Staging: slicoss: remove duplicate structure field initialization
The definition of slic_netdev_ops has initializations of a local function
and eth_mac_addr for its ndo_set_mac_address field.  This change uses only
the local function.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier I, s, fld;
position p0,p;
expression E;
struct I s =@p0 { ... .fld@p = E, ...};
@s@
identifier I, s, r.fld;
position r.p0,p;
expression E;
@script:python@
p0 << r.p0;
fld << r.fld;
ps << s.p;
pr << r.p;
if int(ps[0].line)!=int(pr[0].line) or int(ps[0].column)!=int(pr[0].column):
  cocci.print_main(fld,p0)
Signed-off-by: Julia Lawall
 drivers/staging/slicoss/slicoss.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index e67a130..5b191af 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -354,7 +354,6 @@ static const struct net_device_ops slic_netdev_ops = {
 	.ndo_get_stats		= slic_get_stats,
 	.ndo_set_multicast_list	= slic_mcast_set_list,
 	.ndo_validate_addr	= eth_validate_addr,
-	.ndo_set_mac_address	= eth_mac_addr,
 	.ndo_change_mtu		= eth_change_mtu,
BtrLinux
Privacy Overview
