staging: rts5208: simplify NULL tests
Author: Eva Rachel Retuya <eraretuya@gmail.com>
Replace direct comparisons to NULL i.e. 'x == NULL' with '!x' for
consistency. Coccinelle semantic patch used:
identifier func;
expression x;
statement Z;
x = func(...);
if (
	x
-	== NULL
-	NULL ==
	x
   ) Z
Signed-off-by: Eva Rachel Retuya
 drivers/staging/rts5208/ms.c        |  8 ++++----
 drivers/staging/rts5208/rtsx.c      |  6 +++---
 drivers/staging/rts5208/rtsx_scsi.c | 22 +++++++++++-----------
 drivers/staging/rts5208/sd.c        |  4 ++--
 drivers/staging/rts5208/spi.c       |  2 +-
 drivers/staging/rts5208/xd.c        |  4 ++--
 6 files changed, 23 insertions(+), 23 deletions(-)
diff --git a/drivers/staging/rts5208/ms.c b/drivers/staging/rts5208/ms.c
index 44d79ef..b8c9337 100644
--- a/drivers/staging/rts5208/ms.c
+++ b/drivers/staging/rts5208/ms.c
@@ -1039,7 +1039,7 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 	buf = kmalloc(64 * 512, GFP_KERNEL);
-	if (buf == NULL) {
+	if (!buf) {
 		rtsx_trace(chip);
 		return STATUS_ERROR;
@@ -2405,7 +2405,7 @@ static int ms_init_l2p_tbl(struct rtsx_chip *chip)
 	size = ms_card->segment_cnt * sizeof(struct zone_entry);
 	ms_card->segment = vzalloc(size);
-	if (ms_card->segment == NULL) {
+	if (!ms_card->segment) {
 		rtsx_trace(chip);
 		return STATUS_FAIL;
@@ -2614,7 +2614,7 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 	if (segment->l2p_table == NULL) {
 		segment->l2p_table = vmalloc(table_size * 2);
-		if (segment->l2p_table == NULL) {
+		if (!segment->l2p_table) {
 			rtsx_trace(chip);
 			goto BUILD_FAIL;
@@ -2623,7 +2623,7 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 	if (segment->free_table == NULL) {
 		segment->free_table = vmalloc(MS_FREE_TABLE_CNT * 2);
-		if (segment->free_table == NULL) {
+		if (!segment->free_table) {
 			rtsx_trace(chip);
 			goto BUILD_FAIL;
diff --git a/drivers/staging/rts5208/rtsx.c b/drivers/staging/rts5208/rtsx.c
index 62204b5..5ebaf8c 100644
--- a/drivers/staging/rts5208/rtsx.c
+++ b/drivers/staging/rts5208/rtsx.c
@@ -880,7 +880,7 @@ static int rtsx_probe(struct pci_dev *pci,
 	memset(dev, 0, sizeof(struct rtsx_dev));
 	dev->chip = kzalloc(sizeof(struct rtsx_chip), GFP_KERNEL);
-	if (dev->chip == NULL) {
+	if (!dev->chip) {
 		err = -ENOMEM;
 		goto errout;
@@ -901,7 +901,7 @@ static int rtsx_probe(struct pci_dev *pci,
 		 (unsigned int)pci_resource_len(pci, 0));
 	dev->addr = pci_resource_start(pci, 0);
 	dev->remap_addr = ioremap_nocache(dev->addr, pci_resource_len(pci, 0));
-	if (dev->remap_addr == NULL) {
+	if (!dev->remap_addr) {
 		dev_err(&pci->dev, "ioremap error\n");
 		err = -ENXIO;
 		goto errout;
@@ -916,7 +916,7 @@ static int rtsx_probe(struct pci_dev *pci,
 	dev->rtsx_resv_buf = dmam_alloc_coherent(&pci->dev, RTSX_RESV_BUF_LEN,
 			&dev->rtsx_resv_buf_addr, GFP_KERNEL);
-	if (dev->rtsx_resv_buf == NULL) {
+	if (!dev->rtsx_resv_buf) {
 		dev_err(&pci->dev, "alloc dma buffer fail\n");
 		err = -ENXIO;
 		goto errout;
diff --git a/drivers/staging/rts5208/rtsx_scsi.c b/drivers/staging/rts5208/rtsx_scsi.c
index 16284ca..d203104 100644
--- a/drivers/staging/rts5208/rtsx_scsi.c
+++ b/drivers/staging/rts5208/rtsx_scsi.c
@@ -507,7 +507,7 @@ static int inquiry(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = vmalloc(scsi_bufflen(srb));
+	if (!buf) {
 		rtsx_trace(chip);
 		return TRANSPORT_ERROR;
@@ -644,7 +644,7 @@ static int request_sense(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+	if (!buf) {
 		rtsx_trace(chip);
@@ -792,7 +792,7 @@ static int mode_sense(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 #endif
 	buf = kmalloc(dataSize, GFP_KERNEL);
+	if (!buf) {
 		rtsx_trace(chip);
@@ -1017,7 +1017,7 @@ static int read_format_capacity(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf_len = (scsi_bufflen(srb) > 12) ? 0x14 : 12;
 	buf = kmalloc(buf_len, GFP_KERNEL);
+	if (!buf) {
 		rtsx_trace(chip);
@@ -1096,7 +1096,7 @@ static int read_capacity(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = kmalloc(8, GFP_KERNEL);
+	if (!buf) {
 		rtsx_trace(chip);
@@ -1206,7 +1206,7 @@ static int write_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		len = (unsigned short)min_t(unsigned int, scsi_bufflen(srb),
 					len);
 		buf = vmalloc(len);
+		if (!buf) {
 			rtsx_trace(chip);
@@ -1315,7 +1315,7 @@ static int write_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = (unsigned short)min_t(unsigned int, scsi_bufflen(srb), len);
 	buf = vmalloc(len);
+	if (!buf) {
 		rtsx_trace(chip);
@@ -1410,7 +1410,7 @@ static int trace_msg_cmd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	clear = srb->cmnd[2];
+	if (!buf) {
 		rtsx_trace(chip);
@@ -2030,7 +2030,7 @@ static int write_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 					len);
 		buf = vmalloc(len);
+		if (!buf) {
 			rtsx_trace(chip);
@@ -2186,7 +2186,7 @@ static int write_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = vmalloc(len);
+	if (!buf) {
 		rtsx_trace(chip);
@@ -2290,7 +2290,7 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = (u8)min_t(unsigned int, scsi_bufflen(srb), len);
 	buf = vmalloc(len);
+	if (!buf) {
 		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/sd.c b/drivers/staging/rts5208/sd.c
index 1612610..87d6976 100644
--- a/drivers/staging/rts5208/sd.c
+++ b/drivers/staging/rts5208/sd.c
@@ -4588,7 +4588,7 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		cmd[4] = srb->cmnd[6];
 		buf = kmalloc(data_len, GFP_KERNEL);
+		if (!buf) {
 			rtsx_trace(chip);
@@ -4871,7 +4871,7 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		u8 *buf;
+		if (!buf) {
 			rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/spi.c b/drivers/staging/rts5208/spi.c
index 2e1e6cb..26eb2a1 100644
--- a/drivers/staging/rts5208/spi.c
+++ b/drivers/staging/rts5208/spi.c
@@ -662,7 +662,7 @@ int spi_read_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = kmalloc(SF_PAGE_LEN, GFP_KERNEL);
+	if (!buf) {
 		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/xd.c b/drivers/staging/rts5208/xd.c
index 10fea7b..fe84f75 100644
--- a/drivers/staging/rts5208/xd.c
+++ b/drivers/staging/rts5208/xd.c
@@ -1435,7 +1435,7 @@ static int xd_build_l2p_tbl(struct rtsx_chip *chip, int zone_no)
 	if (zone->l2p_table == NULL) {
 		zone->l2p_table = vmalloc(2000);
-		if (zone->l2p_table == NULL) {
+		if (!zone->l2p_table) {
 			rtsx_trace(chip);
 			goto Build_Fail;
@@ -1444,7 +1444,7 @@ static int xd_build_l2p_tbl(struct rtsx_chip *chip, int zone_no)
 	if (zone->free_table == NULL) {
 		zone->free_table = vmalloc(XD_FREE_TABLE_CNT * 2);
-		if (zone->free_table == NULL) {
+		if (!zone->free_table) {
 			rtsx_trace(chip);
 			goto Build_Fail;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
