staging: slicoss: remove extra parentheses around right bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operations.
The cases handled here are when resultant values are assigned to
variables. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Some coding style issues were handled manually to avoid
checkpatch warnings and errors.
Signed-off-by: Aya Mahfouz
 drivers/staging/slicoss/slicoss.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index 45f6a5f..c84dd60 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -164,7 +164,7 @@ static void slic_mcast_set_bit(struct adapter *adapter, char *address)
 	/* Get the CRC polynomial for the mac address */
 	/* we use bits 1-8 (lsb), bitwise reversed,
 	 * msb (= lsb bit 0 before bitrev) is automatically discarded */
-	crcpoly = (ether_crc(ETH_ALEN, address)>>23);
+	crcpoly = ether_crc(ETH_ALEN, address)>>23;
 	/* We only have space on the SLIC for 64 entries.  Lop
 	 * off the top two bits. (2^6 = 64)
@@ -1862,8 +1862,8 @@ static void slic_xmit_build_request(struct adapter *adapter,
 	hcmd->cmdsize = (u32) ((((u64)&ihcmd->u.slic_buffers.bufs[1] -
 				     (u64) hcmd) + 31) >> 5);
 #else
-	hcmd->cmdsize = ((((u32) &ihcmd->u.slic_buffers.bufs[1] -
-			   (u32) hcmd) + 31) >> 5);
+	hcmd->cmdsize = (((u32)&ihcmd->u.slic_buffers.bufs[1] -
+				       (u32)hcmd) + 31) >> 5;
 #endif
BtrLinux
Privacy Overview
