staging: slicoss: Add error check for pci_map_single
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Currently, DMA mapping failure is not detected, causing the hardware
to attempt a DMA from an invalid address.
This patch adds the corresponding error check for pci_map_single i.e.
pci_dma_mapping_error.
Problem found using the following Coccinelle semantic patch:
expression e1;
identifier x;
 x=
*dma_map_single(...)
*dma_map_page(...)
... when != dma_mapping_error(e1,x)
expression e1;
identifier x;
 x =
*pci_map_single(...)
*pci_map_page(...)
 ... when != pci_dma_mapping_error(e1,x)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/slicoss/slicoss.c | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index 6d50fc4..fa61e8e 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -1855,6 +1855,11 @@ static void slic_xmit_build_request(struct adapter *adapter,
 	ihcmd->u.slic_buffers.totlen = skb->len;
 	phys_addr = pci_map_single(adapter->pcidev, skb->data, skb->len,
 			PCI_DMA_TODEVICE);
+	if (pci_dma_mapping_error(adapter->pcidev, phys_addr)) {
+		kfree_skb(skb);
+		dev_err(&adapter->pcidev->dev, "DMA mapping error\n");
+		return;
 	ihcmd->u.slic_buffers.bufs[0].paddrl = SLIC_GET_ADDR_LOW(phys_addr);
 	ihcmd->u.slic_buffers.bufs[0].paddrh = SLIC_GET_ADDR_HIGH(phys_addr);
 	ihcmd->u.slic_buffers.bufs[0].length = skb->len;
BtrLinux
Privacy Overview
