii164ClearInterrupt(void)
diff --git a/drivers/staging/sm750fb/sm750_hw.c b/drivers/staging/sm750fb/sm750_hw.c
index c44a50b..3050847 100644
--- a/drivers/staging/sm750fb/sm750_hw.c
+++ b/drivers/staging/sm750fb/sm750_hw.c
@@ -581,7 +581,7 @@ void hw_sm750_initAccel(struct lynx_share * share)
share->accel.de_init(&share->accel);
-int hw_sm750le_deWait()
+int hw_sm750le_deWait(void)
int i=0x10000000;
while(i--){
@@ -598,7 +598,7 @@ int hw_sm750le_deWait()
-int hw_sm750_deWait()
+int hw_sm750_deWait(void)
int i=0x10000000;
while(i--){ |
