staging: rts5208: Remove TRACE_RET and TRACE_GOTO macros
Author: Joe Perches <joe@perches.com>
Remove these flow hiding macros.
Miscellanea:
o Add a macro and function to replace a large inline
o Simplify #includes
o Add trace.c and update Makefile
o Remove static inline filename function and use kbasename instead
This reduces object size quite a lot: ~350KB (x86-64 allyesconfig)
$ size drivers/staging/rts5208/built-in.o*
   text	   data	    bss	    dec	    hex	filename
 248385	  36728	  77888	 363001	  589f9	drivers/staging/rts5208/built-in.o.new
 506691	  83352	 115896	 705939	  ac593	drivers/staging/rts5208/built-in.o.old
Done via coccinelle script and some typing.
expression chip;
expression ret;
-	TRACE_RET(chip, ret);
+	rtsx_trace(chip);
+	return ret;
expression chip;
identifier label;
-	TRACE_GOTO(chip, label);
+	rtsx_trace(chip);
+	goto label;
Signed-off-by: Joe Perches
 drivers/staging/rts5208/Makefile         |    2 +-
 drivers/staging/rts5208/ms.c             | 1404 ++++++++++++++++++++----------
 drivers/staging/rts5208/rtsx.c           |    6 -
 drivers/staging/rts5208/rtsx.h           |   13 +-
 drivers/staging/rts5208/rtsx_card.c      |   85 +-
 drivers/staging/rts5208/rtsx_chip.c      |  295 ++++---
 drivers/staging/rts5208/rtsx_chip.h      |   26 +-
 drivers/staging/rts5208/rtsx_scsi.c      |  539 ++++++++----
 drivers/staging/rts5208/rtsx_transport.c |    7 +-
 drivers/staging/rts5208/sd.c             | 1389 +++++++++++++++++++----------
 drivers/staging/rts5208/spi.c            |  255 ++++--
 drivers/staging/rts5208/trace.c          |   26 +
 drivers/staging/rts5208/trace.h          |   61 +-
 drivers/staging/rts5208/xd.c             |  453 ++++++----
 14 files changed, 2986 insertions(+), 1575 deletions(-)
diff --git a/drivers/staging/rts5208/Makefile b/drivers/staging/rts5208/Makefile
index 17b4471..f7fd03a 100644
--- a/drivers/staging/rts5208/Makefile
+++ b/drivers/staging/rts5208/Makefile
@@ -3,4 +3,4 @@ obj-$(CONFIG_RTS5208) := rts5208.o
 ccflags-y := -Idrivers/scsi
 rts5208-y := rtsx.o rtsx_chip.o rtsx_transport.o rtsx_scsi.o \
-	rtsx_card.o general.o sd.o xd.o ms.o spi.o
+	rtsx_card.o general.o sd.o xd.o ms.o spi.o trace.o
diff --git a/drivers/staging/rts5208/ms.c b/drivers/staging/rts5208/ms.c
index 4c38ff9..dcaec19 100644
--- a/drivers/staging/rts5208/ms.c
+++ b/drivers/staging/rts5208/ms.c
@@ -26,9 +26,6 @@
 #include <linux/vmalloc.h>
 #include "rtsx.h"
-#include "rtsx_transport.h"
-#include "rtsx_scsi.h"
-#include "rtsx_card.h"
 #include "ms.h"
 static inline void ms_set_err_code(struct rtsx_chip *chip, u8 err_code)
@@ -47,7 +44,8 @@ static inline int ms_check_err_code(struct rtsx_chip *chip, u8 err_code)
 static int ms_parse_err_code(struct rtsx_chip *chip)
-	TRACE_RET(chip, STATUS_FAIL);
+	rtsx_trace(chip);
+	return STATUS_FAIL;
 static int ms_transfer_tpc(struct rtsx_chip *chip, u8 trans_mode,
@@ -78,7 +76,8 @@ static int ms_transfer_tpc(struct rtsx_chip *chip, u8 trans_mode,
 	if (retval < 0) {
 		rtsx_clear_ms_error(chip);
 		ms_set_err_code(chip, MS_TO_ERROR);
-		TRACE_RET(chip, ms_parse_err_code(chip));
+		rtsx_trace(chip);
+		return ms_parse_err_code(chip);
 	ptr = rtsx_get_cmd_data(chip) + 1;
@@ -86,13 +85,15 @@ static int ms_transfer_tpc(struct rtsx_chip *chip, u8 trans_mode,
 	if (!(tpc & 0x08)) {		/* Read Packet */
 		if (*ptr & MS_CRC16_ERR) {
 			ms_set_err_code(chip, MS_CRC16_ERROR);
+			rtsx_trace(chip);
 	} else {			/* Write Packet */
 		if (CHK_MSPRO(ms_card) && !(*ptr & 0x80)) {
 			if (*ptr & (MS_INT_ERR | MS_INT_CMDNK)) {
 				ms_set_err_code(chip, MS_CMD_NK);
+				rtsx_trace(chip);
@@ -100,7 +101,8 @@ static int ms_transfer_tpc(struct rtsx_chip *chip, u8 trans_mode,
 	if (*ptr & MS_RDY_TIMEOUT) {
+		rtsx_trace(chip);
 	return STATUS_SUCCESS;
@@ -114,8 +116,10 @@ static int ms_transfer_data(struct rtsx_chip *chip, u8 trans_mode,
 	u8 val, err_code = 0;
 	enum dma_data_direction dir;
-	if (!buf || !buf_len)
+	if (!buf || !buf_len) {
+		rtsx_trace(chip);
 	if (trans_mode == MS_TM_AUTO_READ) {
 		dir = DMA_FROM_DEVICE;
@@ -124,7 +128,8 @@ static int ms_transfer_data(struct rtsx_chip *chip, u8 trans_mode,
 		dir = DMA_TO_DEVICE;
 		err_code = MS_FLASH_WRITE_ERROR;
 	} else {
+		rtsx_trace(chip);
 	rtsx_init_cmd(chip);
@@ -160,12 +165,15 @@ static int ms_transfer_data(struct rtsx_chip *chip, u8 trans_mode,
 		else
 			retval = STATUS_FAIL;
-		TRACE_RET(chip, retval);
+		rtsx_trace(chip);
+		return retval;
 	RTSX_READ_REG(chip, MS_TRANS_CFG, &val);
-	if (val & (MS_INT_CMDNK | MS_INT_ERR | MS_CRC16_ERR | MS_RDY_TIMEOUT))
+	if (val & (MS_INT_CMDNK | MS_INT_ERR | MS_CRC16_ERR | MS_RDY_TIMEOUT)) {
+		rtsx_trace(chip);
@@ -176,8 +184,10 @@ static int ms_write_bytes(struct rtsx_chip *chip,
 	struct ms_info *ms_card = &(chip->ms_card);
 	int retval, i;
-	if (!data || (data_len < cnt))
-		TRACE_RET(chip, STATUS_ERROR);
+	if (!data || (data_len < cnt)) {
+		rtsx_trace(chip);
+		return STATUS_ERROR;
@@ -211,25 +221,28 @@ static int ms_write_bytes(struct rtsx_chip *chip,
 			if (val & MS_CRC16_ERR) {
+				rtsx_trace(chip);
 		} else {
 			if (CHK_MSPRO(ms_card) && !(val & 0x80)) {
 				if (val & (MS_INT_ERR | MS_INT_CMDNK)) {
-					TRACE_RET(chip,
-						ms_parse_err_code(chip));
+					rtsx_trace(chip);
 		if (val & MS_RDY_TIMEOUT) {
+			rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -242,8 +255,10 @@ static int ms_read_bytes(struct rtsx_chip *chip,
 	int retval, i;
 	u8 *ptr;
-	if (!data)
+	if (!data) {
+		rtsx_trace(chip);
@@ -277,25 +292,28 @@ static int ms_read_bytes(struct rtsx_chip *chip,
+				rtsx_trace(chip);
 		} else {
-					TRACE_RET(chip,
+					rtsx_trace(chip);
+			rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -331,7 +349,8 @@ static int ms_set_rw_reg_addr(struct rtsx_chip *chip,
+	rtsx_trace(chip);
 static int ms_send_cmd(struct rtsx_chip *chip, u8 cmd, u8 cfg)
@@ -369,12 +388,16 @@ static int ms_set_init_para(struct rtsx_chip *chip)
 	retval = switch_clock(chip, ms_card->ms_clock);
-	if (retval != STATUS_SUCCESS)
+	if (retval != STATUS_SUCCESS) {
+		rtsx_trace(chip);
 	retval = select_card(chip, MS_CARD);
+		rtsx_trace(chip);
@@ -385,12 +408,16 @@ static int ms_switch_clock(struct rtsx_chip *chip)
 	int retval;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -455,8 +482,10 @@ static int ms_pull_ctl_enable(struct rtsx_chip *chip)
 	retval = rtsx_send_cmd(chip, MS_CARD, 100);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -475,20 +504,26 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 	ms_card->pro_under_formatting = 0;
 	retval = ms_power_off_card3v3(chip);
+		rtsx_trace(chip);
 	if (!chip->ft2_fast_mode)
 		wait_timeout(250);
 	retval = enable_card_clock(chip, MS_CARD);
+		rtsx_trace(chip);
 	if (chip->asic_code) {
 		retval = ms_pull_ctl_enable(chip);
+			rtsx_trace(chip);
 	} else {
 		RTSX_WRITE_REG(chip, FPGA_PULL_CTL,
 			FPGA_MS_PULL_CTL_BIT | 0x20, 0);
@@ -496,8 +531,10 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 	if (!chip->ft2_fast_mode) {
 		retval = card_power_on(chip, MS_CARD);
+			rtsx_trace(chip);
 		wait_timeout(150);
@@ -510,7 +547,8 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 		if (chip->ocp_stat & oc_mask) {
 			dev_dbg(rtsx_dev(chip), "Over current, OCPSTAT is 0x%x\n",
 				chip->ocp_stat);
+			rtsx_trace(chip);
 #endif
@@ -532,8 +570,10 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 		MS_STOP | MS_CLR_ERR, MS_STOP | MS_CLR_ERR);
 	retval = ms_set_init_para(chip);
+		rtsx_trace(chip);
@@ -545,8 +585,10 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 	u8 val;
 	retval = ms_set_rw_reg_addr(chip, Pro_StatusReg, 6, SystemParm, 1);
+		rtsx_trace(chip);
 	for (i = 0; i < MS_MAX_RETRY_COUNT; i++) {
 		retval = ms_transfer_tpc(chip, MS_TM_READ_BYTES, READ_REG,
@@ -554,8 +596,10 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		if (retval == STATUS_SUCCESS)
 			break;
-	if (i == MS_MAX_RETRY_COUNT)
+	if (i == MS_MAX_RETRY_COUNT) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, PPBUF_BASE2 + 2, &val);
 	dev_dbg(rtsx_dev(chip), "Type register: 0x%x\n", val);
@@ -563,14 +607,16 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		if (val != 0x02)
 			ms_card->check_ms_flow = 1;
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, PPBUF_BASE2 + 4, &val);
 	dev_dbg(rtsx_dev(chip), "Category register: 0x%x\n", val);
 	if (val != 0) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, PPBUF_BASE2 + 5, &val);
@@ -586,7 +632,8 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		chip->card_wp |= MS_CARD;
 	} else {
+		rtsx_trace(chip);
 	ms_card->ms_type |= TYPE_MSPRO;
@@ -602,7 +649,8 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 			ms_card->ms_type &= 0x0F;
 	} else {
+		rtsx_trace(chip);
@@ -618,7 +666,8 @@ static int ms_confirm_cpu_startup(struct rtsx_chip *chip)
 	do {
 		if (detect_card_cd(chip, MS_CARD) != STATUS_SUCCESS) {
 			ms_set_err_code(chip, MS_NO_CARD);
+			rtsx_trace(chip);
@@ -627,11 +676,15 @@ static int ms_confirm_cpu_startup(struct rtsx_chip *chip)
 				break;
+			rtsx_trace(chip);
-		if (k > 100)
+		if (k > 100) {
+			rtsx_trace(chip);
 		k++;
 		wait_timeout(100);
@@ -642,14 +695,18 @@ static int ms_confirm_cpu_startup(struct rtsx_chip *chip)
 			break;
+		rtsx_trace(chip);
 	if (val & INT_REG_ERR) {
 		if (val & INT_REG_CMDNK)
 			chip->card_wp |= (MS_CARD);
-		else
+		else {
+			rtsx_trace(chip);
 	/* --  end confirm CPU startup */
@@ -669,8 +726,10 @@ static int ms_switch_parallel_bus(struct rtsx_chip *chip)
 			break;
+		rtsx_trace(chip);
@@ -689,21 +748,27 @@ static int ms_switch_8bit_bus(struct rtsx_chip *chip)
 			break;
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, MS_CFG, 0x98,
 		MS_BUS_WIDTH_8 | SAMPLE_TIME_FALLING);
 	ms_card->ms_type |= MS_8BIT;
+		rtsx_trace(chip);
 		retval = ms_transfer_tpc(chip, MS_TM_READ_BYTES, GET_INT,
 					1, NO_WAIT_INT);
+			rtsx_trace(chip);
@@ -716,22 +781,29 @@ static int ms_pro_reset_flow(struct rtsx_chip *chip, int switch_8bit_bus)
 	for (i = 0; i < 3; i++) {
 		retval = ms_prepare_reset(chip);
+			rtsx_trace(chip);
 		retval = ms_identify_media_type(chip, switch_8bit_bus);
+			rtsx_trace(chip);
 		retval = ms_confirm_cpu_startup(chip);
+			rtsx_trace(chip);
 		retval = ms_switch_parallel_bus(chip);
+				rtsx_trace(chip);
 			continue;
 		} else {
@@ -739,23 +811,28 @@ static int ms_pro_reset_flow(struct rtsx_chip *chip, int switch_8bit_bus)
+		rtsx_trace(chip);
 	/* Switch MS-PRO into Parallel mode */
 	RTSX_WRITE_REG(chip, MS_CFG, 0x18, MS_BUS_WIDTH_4);
 	RTSX_WRITE_REG(chip, MS_CFG, PUSH_TIME_ODD, PUSH_TIME_ODD);
+		rtsx_trace(chip);
 	/* If MSPro HG Card, We shall try to switch to 8-bit bus */
 	if (CHK_MSHG(ms_card) && chip->support_ms_8bit && switch_8bit_bus) {
 		retval = ms_switch_8bit_bus(chip);
 			ms_card->switch_8bit_fail = 1;
+			rtsx_trace(chip);
@@ -771,8 +848,10 @@ static int msxc_change_power(struct rtsx_chip *chip, u8 mode)
 	ms_cleanup_work(chip);
 	retval = ms_set_rw_reg_addr(chip, 0, 0, Pro_DataCount1, 6);
+		rtsx_trace(chip);
 	buf[0] = 0;
 	buf[1] = mode;
@@ -782,16 +861,22 @@ static int msxc_change_power(struct rtsx_chip *chip, u8 mode)
 	buf[5] = 0;
 	retval = ms_write_bytes(chip, PRO_WRITE_REG, 6, NO_WAIT_INT, buf, 6);
+		rtsx_trace(chip);
 	retval = ms_send_cmd(chip, XC_CHG_POWER, WAIT_INT);
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, MS_TRANS_CFG, buf);
-	if (buf[0] & (MS_INT_CMDNK | MS_INT_ERR))
+	if (buf[0] & (MS_INT_CMDNK | MS_INT_ERR)) {
+		rtsx_trace(chip);
@@ -813,8 +898,10 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 #endif
 	retval = ms_set_rw_reg_addr(chip, Pro_IntReg, 2, Pro_SystemParm, 7);
+		rtsx_trace(chip);
 	if (CHK_MS8BIT(ms_card))
 		data[0] = PARALLEL_8BIT_IF;
@@ -836,12 +923,16 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 			break;
+		rtsx_trace(chip);
 	buf = kmalloc(64 * 512, GFP_KERNEL);
-	if (buf == NULL)
+	if (buf == NULL) {
+		rtsx_trace(chip);
 		retval = ms_send_cmd(chip, PRO_READ_ATRB, WAIT_INT);
@@ -851,11 +942,13 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 		retval = rtsx_read_register(chip, MS_TRANS_CFG, &val);
 			kfree(buf);
+			rtsx_trace(chip);
 		if (!(val & MS_INT_BREQ)) {
 			kfree(buf);
+			rtsx_trace(chip);
 		retval = ms_transfer_data(chip, MS_TM_AUTO_READ,
 					PRO_READ_LONG_DATA, 0x40, WAIT_INT,
@@ -867,7 +960,8 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 		kfree(buf);
+		rtsx_trace(chip);
 	i = 0;
@@ -875,7 +969,8 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 			kfree(buf);
+			rtsx_trace(chip);
 		if ((val & MS_INT_CED) || !(val & MS_INT_BREQ))
@@ -885,7 +980,8 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 					PRO_READ_LONG_DATA, 0, WAIT_INT);
 			kfree(buf);
+			rtsx_trace(chip);
 		i++;
@@ -893,18 +989,21 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 		kfree(buf);
+		rtsx_trace(chip);
 	if ((buf[0] != 0xa5) && (buf[1] != 0xc3)) {
 		/* Signature code is wrong */
 		kfree(buf);
+		rtsx_trace(chip);
 	if ((buf[4] < 1) || (buf[4] > 12)) {
 		kfree(buf);
+		rtsx_trace(chip);
 	for (i = 0; i < buf[4]; i++) {
@@ -929,15 +1028,18 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 				sys_info_addr, sys_info_size);
 			if (sys_info_size != 96)  {
 				kfree(buf);
+				rtsx_trace(chip);
 			if (sys_info_addr < 0x1A0) {
 				kfree(buf);
+				rtsx_trace(chip);
 			if ((sys_info_size + sys_info_addr) > 0x8000) {
 				kfree(buf);
+				rtsx_trace(chip);
 #ifdef SUPPORT_MSXC
@@ -964,15 +1066,18 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 				model_name_addr, model_name_size);
 			if (model_name_size != 48)  {
 				kfree(buf);
+				rtsx_trace(chip);
 			if (model_name_addr < 0x1A0) {
 				kfree(buf);
+				rtsx_trace(chip);
 			if ((model_name_size + model_name_addr) > 0x8000) {
 				kfree(buf);
+				rtsx_trace(chip);
 			found_model_name = 1;
@@ -985,7 +1090,8 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 	if (i == buf[4]) {
 		kfree(buf);
+		rtsx_trace(chip);
 	class_code =  buf[sys_info_addr + 0];
@@ -1030,15 +1136,21 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 #ifdef SUPPORT_MSXC
 	if (CHK_MSXC(ms_card)) {
-		if (class_code != 0x03)
+		if (class_code != 0x03) {
+			rtsx_trace(chip);
 	} else {
-		if (class_code != 0x02)
+		if (class_code != 0x02) {
+			rtsx_trace(chip);
 #else
+		rtsx_trace(chip);
 #endif
 	if (device_type != 0x00) {
@@ -1046,12 +1158,15 @@ static int ms_read_attribute_info(struct rtsx_chip *chip)
 				(device_type == 0x03)) {
 		} else {
+			rtsx_trace(chip);
-	if (sub_class & 0xC0)
+	if (sub_class & 0xC0) {
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "class_code: 0x%x, device_type: 0x%x, sub_class: 0x%x\n",
 		class_code, device_type, sub_class);
@@ -1099,16 +1214,21 @@ Retry:
 		if (ms_card->switch_8bit_fail) {
 			retval = ms_pro_reset_flow(chip, 0);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 	retval = ms_read_attribute_info(chip);
+		rtsx_trace(chip);
 #ifdef XC_POWERCLASS
 	if (CHK_HG8BIT(ms_card))
@@ -1148,8 +1268,10 @@ Retry:
 #ifdef SUPPORT_MAGIC_GATE
 	retval = mg_set_tpc_para_sub(chip, 0, 0);
+		rtsx_trace(chip);
 #endif
@@ -1166,16 +1288,21 @@ static int ms_read_status_reg(struct rtsx_chip *chip)
 	u8 val[2];
 	retval = ms_set_rw_reg_addr(chip, StatusReg0, 2, 0, 0);
+		rtsx_trace(chip);
 	retval = ms_read_bytes(chip, READ_REG, 2, NO_WAIT_INT, val, 2);
+		rtsx_trace(chip);
 	if (val[1] & (STS_UCDT | STS_UCEX | STS_UCFG)) {
 		ms_set_err_code(chip, MS_FLASH_READ_ERROR);
+		rtsx_trace(chip);
@@ -1191,8 +1318,10 @@ static int ms_read_extra_data(struct rtsx_chip *chip,
 	retval = ms_set_rw_reg_addr(chip, OverwriteFlag, MS_EXTRA_SIZE,
 				SystemParm, 6);
+		rtsx_trace(chip);
 	if (CHK_MS4BIT(ms_card)) {
 		/* Parallel interface */
@@ -1213,8 +1342,10 @@ static int ms_read_extra_data(struct rtsx_chip *chip,
 			break;
+		rtsx_trace(chip);
 	ms_set_err_code(chip, MS_NO_ERROR);
@@ -1223,35 +1354,46 @@ static int ms_read_extra_data(struct rtsx_chip *chip,
 			break;
+		rtsx_trace(chip);
 	retval = ms_read_bytes(chip, GET_INT, 1, NO_WAIT_INT, &val, 1);
+		rtsx_trace(chip);
 	if (val & INT_REG_CMDNK) {
+		rtsx_trace(chip);
 	if (val & INT_REG_CED) {
 			retval = ms_read_status_reg(chip);
+				rtsx_trace(chip);
 						MS_EXTRA_SIZE, SystemParm, 6);
+				rtsx_trace(chip);
 	retval = ms_read_bytes(chip, READ_REG, MS_EXTRA_SIZE, NO_WAIT_INT,
 			data, MS_EXTRA_SIZE);
+		rtsx_trace(chip);
 	if (buf && buf_len) {
 		if (buf_len > MS_EXTRA_SIZE)
@@ -1269,13 +1411,17 @@ static int ms_write_extra_data(struct rtsx_chip *chip,
 	int retval, i;
 	u8 val, data[16];
-	if (!buf || (buf_len < MS_EXTRA_SIZE))
+	if (!buf || (buf_len < MS_EXTRA_SIZE)) {
+		rtsx_trace(chip);
 				SystemParm, 6 + MS_EXTRA_SIZE);
+		rtsx_trace(chip);
 		data[0] = 0x88;
@@ -1293,26 +1439,34 @@ static int ms_write_extra_data(struct rtsx_chip *chip,
 	retval = ms_write_bytes(chip, WRITE_REG, (6 + MS_EXTRA_SIZE),
 				NO_WAIT_INT, data, 16);
+		rtsx_trace(chip);
 	retval = ms_send_cmd(chip, BLOCK_WRITE, WAIT_INT);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 			ms_set_err_code(chip, MS_FLASH_WRITE_ERROR);
+			rtsx_trace(chip);
@@ -1328,8 +1482,10 @@ static int ms_read_page(struct rtsx_chip *chip, u16 block_addr, u8 page_num)
 				SystemParm, 6);
+		rtsx_trace(chip);
 		data[0] = 0x88;
@@ -1343,28 +1499,36 @@ static int ms_read_page(struct rtsx_chip *chip, u16 block_addr, u8 page_num)
 	data[5] = page_num;
 	retval = ms_write_bytes(chip, WRITE_REG, 6, NO_WAIT_INT, data, 6);
+		rtsx_trace(chip);
 	retval = ms_send_cmd(chip, BLOCK_READ, WAIT_INT);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 			if (!(val & INT_REG_BREQ)) {
+				rtsx_trace(chip);
@@ -1373,18 +1537,23 @@ static int ms_read_page(struct rtsx_chip *chip, u16 block_addr, u8 page_num)
 		} else {
 				ms_set_err_code(chip, MS_BREQ_ERROR);
+				rtsx_trace(chip);
 	retval = ms_transfer_tpc(chip, MS_TM_NORMAL_READ, READ_PAGE_DATA,
 				0, NO_WAIT_INT);
+		rtsx_trace(chip);
-	if (ms_check_err_code(chip, MS_FLASH_WRITE_ERROR))
+	if (ms_check_err_code(chip, MS_FLASH_WRITE_ERROR)) {
+		rtsx_trace(chip);
@@ -1397,13 +1566,17 @@ static int ms_set_bad_block(struct rtsx_chip *chip, u16 phy_blk)
 	u8 val, data[8], extra[MS_EXTRA_SIZE];
 	retval = ms_read_extra_data(chip, phy_blk, 0, extra, MS_EXTRA_SIZE);
+		rtsx_trace(chip);
 				SystemParm, 7);
+		rtsx_trace(chip);
@@ -1421,27 +1594,35 @@ static int ms_set_bad_block(struct rtsx_chip *chip, u16 phy_blk)
 	data[7] = 0xFF;
 	retval = ms_write_bytes(chip, WRITE_REG, 7, NO_WAIT_INT, data, 7);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -1457,8 +1638,10 @@ static int ms_erase_block(struct rtsx_chip *chip, u16 phy_blk)
 				SystemParm, 6);
+		rtsx_trace(chip);
@@ -1474,18 +1657,24 @@ static int ms_erase_block(struct rtsx_chip *chip, u16 phy_blk)
 	data[5] = 0;
+		rtsx_trace(chip);
 ERASE_RTY:
 	retval = ms_send_cmd(chip, BLOCK_ERASE, WAIT_INT);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 		if (i < 3) {
@@ -1495,13 +1684,15 @@ ERASE_RTY:
 		ms_set_bad_block(chip, phy_blk);
+		rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -1544,13 +1735,16 @@ static int ms_init_page(struct rtsx_chip *chip, u16 phy_blk, u16 log_blk,
 	for (i = start_page; i < end_page; i++) {
+			rtsx_trace(chip);
 		retval = ms_write_extra_data(chip, phy_blk, i,
+			rtsx_trace(chip);
@@ -1570,42 +1764,54 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 		start_page, end_page);
 	retval = ms_read_extra_data(chip, new_blk, 0, extra, MS_EXTRA_SIZE);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, PPBUF_BASE2, &val);
 	if (val & BUF_FULL) {
 		retval = ms_send_cmd(chip, CLEAR_BUF, WAIT_INT);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 		if (!(val & INT_REG_CED)) {
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 		ms_read_extra_data(chip, old_blk, i, extra, MS_EXTRA_SIZE);
+			rtsx_trace(chip);
@@ -1622,21 +1828,28 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 					data, 6);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -1653,8 +1866,10 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 							MS_TM_NORMAL_READ,
 							READ_PAGE_DATA,
 							0, NO_WAIT_INT);
+					rtsx_trace(chip);
 				if (uncorrect_flag) {
 					ms_set_page_status(log_blk, setPS_NG,
@@ -1685,13 +1900,16 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 						break;
-				if (rty_cnt == MS_MAX_RETRY_COUNT)
+				if (rty_cnt == MS_MAX_RETRY_COUNT) {
+					rtsx_trace(chip);
+				rtsx_trace(chip);
@@ -1725,35 +1943,45 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+				rtsx_trace(chip);
 		if (i == 0) {
 						MS_EXTRA_SIZE, SystemParm, 7);
+				rtsx_trace(chip);
@@ -1772,29 +2000,37 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 						NO_WAIT_INT, data, 8);
+				rtsx_trace(chip);
+				rtsx_trace(chip);
+				rtsx_trace(chip);
+				rtsx_trace(chip);
+					rtsx_trace(chip);
@@ -1815,18 +2051,24 @@ static int reset_ms(struct rtsx_chip *chip)
 #endif
+		rtsx_trace(chip);
 	ms_card->ms_type |= TYPE_MS;
 	retval = ms_send_cmd(chip, MS_RESET, NO_WAIT_INT);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (val & WRT_PRTCT)
@@ -1841,7 +2083,8 @@ RE_SEARCH:
 	while (i < (MAX_DEFECTIVE_BLOCK + 2)) {
+			rtsx_trace(chip);
 		retval = ms_read_extra_data(chip, i, 0, extra, MS_EXTRA_SIZE);
@@ -1861,7 +2104,8 @@ RE_SEARCH:
 	if (i == (MAX_DEFECTIVE_BLOCK + 2)) {
 		dev_dbg(rtsx_dev(chip), "No boot block found!");
+		rtsx_trace(chip);
 	for (j = 0; j < 3; j++) {
@@ -1876,8 +2120,10 @@ RE_SEARCH:
 	retval = ms_read_page(chip, ms_card->boot_block, 0);
+		rtsx_trace(chip);
 	/* Read MS system information as sys_info */
@@ -1886,8 +2132,10 @@ RE_SEARCH:
 		rtsx_add_cmd(chip, READ_REG_CMD, PPBUF_BASE2 + 0x1A0 + i, 0, 0);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	ptr = rtsx_get_cmd_data(chip);
 	memcpy(ms_card->raw_sys_info, ptr, 96);
@@ -1909,8 +2157,10 @@ RE_SEARCH:
 	rtsx_add_cmd(chip, READ_REG_CMD, MS_4bit_Support, 0, 0);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -1983,16 +2233,20 @@ RE_SEARCH:
 	/* Switch I/F Mode */
 	if (ptr[15]) {
 		retval = ms_set_rw_reg_addr(chip, 0, 0, SystemParm, 1);
+			rtsx_trace(chip);
 		RTSX_WRITE_REG(chip, PPBUF_BASE2, 0xFF, 0x88);
 		RTSX_WRITE_REG(chip, PPBUF_BASE2 + 1, 0xFF, 0);
 		retval = ms_transfer_tpc(chip, MS_TM_WRITE_BYTES, WRITE_REG, 1,
 					NO_WAIT_INT);
+			rtsx_trace(chip);
 		RTSX_WRITE_REG(chip, MS_CFG, 0x58 | MS_NO_CHECK_INT,
 			MS_BUS_WIDTH_4 | PUSH_TIME_ODD | MS_NO_CHECK_INT);
@@ -2021,24 +2275,32 @@ static int ms_init_l2p_tbl(struct rtsx_chip *chip)
 	size = ms_card->segment_cnt * sizeof(struct zone_entry);
 	ms_card->segment = vzalloc(size);
-	if (ms_card->segment == NULL)
+	if (ms_card->segment == NULL) {
+		rtsx_trace(chip);
 	retval = ms_read_page(chip, ms_card->boot_block, 1);
-		TRACE_GOTO(chip, INIT_FAIL);
+		rtsx_trace(chip);
+		goto INIT_FAIL;
 	reg_addr = PPBUF_BASE2;
 	for (i = 0; i < (((ms_card->total_block >> 9) * 10) + 1); i++) {
 		int block_no;
 		retval = rtsx_read_register(chip, reg_addr++, &val1);
+			rtsx_trace(chip);
+			goto INIT_FAIL;
 		retval = rtsx_read_register(chip, reg_addr++, &val2);
+			rtsx_trace(chip);
+			goto INIT_FAIL;
 		defect_block = ((u16)val1 << 8) | val2;
 		if (defect_block == 0xFFFF)
@@ -2201,8 +2463,10 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 		retval = ms_init_l2p_tbl(chip);
+			rtsx_trace(chip);
+			return retval;
 	if (ms_card->segment[seg_no].build_flag) {
@@ -2220,15 +2484,19 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 	if (segment->l2p_table == NULL) {
 		segment->l2p_table = vmalloc(table_size * 2);
-		if (segment->l2p_table == NULL)
-			TRACE_GOTO(chip, BUILD_FAIL);
+		if (segment->l2p_table == NULL) {
+			rtsx_trace(chip);
+			goto BUILD_FAIL;
 	memset((u8 *)(segment->l2p_table), 0xff, table_size * 2);
 	if (segment->free_table == NULL) {
 		segment->free_table = vmalloc(MS_FREE_TABLE_CNT * 2);
-		if (segment->free_table == NULL)
+		if (segment->free_table == NULL) {
+			rtsx_trace(chip);
+			goto BUILD_FAIL;
 	memset((u8 *)(segment->free_table), 0xff, MS_FREE_TABLE_CNT * 2);
@@ -2352,8 +2620,10 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 			retval = ms_init_page(chip, phy_blk, log_blk, 0, 1);
+				rtsx_trace(chip);
+				goto BUILD_FAIL;
 			segment->l2p_table[idx] = phy_blk;
 			if (seg_no == ms_card->segment_cnt - 1) {
@@ -2383,14 +2653,18 @@ static int ms_build_l2p_tbl(struct rtsx_chip *chip, int seg_no)
 				phy_blk = ms_get_unused_block(chip, 0);
 				retval = ms_copy_page(chip, tmp_blk, phy_blk,
 						log_blk, 0, ms_card->page_off + 1);
+					rtsx_trace(chip);
 				segment->l2p_table[log_blk] = phy_blk;
 				retval = ms_set_bad_block(chip, tmp_blk);
+					rtsx_trace(chip);
@@ -2420,12 +2694,16 @@ int reset_ms_card(struct rtsx_chip *chip)
 	memset(ms_card, 0, sizeof(struct ms_info));
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	ms_card->ms_type = 0;
@@ -2433,24 +2711,31 @@ int reset_ms_card(struct rtsx_chip *chip)
 		if (ms_card->check_ms_flow) {
 			retval = reset_ms(chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (!CHK_MSPRO(ms_card)) {
 		/* Build table for the last segment,
 		 * to check if L2P table block exists, erasing it
 		retval = ms_build_l2p_tbl(chip, ms_card->total_block / 512 - 1);
+			rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "ms_card->ms_type = 0x%x\n", ms_card->ms_type);
@@ -2479,8 +2764,10 @@ static int mspro_set_rw_cmd(struct rtsx_chip *chip,
 			break;
+		rtsx_trace(chip);
@@ -2520,8 +2807,10 @@ static inline int ms_auto_tune_clock(struct rtsx_chip *chip)
 	retval = ms_switch_clock(chip);
+		rtsx_trace(chip);
@@ -2570,8 +2859,10 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
+		rtsx_trace(chip);
 	if (srb->sc_data_direction == DMA_FROM_DEVICE)
 		trans_mode = MS_TM_AUTO_READ;
@@ -2591,8 +2882,10 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
 			ms_card->total_sec_cnt = 0;
 			if (val & MS_INT_BREQ) {
 				retval = ms_send_cmd(chip, PRO_STOP, WAIT_INT);
+					rtsx_trace(chip);
 				rtsx_write_register(chip, RBCTL, RB_FLUSH, RB_FLUSH);
@@ -2619,7 +2912,8 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
 		retval = mspro_set_rw_cmd(chip, start_sector, count, rw_cmd);
 			ms_card->seq_mode = 0;
+			rtsx_trace(chip);
@@ -2634,7 +2928,8 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
 			chip->rw_need_retry = 0;
 			dev_dbg(rtsx_dev(chip), "No card exist, exit mspro_rw_multi_sector\n");
+			rtsx_trace(chip);
@@ -2646,7 +2941,8 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
 			ms_auto_tune_clock(chip);
+		rtsx_trace(chip);
+		return retval;
 	if (ms_card->seq_mode) {
@@ -2674,13 +2970,15 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
 		ms_card->format_status = FORMAT_FAIL;
+		rtsx_trace(chip);
 	retval = rtsx_read_register(chip, MS_TRANS_CFG, &tmp);
+		rtsx_trace(chip);
 	if (!(tmp & MS_INT_BREQ)) {
@@ -2689,7 +2987,8 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
+		rtsx_trace(chip);
 	if (short_data_len >= 256)
@@ -2701,14 +3000,16 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
 				MS_NO_CHECK_INT);
+		rtsx_trace(chip);
 	retval = ms_read_bytes(chip, PRO_READ_SHORT_DATA, cnt, WAIT_INT,
 			data, 8);
+		rtsx_trace(chip);
 	total_progress = (data[0] << 24) | (data[1] << 16) |
@@ -2733,7 +3034,8 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
+			rtsx_trace(chip);
 		if (tmp & (MS_INT_CED | MS_INT_CMDNK |
 				MS_INT_BREQ | MS_INT_ERR))
@@ -2745,17 +3047,20 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
 	retval = rtsx_write_register(chip, MS_CFG, MS_NO_CHECK_INT, 0);
+		rtsx_trace(chip);
 	if (i == 5000) {
+		rtsx_trace(chip);
 	if (tmp & (MS_INT_CMDNK | MS_INT_ERR)) {
+		rtsx_trace(chip);
 	if (tmp & MS_INT_CED) {
@@ -2766,7 +3071,8 @@ static int mspro_read_format_progress(struct rtsx_chip *chip,
 	} else {
+		rtsx_trace(chip);
@@ -2798,12 +3104,16 @@ int mspro_format(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 	u16 para;
+		rtsx_trace(chip);
 	retval = ms_set_rw_reg_addr(chip, 0x00, 0x00, Pro_TPCParm, 0x01);
+		rtsx_trace(chip);
 	memset(buf, 0, 2);
 	switch (short_data_len) {
@@ -2828,8 +3138,10 @@ int mspro_format(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 			break;
+		rtsx_trace(chip);
 	if (quick_format)
 		para = 0x0000;
@@ -2837,13 +3149,17 @@ int mspro_format(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 		para = 0x0001;
 	retval = mspro_set_rw_cmd(chip, 0, para, PRO_FORMAT);
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, MS_TRANS_CFG, &tmp);
-	if (tmp & (MS_INT_CMDNK | MS_INT_ERR))
+	if (tmp & (MS_INT_CMDNK | MS_INT_ERR)) {
+		rtsx_trace(chip);
 	if ((tmp & (MS_INT_BREQ | MS_INT_CED)) == MS_INT_BREQ) {
 		ms_card->pro_under_formatting = 1;
@@ -2860,7 +3176,8 @@ int mspro_format(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+	rtsx_trace(chip);
@@ -2879,14 +3196,17 @@ static int ms_read_multiple_pages(struct rtsx_chip *chip, u16 phy_blk,
 	if (retval == STATUS_SUCCESS) {
 		if ((extra[1] & 0x30) != 0x30) {
+			rtsx_trace(chip);
 				SystemParm, 6);
+		rtsx_trace(chip);
 		data[0] = 0x88;
@@ -2905,14 +3225,18 @@ static int ms_read_multiple_pages(struct rtsx_chip *chip, u16 phy_blk,
 			break;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	ptr = buf;
@@ -2921,16 +3245,20 @@ static int ms_read_multiple_pages(struct rtsx_chip *chip, u16 phy_blk,
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 			if (val & INT_REG_BREQ) {
@@ -2943,34 +3271,42 @@ static int ms_read_multiple_pages(struct rtsx_chip *chip, u16 phy_blk,
 								page_addr, extra, MS_EXTRA_SIZE);
+					rtsx_trace(chip);
 			} else {
+				rtsx_trace(chip);
 		} else {
+				rtsx_trace(chip);
 		if (page_addr == (end_page - 1)) {
 				retval = ms_send_cmd(chip, BLOCK_END, WAIT_INT);
+					rtsx_trace(chip);
 					&val, 1);
+				rtsx_trace(chip);
+				rtsx_trace(chip);
 			trans_cfg = NO_WAIT_INT;
@@ -3003,19 +3339,22 @@ static int ms_read_multiple_pages(struct rtsx_chip *chip, u16 phy_blk,
 			if (retval == -ETIMEDOUT) {
-				TRACE_RET(chip, STATUS_TIMEDOUT);
+				rtsx_trace(chip);
+				return STATUS_TIMEDOUT;
+				rtsx_trace(chip);
 			if (val & (MS_CRC16_ERR | MS_RDY_TIMEOUT)) {
+				rtsx_trace(chip);
@@ -3039,8 +3378,10 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
 	if (!start_page) {
 					SystemParm, 7);
+			rtsx_trace(chip);
 			data[0] = 0x88;
@@ -3057,24 +3398,32 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
 					data, 8);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 		retval = ms_transfer_tpc(chip, MS_TM_READ_BYTES, GET_INT, 1,
 					NO_WAIT_INT);
+			rtsx_trace(chip);
 				SystemParm, (6 + MS_EXTRA_SIZE));
+		rtsx_trace(chip);
@@ -3106,20 +3455,26 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
 			break;
+		rtsx_trace(chip);
 			break;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	ptr = buf;
 	for (page_addr = start_page; page_addr < end_page; page_addr++) {
@@ -3127,20 +3482,24 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 		udelay(30);
@@ -3171,34 +3530,43 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
-			if (retval == -ETIMEDOUT)
-			else
+			if (retval == -ETIMEDOUT) {
+				rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 		if ((end_page - start_page) == 1) {
+				rtsx_trace(chip);
 		} else {
 							WAIT_INT);
+						rtsx_trace(chip);
+					rtsx_trace(chip);
 			if ((page_addr == (end_page - 1)) ||
@@ -3206,7 +3574,8 @@ static int ms_write_multiple_pages(struct rtsx_chip *chip, u16 old_blk,
+					rtsx_trace(chip);
@@ -3227,8 +3596,10 @@ static int ms_finish_write(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 	retval = ms_copy_page(chip, old_blk, new_blk, log_blk,
 			page_off, ms_card->page_off + 1);
+		rtsx_trace(chip);
 	seg_no = old_blk >> 9;
@@ -3254,8 +3625,10 @@ static int ms_prepare_write(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 	if (start_page) {
 				0, start_page);
+			rtsx_trace(chip);
@@ -3270,8 +3643,10 @@ int ms_delay_write(struct rtsx_chip *chip)
 	if (delay_write->delay_write_flag) {
+			rtsx_trace(chip);
 		delay_write->delay_write_flag = 0;
 		retval = ms_finish_write(chip,
@@ -3279,8 +3654,10 @@ int ms_delay_write(struct rtsx_chip *chip)
 					delay_write->new_phyblock,
 					delay_write->logblock,
 					delay_write->pageoff);
+			rtsx_trace(chip);
@@ -3319,7 +3696,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 		ms_rw_fail(srb, chip);
+		rtsx_trace(chip);
 	log_blk = (u16)(start_sector >> ms_card->block_shift);
@@ -3335,7 +3713,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 			chip->card_fail |= MS_CARD;
 			set_sense_type(chip, lun, SENSE_TYPE_MEDIA_NOT_PRESENT);
+			rtsx_trace(chip);
@@ -3352,7 +3731,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 					SENSE_TYPE_MEDIA_WRITE_ERR);
+				rtsx_trace(chip);
 			old_blk = delay_write->old_phyblock;
 			new_blk = delay_write->new_phyblock;
@@ -3367,7 +3747,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 #endif
 			old_blk = ms_get_l2p_tbl(chip, seg_no,
@@ -3376,7 +3757,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 			if ((old_blk == 0xFFFF) || (new_blk == 0xFFFF)) {
+				rtsx_trace(chip);
 			retval = ms_prepare_write(chip, old_blk, new_blk,
@@ -3385,11 +3767,13 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+					rtsx_trace(chip);
+				rtsx_trace(chip);
 #ifdef MS_DELAY_WRITE
@@ -3401,11 +3785,13 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 				SENSE_TYPE_MEDIA_UNRECOVER_READ_ERR);
+			rtsx_trace(chip);
 #endif
@@ -3413,7 +3799,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 		if (old_blk == 0xFFFF) {
+			rtsx_trace(chip);
@@ -3446,10 +3833,12 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
+			rtsx_trace(chip);
 		if (srb->sc_data_direction == DMA_TO_DEVICE) {
@@ -3485,7 +3874,8 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
@@ -3493,14 +3883,16 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 					log_blk - ms_start_idx[seg_no]);
+			rtsx_trace(chip);
 			new_blk = ms_get_unused_block(chip, seg_no);
 			if (new_blk == 0xFFFF) {
+				rtsx_trace(chip);
@@ -3525,11 +3917,13 @@ static int ms_rw_multi_sector(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+					rtsx_trace(chip);
+				rtsx_trace(chip);
 #endif
@@ -3591,12 +3985,16 @@ static int ms_poll_int(struct rtsx_chip *chip)
 	rtsx_add_cmd(chip, CHECK_REG_CMD, MS_TRANS_CFG, MS_INT_CED, MS_INT_CED);
 	retval = rtsx_send_cmd(chip, MS_CARD, 5000);
+		rtsx_trace(chip);
 	val = *rtsx_get_cmd_data(chip);
-	if (val & MS_INT_ERR)
+	if (val & MS_INT_ERR) {
+		rtsx_trace(chip);
@@ -3659,12 +4057,15 @@ static int mg_send_ex_cmd(struct rtsx_chip *chip, u8 cmd, u8 entry_num)
 			break;
+		rtsx_trace(chip);
 	if (check_ms_err(chip)) {
+		rtsx_trace(chip);
@@ -3681,8 +4082,10 @@ static int mg_set_tpc_para_sub(struct rtsx_chip *chip, int type,
 	else
+		rtsx_trace(chip);
 	buf[0] = 0;
 	buf[1] = 0;
@@ -3694,8 +4097,10 @@ static int mg_set_tpc_para_sub(struct rtsx_chip *chip, int type,
 	retval = ms_write_bytes(chip, PRO_WRITE_REG, (type == 0) ? 1 : 6,
+		rtsx_trace(chip);
@@ -3709,19 +4114,23 @@ int mg_set_leaf_id(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (scsi_bufflen(srb) < 12) {
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_INVALID_CMD_FIELD);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	retval = mg_send_ex_cmd(chip, MG_SET_LID, 0);
 		set_sense_type(chip, lun, SENSE_TYPE_MG_KEY_FAIL_NOT_ESTAB);
+		rtsx_trace(chip);
 	memset(buf1, 0, 32);
@@ -3733,12 +4142,14 @@ int mg_set_leaf_id(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				buf1, 32);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -3754,12 +4165,16 @@ int mg_get_local_EKB(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	buf = kmalloc(1540, GFP_KERNEL);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	buf[0] = 0x04;
 	buf[1] = 0x1A;
@@ -3769,7 +4184,8 @@ int mg_get_local_EKB(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	retval = mg_send_ex_cmd(chip, MG_GET_LEKB, 0);
 		set_sense_type(chip, lun, SENSE_TYPE_MG_KEY_FAIL_NOT_AUTHEN);
-		TRACE_GOTO(chip, GetEKBFinish);
+		rtsx_trace(chip);
+		goto GetEKBFinish;
 	retval = ms_transfer_data(chip, MS_TM_AUTO_READ, PRO_READ_LONG_DATA,
@@ -3777,12 +4193,14 @@ int mg_get_local_EKB(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	bufflen = min_t(int, 1052, scsi_bufflen(srb));
@@ -3805,25 +4223,30 @@ int mg_chg(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	retval = mg_send_ex_cmd(chip, MG_GET_ID, 0);
 		set_sense_type(chip, lun, SENSE_TYPE_MG_INCOMPATIBLE_MEDIUM);
+		rtsx_trace(chip);
 	retval = ms_read_bytes(chip, PRO_READ_SHORT_DATA, 32, WAIT_INT,
 			buf, 32);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	memcpy(ms_card->magic_gate_id, buf, 16);
@@ -3832,14 +4255,16 @@ int mg_chg(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	retval = ms_poll_int(chip);
+		rtsx_trace(chip);
 #endif
 	retval = mg_send_ex_cmd(chip, MG_SET_RD, 0);
+		rtsx_trace(chip);
 	bufflen = min_t(int, 12, scsi_bufflen(srb));
@@ -3855,12 +4280,14 @@ int mg_chg(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				32, WAIT_INT, buf, 32);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	ms_card->mg_auth = 0;
@@ -3879,25 +4306,30 @@ int mg_get_rsp_chg(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	retval = mg_send_ex_cmd(chip, MG_MAKE_RMS, 0);
+		rtsx_trace(chip);
 			buf1, 32);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	buf2[0] = 0x00;
@@ -3915,7 +4347,8 @@ int mg_get_rsp_chg(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 #endif
@@ -3934,13 +4367,16 @@ int mg_rsp(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	retval = mg_send_ex_cmd(chip, MG_MAKE_KSE, 0);
+		rtsx_trace(chip);
@@ -3956,12 +4392,14 @@ int mg_rsp(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				buf, 32);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	ms_card->mg_auth = 1;
@@ -3980,12 +4418,16 @@ int mg_get_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	buf = kmalloc(1028, GFP_KERNEL);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	buf[0] = 0x04;
 	buf[1] = 0x02;
@@ -3995,7 +4437,8 @@ int mg_get_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	retval = mg_send_ex_cmd(chip, MG_GET_IBD, ms_card->mg_entry_num);
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_UNRECOVER_READ_ERR);
-		TRACE_GOTO(chip, GetICVFinish);
+		rtsx_trace(chip);
+		goto GetICVFinish;
@@ -4003,12 +4446,14 @@ int mg_get_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	bufflen = min_t(int, 1028, scsi_bufflen(srb));
@@ -4033,12 +4478,16 @@ int mg_set_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	rtsx_stor_get_xfer_buf(buf, bufflen, srb);
@@ -4055,7 +4504,8 @@ int mg_set_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		} else {
 			set_sense_type(chip, lun, SENSE_TYPE_MG_WRITE_ERR);
-		TRACE_GOTO(chip, SetICVFinish);
+		rtsx_trace(chip);
+		goto SetICVFinish;
 #ifdef MG_SET_ICV_SLOW
@@ -4094,7 +4544,8 @@ int mg_set_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+			rtsx_trace(chip);
 #else
@@ -4112,7 +4563,8 @@ int mg_set_ICV(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		} else {
+		rtsx_trace(chip);
 #endif
@@ -4152,13 +4604,17 @@ int ms_power_off_card3v3(struct rtsx_chip *chip)
 	int retval;
 	retval = disable_card_clock(chip, MS_CARD);
+		rtsx_trace(chip);
 		retval = ms_pull_ctl_disable(chip);
+			rtsx_trace(chip);
 	} else {
 			FPGA_MS_PULL_CTL_BIT | 0x20, FPGA_MS_PULL_CTL_BIT);
@@ -4166,8 +4622,10 @@ int ms_power_off_card3v3(struct rtsx_chip *chip)
 	RTSX_WRITE_REG(chip, CARD_OE, MS_OUTPUT_EN, 0);
 		retval = card_power_off(chip, MS_CARD);
+			rtsx_trace(chip);
@@ -4195,8 +4653,10 @@ int release_ms_card(struct rtsx_chip *chip)
 #endif
+		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/rtsx.c b/drivers/staging/rts5208/rtsx.c
index c482a6a..d64b6ed 100644
--- a/drivers/staging/rts5208/rtsx.c
+++ b/drivers/staging/rts5208/rtsx.c
@@ -26,12 +26,6 @@
 #include <linux/workqueue.h>
 #include "rtsx.h"
-#include "rtsx_chip.h"
-#include "general.h"
 #include "ms.h"
 #include "sd.h"
 #include "xd.h"
diff --git a/drivers/staging/rts5208/rtsx.h b/drivers/staging/rts5208/rtsx.h
index 9e6ecb7..262441b 100644
--- a/drivers/staging/rts5208/rtsx.h
+++ b/drivers/staging/rts5208/rtsx.h
@@ -46,9 +46,6 @@
 #include <scsi/scsi_eh.h>
 #include <scsi/scsi_host.h>
-#include "trace.h"
 #define CR_DRIVER_NAME		"rts5208"
 #define pci_get_bus_and_slot(bus, devfn)	\
@@ -181,4 +178,14 @@ enum xfer_buf_dir	{TO_XFER_BUF, FROM_XFER_BUF};
 int rtsx_read_pci_cfg_byte(u8 bus, u8 dev, u8 func, u8 offset, u8 *val);
+#define _MSG_TRACE
+#include "trace.h"
+#include "rtsx_chip.h"
+#include "rtsx_transport.h"
+#include "rtsx_scsi.h"
+#include "rtsx_card.h"
+#include "rtsx_sys.h"
+#include "general.h"
 #endif  /* __REALTEK_RTSX_H */
diff --git a/drivers/staging/rts5208/rtsx_card.c b/drivers/staging/rts5208/rtsx_card.c
index b4595ab..d7ca44f 100644
--- a/drivers/staging/rts5208/rtsx_card.c
+++ b/drivers/staging/rts5208/rtsx_card.c
@@ -27,13 +27,6 @@
 #include <linux/kernel.h>
 #include "rtsx.h"
-#include "rtsx_sys.h"
 #include "sd.h"
 #include "xd.h"
 #include "ms.h"
@@ -657,8 +650,10 @@ int switch_ssc_clock(struct rtsx_chip *chip, int clk)
 	dev_dbg(rtsx_dev(chip), "Switch SSC clock to %dMHz (cur_clk = %d)\n",
 		clk, chip->cur_clk);
-	if ((clk <= 2) || (N > max_N))
+	if ((clk <= 2) || (N > max_N)) {
+		rtsx_trace(chip);
 	mcu_cnt = (u8)(125/clk + 3);
 	if (mcu_cnt > 7)
@@ -697,8 +692,10 @@ int switch_ssc_clock(struct rtsx_chip *chip, int clk)
 	retval = rtsx_send_cmd(chip, 0, WAIT_TIME);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	udelay(10);
 	RTSX_WRITE_REG(chip, CLK_CTL, CLK_LOW_FREQ, 0);
@@ -790,7 +787,8 @@ int switch_normal_clock(struct rtsx_chip *chip, int clk)
 	default:
 		dev_dbg(rtsx_dev(chip), "Try to switch to an illegal clock (%d)\n",
 			clk);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CLK_CTL, 0xFF, CLK_LOW_FREQ);
@@ -893,8 +891,10 @@ int card_power_on(struct rtsx_chip *chip, u8 card)
 	rtsx_add_cmd(chip, WRITE_REG_CMD, CARD_PWR_CTL, mask, val1);
 	retval = rtsx_send_cmd(chip, 0, 100);
+		rtsx_trace(chip);
 	udelay(chip->pmos_pwr_on_interval);
@@ -902,8 +902,10 @@ int card_power_on(struct rtsx_chip *chip, u8 card)
 	rtsx_add_cmd(chip, WRITE_REG_CMD, CARD_PWR_CTL, mask, val2);
+		rtsx_trace(chip);
@@ -932,8 +934,10 @@ int card_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 	unsigned int lun = SCSI_LUN(srb);
 	int i;
-	if (chip->rw_card[lun] == NULL)
+	if (chip->rw_card[lun] == NULL) {
+		rtsx_trace(chip);
@@ -942,11 +946,14 @@ int card_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 			if (rtsx_check_chip_exist(chip) != STATUS_SUCCESS) {
 				rtsx_release_chip(chip);
+				rtsx_trace(chip);
 			if (detect_card_cd(chip, chip->cur_card) !=
-							STATUS_SUCCESS)
+							STATUS_SUCCESS) {
+				rtsx_trace(chip);
 			if (!chip->rw_need_retry) {
 				dev_dbg(rtsx_dev(chip), "RW fail, but no need to retry\n");
@@ -975,8 +982,10 @@ int card_share_mode(struct rtsx_chip *chip, int card)
 			value = CARD_SHARE_48_MS;
 		else if (card == XD_CARD)
 			value = CARD_SHARE_48_XD;
-		else
+		else {
+			rtsx_trace(chip);
 	} else if (CHECK_PID(chip, 0x5288)) {
 		mask = 0x03;
@@ -986,11 +995,14 @@ int card_share_mode(struct rtsx_chip *chip, int card)
 			value = CARD_SHARE_BAROSSA_MS;
 			value = CARD_SHARE_BAROSSA_XD;
-		else
+		else {
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CARD_SHARE_MODE, mask, value);
@@ -1014,15 +1026,19 @@ int select_card(struct rtsx_chip *chip, int card)
 			mod = XD_MOD_SEL;
 		else if (card == SPI_CARD)
 			mod = SPI_MOD_SEL;
-		else
+		else {
+			rtsx_trace(chip);
 		RTSX_WRITE_REG(chip, CARD_SELECT, 0x07, mod);
 		chip->cur_card = card;
 		retval =  card_share_mode(chip, card);
+			rtsx_trace(chip);
@@ -1067,12 +1083,15 @@ int detect_card_cd(struct rtsx_chip *chip, int card)
 		card_cd = XD_EXIST;
 	} else {
 		dev_dbg(rtsx_dev(chip), "Wrong card type: 0x%x\n", card);
+		rtsx_trace(chip);
 	status = rtsx_readl(chip, RTSX_BIPR);
-	if (!(status & card_cd))
+	if (!(status & card_cd)) {
+		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/rtsx_chip.c b/drivers/staging/rts5208/rtsx_chip.c
index 35fa19d..a8feee8 100644
--- a/drivers/staging/rts5208/rtsx_chip.c
+++ b/drivers/staging/rts5208/rtsx_chip.c
@@ -27,13 +27,6 @@
 #include "rtsx.h"
 #include "sd.h"
 #include "xd.h"
 #include "ms.h"
@@ -198,15 +191,19 @@ static int rtsx_pre_handle_sdio_new(struct rtsx_chip *chip)
 				retval = sd_pull_ctl_enable(chip);
+					rtsx_trace(chip);
 			} else {
 					       FPGA_SD_PULL_CTL_BIT | 0x20, 0);
 			retval = card_share_mode(chip, SD_CARD);
+				rtsx_trace(chip);
 			/* Enable sdio_bus_auto_switch */
@@ -237,8 +234,10 @@ static int rtsx_reset_aspm(struct rtsx_chip *chip)
 		ret = rtsx_write_cfg_dw(chip, 2, 0xC0, 0xFF,
 					chip->aspm_l0s_l1_en);
-		if (ret != STATUS_SUCCESS)
+		if (ret != STATUS_SUCCESS) {
+			rtsx_trace(chip);
@@ -246,16 +245,20 @@ static int rtsx_reset_aspm(struct rtsx_chip *chip)
 	if (CHECK_PID(chip, 0x5208))
 		RTSX_WRITE_REG(chip, ASPM_FORCE_CTL, 0xFF, 0x3F);
 	ret = rtsx_write_config_byte(chip, LCTLR, chip->aspm_l0s_l1_en);
+		rtsx_trace(chip);
 	chip->aspm_level[0] = chip->aspm_l0s_l1_en;
 	if (CHK_SDIO_EXIST(chip)) {
 		chip->aspm_level[1] = chip->aspm_l0s_l1_en;
 		ret = rtsx_write_cfg_dw(chip, CHECK_PID(chip, 0x5288) ? 2 : 1,
 					0xC0, 0xFF, chip->aspm_l0s_l1_en);
+			rtsx_trace(chip);
 	chip->aspm_enabled = 1;
@@ -283,23 +286,31 @@ static int rtsx_enable_pcie_intr(struct rtsx_chip *chip)
 		u16 reg;
 		ret = rtsx_read_phy_register(chip, 0x00, &reg);
+			rtsx_trace(chip);
 		reg &= 0xFE7F;
 		reg |= 0x80;
 		ret = rtsx_write_phy_register(chip, 0x00, reg);
+			rtsx_trace(chip);
 		ret = rtsx_read_phy_register(chip, 0x1C, &reg);
+			rtsx_trace(chip);
 		reg &= 0xFFF7;
 		ret = rtsx_write_phy_register(chip, 0x1C, reg);
+			rtsx_trace(chip);
 	if (chip->driver_first_load && (chip->ic_version < IC_VER_C))
@@ -371,41 +382,55 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 	/* Enable ASPM */
 	if (chip->aspm_l0s_l1_en) {
 		retval = rtsx_reset_aspm(chip);
+			rtsx_trace(chip);
 	} else {
 		if (chip->asic_code && CHECK_PID(chip, 0x5208)) {
 			retval = rtsx_write_phy_register(chip, 0x07, 0x0129);
+				rtsx_trace(chip);
 		retval = rtsx_write_config_byte(chip, LCTLR,
+			rtsx_trace(chip);
 	retval = rtsx_write_config_byte(chip, 0x81, 1);
+		rtsx_trace(chip);
 		retval = rtsx_write_cfg_dw(chip,
 					   0xC0, 0xFF00, 0x0100);
+			rtsx_trace(chip);
 	if (CHECK_PID(chip, 0x5288) && !CHK_SDIO_EXIST(chip)) {
 		retval = rtsx_write_cfg_dw(chip, 2, 0xC0, 0xFFFF, 0x0103);
+			rtsx_trace(chip);
 		retval = rtsx_write_cfg_dw(chip, 2, 0x84, 0xFF, 0x03);
+			rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, IRQSTAT0, LINK_RDY_INT, LINK_RDY_INT);
@@ -413,8 +438,10 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 	RTSX_WRITE_REG(chip, PERST_GLITCH_WIDTH, 0xFF, 0x80);
 	retval = rtsx_enable_pcie_intr(chip);
+		rtsx_trace(chip);
 	chip->need_reset = 0;
@@ -436,8 +463,10 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 #else  /* HW_AUTO_SWITCH_SD_BUS */
 		retval = rtsx_pre_handle_sdio_old(chip);
 #endif  /* HW_AUTO_SWITCH_SD_BUS */
+			rtsx_trace(chip);
 	} else {
 		chip->sd_io = 0;
@@ -477,8 +506,10 @@ nextcard:
 		retval = rtsx_clr_phy_reg_bit(chip, 0x1C, 2);
+			rtsx_trace(chip);
 	if (chip->ft2_fast_mode) {
@@ -545,8 +576,10 @@ static int rts5208_init(struct rtsx_chip *chip)
 		retval = rtsx_read_phy_register(chip, 0x1C, &reg);
+			rtsx_trace(chip);
 		dev_dbg(rtsx_dev(chip), "Value of phy register 0x1C is 0x%x\n",
 			reg);
@@ -605,8 +638,10 @@ static int rts5288_init(struct rtsx_chip *chip)
 	chip->hw_bypass_sd = val & 0x10 ? 1 : 0;
 	retval = rtsx_read_cfg_dw(chip, 0, 0x718, &lval);
+		rtsx_trace(chip);
 	max_func = (u8)((lval >> 29) & 0x07);
 	dev_dbg(rtsx_dev(chip), "Max function number: %d\n", max_func);
@@ -703,13 +738,17 @@ int rtsx_init_chip(struct rtsx_chip *chip)
 	if (CHECK_PID(chip, 0x5208)) {
 		retval = rts5208_init(chip);
+			rtsx_trace(chip);
 		retval = rts5288_init(chip);
+			rtsx_trace(chip);
 	if (chip->ss_en == 2)
@@ -756,8 +795,10 @@ int rtsx_init_chip(struct rtsx_chip *chip)
 	retval = rtsx_reset_chip(chip);
+		rtsx_trace(chip);
@@ -1155,14 +1196,17 @@ int rtsx_write_register(struct rtsx_chip *chip, u16 addr, u8 mask, u8 data)
 	for (i = 0; i < MAX_RW_REG_CNT; i++) {
 		val = rtsx_readl(chip, RTSX_HAIMR);
 		if ((val & (1 << 31)) == 0) {
-			if (data != (u8)val)
+			if (data != (u8)val) {
+				rtsx_trace(chip);
+	rtsx_trace(chip);
 int rtsx_read_register(struct rtsx_chip *chip, u16 addr, u8 *data)
@@ -1183,8 +1227,10 @@ int rtsx_read_register(struct rtsx_chip *chip, u16 addr, u8 *data)
 			break;
-	if (i >= MAX_RW_REG_CNT)
+	if (i >= MAX_RW_REG_CNT) {
+		rtsx_trace(chip);
 	if (data)
 		*data = (u8)(val & 0xFF);
@@ -1261,8 +1307,10 @@ int rtsx_write_cfg_seq(struct rtsx_chip *chip, u8 func, u16 addr, u8 *buf,
 	int dw_len, i, j;
 	int retval;
-	if (!buf)
-		TRACE_RET(chip, STATUS_NOMEM);
+	if (!buf) {
+		rtsx_trace(chip);
+		return STATUS_NOMEM;
 	if ((len + offset) % 4)
 		dw_len = (len + offset) / 4 + 1;
@@ -1272,13 +1320,16 @@ int rtsx_write_cfg_seq(struct rtsx_chip *chip, u8 func, u16 addr, u8 *buf,
 	dev_dbg(rtsx_dev(chip), "dw_len = %d\n", dw_len);
 	data = vzalloc(dw_len * 4);
-	if (!data)
+	if (!data) {
+		rtsx_trace(chip);
 	mask = vzalloc(dw_len * 4);
 	if (!mask) {
 		vfree(data);
+		rtsx_trace(chip);
 	j = 0;
@@ -1302,7 +1353,8 @@ int rtsx_write_cfg_seq(struct rtsx_chip *chip, u8 func, u16 addr, u8 *buf,
 			vfree(data);
 			vfree(mask);
+			rtsx_trace(chip);
@@ -1329,15 +1381,18 @@ int rtsx_read_cfg_seq(struct rtsx_chip *chip, u8 func, u16 addr, u8 *buf,
 	data = vmalloc(dw_len * 4);
-	if (!data)
+	if (!data) {
+		rtsx_trace(chip);
 	for (i = 0; i < dw_len; i++) {
 		retval = rtsx_read_cfg_dw(chip, func, aligned_addr + i * 4,
 					  data + i);
 			vfree(data);
+			rtsx_trace(chip);
@@ -1377,8 +1432,10 @@ int rtsx_write_phy_register(struct rtsx_chip *chip, u8 addr, u16 val)
-	if (!finished)
+	if (!finished) {
+		rtsx_trace(chip);
@@ -1401,8 +1458,10 @@ int rtsx_read_phy_register(struct rtsx_chip *chip, u8 addr, u16 *val)
-	if (!finished)
+	if (!finished) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, PHYDATA0, &tmp);
 	data = tmp;
@@ -1429,8 +1488,10 @@ int rtsx_read_efuse(struct rtsx_chip *chip, u8 addr, u8 *val)
 		udelay(1);
-	if (data & 0x80)
+	if (data & 0x80) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, EFUSE_DATA, &data);
 	if (val)
@@ -1461,8 +1522,10 @@ int rtsx_write_efuse(struct rtsx_chip *chip, u8 addr, u8 val)
 			wait_timeout(3);
-		if (data & 0x80)
+			rtsx_trace(chip);
 		wait_timeout(5);
@@ -1476,14 +1539,18 @@ int rtsx_clr_phy_reg_bit(struct rtsx_chip *chip, u8 reg, u8 bit)
 	u16 value;
 	retval = rtsx_read_phy_register(chip, reg, &value);
+		rtsx_trace(chip);
 	if (value & (1 << bit)) {
 		value &= ~(1 << bit);
 		retval = rtsx_write_phy_register(chip, reg, value);
+			rtsx_trace(chip);
@@ -1495,14 +1562,18 @@ int rtsx_set_phy_reg_bit(struct rtsx_chip *chip, u8 reg, u8 bit)
 	u16 value;
+		rtsx_trace(chip);
 	if ((value & (1 << bit)) == 0) {
 		value |= (1 << bit);
+			rtsx_trace(chip);
@@ -1818,8 +1889,10 @@ int rtsx_read_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
 	u16 reg_addr;
 	u8 *ptr;
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	ptr = buf;
@@ -1830,8 +1903,10 @@ int rtsx_read_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
 			rtsx_add_cmd(chip, READ_REG_CMD, reg_addr++, 0, 0);
 		retval = rtsx_send_cmd(chip, 0, 250);
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
 		memcpy(ptr, rtsx_get_cmd_data(chip), 256);
 		ptr += 256;
@@ -1844,8 +1919,10 @@ int rtsx_read_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
 	memcpy(ptr, rtsx_get_cmd_data(chip), buf_len%256);
@@ -1860,8 +1937,10 @@ int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
 	u16 reg_addr;
 	u8 *ptr;
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	ptr = buf;
@@ -1875,8 +1954,10 @@ int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
 	if (buf_len%256) {
@@ -1889,8 +1970,10 @@ int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
@@ -1898,8 +1981,10 @@ int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len)
 int rtsx_check_chip_exist(struct rtsx_chip *chip)
-	if (rtsx_readl(chip, 0) == 0xFFFFFFFF)
+	if (rtsx_readl(chip, 0) == 0xFFFFFFFF) {
+		rtsx_trace(chip);
@@ -1922,8 +2007,10 @@ int rtsx_force_power_on(struct rtsx_chip *chip, u8 ctl)
 	if (mask) {
 		retval = rtsx_write_register(chip, FPDCTL, mask, 0);
+			rtsx_trace(chip);
 			wait_timeout(200);
@@ -1951,8 +2038,10 @@ int rtsx_force_power_down(struct rtsx_chip *chip, u8 ctl)
 	if (mask) {
 		val = mask;
 		retval = rtsx_write_register(chip, FPDCTL, mask, val);
+			rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/rtsx_chip.h b/drivers/staging/rts5208/rtsx_chip.h
index feac986..93fd7b2 100644
--- a/drivers/staging/rts5208/rtsx_chip.h
+++ b/drivers/staging/rts5208/rtsx_chip.h
@@ -989,19 +989,21 @@ int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len);
 int rtsx_check_chip_exist(struct rtsx_chip *chip);
 #define RTSX_WRITE_REG(chip, addr, mask, data)				\
-	do {								\
-		int retval = rtsx_write_register((chip), (addr), (mask), (data)); \
-		if (retval != STATUS_SUCCESS) {				\
-			TRACE_RET((chip), retval);			\
-	} while (0)
+do {									\
+	int retval = rtsx_write_register(chip, addr, mask, data);	\
+	if (retval != STATUS_SUCCESS) {					\
+		rtsx_trace(chip);					\
+		return retval;						\
+} while (0)
 #define RTSX_READ_REG(chip, addr, data)					\
-	do {								\
-		int retval = rtsx_read_register((chip), (addr), (data)); \
-	} while (0)
+do {									\
+	int retval = rtsx_read_register(chip, addr, data);		\
+		return retval;						\
+} while (0)
 #endif  /* __REALTEK_RTSX_CHIP_H */
diff --git a/drivers/staging/rts5208/rtsx_scsi.c b/drivers/staging/rts5208/rtsx_scsi.c
index 98f102b..8a5d6a8 100644
--- a/drivers/staging/rts5208/rtsx_scsi.c
+++ b/drivers/staging/rts5208/rtsx_scsi.c
@@ -26,11 +26,6 @@
 #include "rtsx.h"
 #include "sd.h"
 #include "ms.h"
 #include "spi.h"
@@ -512,8 +507,10 @@ static int inquiry(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = vmalloc(scsi_bufflen(srb));
-	if (buf == NULL)
-		TRACE_RET(chip, TRANSPORT_ERROR);
+		rtsx_trace(chip);
+		return TRANSPORT_ERROR;
 	if ((chip->mspro_formatter_enable) &&
@@ -587,12 +584,14 @@ static int start_stop_unit(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (check_card_ready(chip, lun))
 			return TRANSPORT_GOOD;
-		TRACE_RET(chip, TRANSPORT_FAILED);
+		rtsx_trace(chip);
+		return TRANSPORT_FAILED;
 		break;
+	rtsx_trace(chip);
@@ -607,7 +606,8 @@ static int allow_medium_removal(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (prevent) {
 		set_sense_type(chip, SCSI_LUN(srb),
+		rtsx_trace(chip);
@@ -644,8 +644,10 @@ static int request_sense(struct scsi_cmnd *srb, struct rtsx_chip *chip)
-	if (buf == NULL)
+		rtsx_trace(chip);
 	tmp = (unsigned char *)sense;
 	memcpy(buf, tmp, scsi_bufflen(srb));
@@ -765,7 +767,8 @@ static int mode_sense(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (!check_card_ready(chip, lun)) {
 		scsi_set_resid(srb, scsi_bufflen(srb));
+		rtsx_trace(chip);
 #endif
@@ -789,8 +792,10 @@ static int mode_sense(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 #endif
 	buf = kmalloc(dataSize, GFP_KERNEL);
-	if (buf == NULL)
+		rtsx_trace(chip);
 	pageCode = srb->cmnd[2] & 0x3f;
@@ -869,7 +874,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (!check_card_ready(chip, lun) || (get_card_size(chip, lun) == 0)) {
+		rtsx_trace(chip);
 	if (!(CHK_BIT(chip->lun_mc, lun))) {
@@ -885,7 +891,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		dev_dbg(rtsx_dev(chip), "SD card being erased!\n");
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_READ_FORBIDDEN);
+		rtsx_trace(chip);
 	if (get_lun_card(chip, lun) == SD_CARD) {
@@ -893,7 +900,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			dev_dbg(rtsx_dev(chip), "SD card locked!\n");
+			rtsx_trace(chip);
 #endif
@@ -916,7 +924,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		sec_cnt = ((u16)(srb->cmnd[9]) << 8) | srb->cmnd[10];
 	} else {
+		rtsx_trace(chip);
 	/* In some test, we will receive a start_sec like 0xFFFFFFFF.
@@ -926,7 +935,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if ((start_sec > get_card_size(chip, lun)) ||
 			((start_sec + sec_cnt) > get_card_size(chip, lun))) {
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_LBA_OVER_RANGE);
+		rtsx_trace(chip);
 	if (sec_cnt == 0) {
@@ -942,7 +952,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		else
 			set_sense_type(chip, lun, SENSE_TYPE_MEDIA_WRITE_ERR);
+		rtsx_trace(chip);
@@ -950,7 +961,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			dev_dbg(rtsx_dev(chip), "Write protected card!\n");
 				SENSE_TYPE_MEDIA_WRITE_PROTECT);
+			rtsx_trace(chip);
@@ -969,7 +981,8 @@ static int read_write(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		retval = TRANSPORT_FAILED;
-		TRACE_GOTO(chip, Exit);
+		rtsx_trace(chip);
+		goto Exit;
 	} else {
 		chip->rw_fail_cnt[lun] = 0;
 		retval = TRANSPORT_GOOD;
@@ -994,15 +1007,18 @@ static int read_format_capacity(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (!chip->mspro_formatter_enable) {
+			rtsx_trace(chip);
 	buf_len = (scsi_bufflen(srb) > 12) ? 0x14 : 12;
 	buf = kmalloc(buf_len, GFP_KERNEL);
-	if (buf == NULL)
+		rtsx_trace(chip);
 	buf[i++] = 0;
 	buf[i++] = 0;
@@ -1067,7 +1083,8 @@ static int read_capacity(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
@@ -1077,8 +1094,10 @@ static int read_capacity(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = kmalloc(8, GFP_KERNEL);
-	if (buf == NULL)
+		rtsx_trace(chip);
 	card_size = get_card_size(chip, lun);
 	buf[0] = (unsigned char)((card_size - 1) >> 24);
@@ -1116,15 +1135,18 @@ static int read_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = ((u16)srb->cmnd[4] << 8) | srb->cmnd[5];
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	retval = rtsx_force_power_on(chip, SSC_PDCTL);
 		vfree(buf);
+		rtsx_trace(chip);
 	for (i = 0; i < len; i++) {
@@ -1133,7 +1155,8 @@ static int read_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -1165,7 +1188,8 @@ static int write_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		set_sense_type(chip, SCSI_LUN(srb), SENSE_TYPE_MEDIA_WRITE_ERR);
+		rtsx_trace(chip);
 	if (len == 511) {
@@ -1173,14 +1197,17 @@ static int write_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+			rtsx_trace(chip);
 	} else {
 		len = (unsigned short)min_t(unsigned int, scsi_bufflen(srb),
 					len);
 		buf = vmalloc(len);
-		if (buf == NULL)
+			rtsx_trace(chip);
 		rtsx_stor_get_xfer_buf(buf, len, srb);
 		scsi_set_resid(srb, scsi_bufflen(srb) - len);
@@ -1191,7 +1218,8 @@ static int write_eeprom(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				vfree(buf);
+				rtsx_trace(chip);
@@ -1221,18 +1249,22 @@ static int read_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (addr < 0xFC00) {
+		rtsx_trace(chip);
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 		vfree(buf);
+		rtsx_trace(chip);
@@ -1241,7 +1273,8 @@ static int read_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -1274,13 +1307,16 @@ static int write_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	len = (unsigned short)min_t(unsigned int, scsi_bufflen(srb), len);
 	buf = vmalloc(len);
-	if (buf == NULL)
+		rtsx_trace(chip);
@@ -1289,7 +1325,8 @@ static int write_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		vfree(buf);
+		rtsx_trace(chip);
@@ -1298,7 +1335,8 @@ static int write_mem(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -1314,12 +1352,14 @@ static int get_sd_csd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	if (get_lun_card(chip, lun) != SD_CARD) {
+		rtsx_trace(chip);
 	scsi_set_resid(srb, 0);
@@ -1361,14 +1401,17 @@ static int trace_msg_cmd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if ((scsi_bufflen(srb) < buf_len) || (scsi_sglist(srb) == NULL)) {
+		rtsx_trace(chip);
 	clear = srb->cmnd[2];
-	if (buf == NULL)
+		rtsx_trace(chip);
 	ptr = buf;
 	if (chip->trace_msg[chip->msg_idx].valid)
@@ -1500,7 +1543,8 @@ static int set_variable(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		default:
+			rtsx_trace(chip);
 	} else if (srb->cmnd[3] == 2) {
 		if (srb->cmnd[4]) {
@@ -1523,14 +1567,16 @@ static int set_variable(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+				rtsx_trace(chip);
 			turn_off_led(chip, LED_GPIO);
 	} else {
+		rtsx_trace(chip);
@@ -1562,7 +1608,8 @@ static int get_variable(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		default:
+			rtsx_trace(chip);
 		rtsx_stor_set_xfer_buf(&tmp, 1, srb);
@@ -1572,7 +1619,8 @@ static int get_variable(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	} else {
+		rtsx_trace(chip);
@@ -1610,7 +1658,8 @@ static int dma_access_ring_buffer(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
@@ -1757,7 +1806,8 @@ static int set_chip_mode(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (!CHECK_PID(chip, 0x5208)) {
+		rtsx_trace(chip);
 	phy_debug_mode = (int)(srb->cmnd[3]);
@@ -1765,35 +1815,47 @@ static int set_chip_mode(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (phy_debug_mode) {
 		chip->phy_debug_mode = 1;
 		retval = rtsx_write_register(chip, CDRESUMECTL, 0x77, 0);
+			rtsx_trace(chip);
 		rtsx_disable_bus_int(chip);
+			rtsx_trace(chip);
 		reg |= 0x0001;
 		retval = rtsx_write_phy_register(chip, 0x1C, reg);
+			rtsx_trace(chip);
 	} else {
 		chip->phy_debug_mode = 0;
 		retval = rtsx_write_register(chip, CDRESUMECTL, 0x77, 0x77);
+			rtsx_trace(chip);
 		rtsx_enable_bus_int(chip);
+			rtsx_trace(chip);
 		reg &= 0xFFFE;
+			rtsx_trace(chip);
@@ -1824,7 +1886,8 @@ static int rw_mem_cmd_buf(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (cmd_type > 2) {
+			rtsx_trace(chip);
 		addr = (srb->cmnd[5] << 8) | srb->cmnd[6];
 		mask = srb->cmnd[7];
@@ -1842,7 +1905,8 @@ static int rw_mem_cmd_buf(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (scsi_bufflen(srb) < 1) {
+			rtsx_trace(chip);
 		rtsx_stor_set_xfer_buf(&value, 1, srb);
@@ -1850,12 +1914,14 @@ static int rw_mem_cmd_buf(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	default:
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -1902,15 +1968,18 @@ static int read_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (len) {
 		buf = vmalloc(len);
-		if (!buf)
+		if (!buf) {
+			rtsx_trace(chip);
 			vfree(buf);
+			rtsx_trace(chip);
 		for (i = 0; i < len / 2; i++) {
@@ -1919,7 +1988,8 @@ static int read_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				vfree(buf);
+				rtsx_trace(chip);
 			buf[2*i] = (u8)(val >> 8);
@@ -1963,8 +2033,10 @@ static int write_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 					len);
 		buf = vmalloc(len);
-		if (buf == NULL)
+			rtsx_trace(chip);
@@ -1974,7 +2046,8 @@ static int write_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -1984,7 +2057,8 @@ static int write_phy_register(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				vfree(buf);
+				rtsx_trace(chip);
@@ -2011,7 +2085,8 @@ static int erase_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	mode = srb->cmnd[3];
@@ -2022,19 +2097,22 @@ static int erase_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+			rtsx_trace(chip);
 	} else if (mode == 1) {
 		retval = spi_erase_eeprom_byte(chip, addr);
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
@@ -2058,15 +2136,18 @@ static int read_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = ((u16)srb->cmnd[6] << 8) | srb->cmnd[7];
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 		vfree(buf);
+		rtsx_trace(chip);
@@ -2075,7 +2156,8 @@ static int read_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -2107,8 +2189,10 @@ static int write_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	buf = vmalloc(len);
-	if (buf == NULL)
+		rtsx_trace(chip);
@@ -2117,7 +2201,8 @@ static int write_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		vfree(buf);
+		rtsx_trace(chip);
@@ -2126,7 +2211,8 @@ static int write_eeprom2(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -2153,15 +2239,18 @@ static int read_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = srb->cmnd[5];
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 		vfree(buf);
+		rtsx_trace(chip);
@@ -2170,7 +2259,8 @@ static int read_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			vfree(buf);
+			rtsx_trace(chip);
@@ -2203,8 +2293,10 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = (u8)min_t(unsigned int, scsi_bufflen(srb), len);
 	buf = vmalloc(len);
-	if (buf == NULL)
+		rtsx_trace(chip);
@@ -2212,21 +2304,24 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		vfree(buf);
+		rtsx_trace(chip);
 		retval = rtsx_read_phy_register(chip, 0x08, &val);
 			vfree(buf);
+			rtsx_trace(chip);
 		retval = rtsx_write_register(chip, PWR_GATE_CTRL,
 					LDO3318_PWR_MASK, LDO_OFF);
 			vfree(buf);
+			rtsx_trace(chip);
 		wait_timeout(600);
@@ -2235,14 +2330,16 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 						0x4C00 | chip->phy_voltage);
 			vfree(buf);
+			rtsx_trace(chip);
 					LDO3318_PWR_MASK, LDO_ON);
 			vfree(buf);
+			rtsx_trace(chip);
 		wait_timeout(600);
@@ -2251,7 +2348,8 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	retval = card_power_on(chip, SPI_CARD);
 		vfree(buf);
+		rtsx_trace(chip);
 	wait_timeout(50);
@@ -2262,7 +2360,8 @@ static int write_efuse(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			result = TRANSPORT_FAILED;
+			rtsx_trace(chip);
+			goto Exit;
@@ -2270,25 +2369,33 @@ Exit:
 	vfree(buf);
 	retval = card_power_off(chip, SPI_CARD);
+		rtsx_trace(chip);
+			rtsx_trace(chip);
 		wait_timeout(600);
 		retval = rtsx_write_phy_register(chip, 0x08, val);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 	return result;
@@ -2325,19 +2432,23 @@ static int read_cfg_byte(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (func > func_max) {
+		rtsx_trace(chip);
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	retval = rtsx_read_cfg_seq(chip, func, addr, buf, len);
 		vfree(buf);
+		rtsx_trace(chip);
 	len = (u16)min_t(unsigned int, scsi_bufflen(srb), len);
@@ -2380,13 +2491,16 @@ static int write_cfg_byte(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	buf = vmalloc(len);
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
@@ -2395,7 +2509,8 @@ static int write_cfg_byte(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		vfree(buf);
+		rtsx_trace(chip);
 	vfree(buf);
@@ -2485,7 +2600,8 @@ static int app_cmd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	default:
+		rtsx_trace(chip);
 	return result;
@@ -2628,7 +2744,8 @@ static int get_card_bus_width(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	card = get_lun_card(chip, lun);
@@ -2636,7 +2753,8 @@ static int get_card_bus_width(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		bus_width = chip->card_bus_width[lun];
 	} else {
+		rtsx_trace(chip);
@@ -2653,7 +2771,8 @@ static int spi_vendor_cmd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (CHECK_PID(chip, 0x5208) || CHECK_PID(chip, 0x5288)) {
+		rtsx_trace(chip);
 	rtsx_disable_aspm(chip);
@@ -2702,13 +2821,16 @@ static int spi_vendor_cmd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		rtsx_write_register(chip, CARD_GPIO_DIR, 0x07, gpio_dir);
+		rtsx_trace(chip);
-	if (result != STATUS_SUCCESS)
+	if (result != STATUS_SUCCESS) {
+		rtsx_trace(chip);
@@ -2767,7 +2889,8 @@ static int vendor_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	default:
+		rtsx_trace(chip);
 	return result;
@@ -2804,14 +2927,16 @@ static int ms_format_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (get_lun_card(chip, lun) != MS_CARD) {
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_LUN_NOT_SUPPORT);
+		rtsx_trace(chip);
 	if ((srb->cmnd[3] != 0x4D) || (srb->cmnd[4] != 0x47) ||
 		(srb->cmnd[5] != 0x66) || (srb->cmnd[6] != 0x6D) ||
 		(srb->cmnd[7] != 0x74)) {
+		rtsx_trace(chip);
@@ -2823,7 +2948,8 @@ static int ms_format_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+			rtsx_trace(chip);
 	rtsx_set_stat(chip, RTSX_STAT_RUN);
@@ -2835,23 +2961,27 @@ static int ms_format_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (!(chip->card_ready & MS_CARD)) {
+		rtsx_trace(chip);
 	if (chip->card_wp & MS_CARD) {
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_WRITE_PROTECT);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	retval = mspro_format(srb, chip, MS_SHORT_DATA_LEN, quick_format);
 		set_sense_type(chip, lun, SENSE_TYPE_FORMAT_CMD_FAILED);
+		rtsx_trace(chip);
@@ -2870,18 +3000,21 @@ static int get_ms_information(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if ((srb->cmnd[2] != 0xB0) || (srb->cmnd[4] != 0x4D) ||
 		(srb->cmnd[5] != 0x53) || (srb->cmnd[6] != 0x49) ||
 		(srb->cmnd[7] != 0x44)) {
+		rtsx_trace(chip);
 	dev_info_id = srb->cmnd[3];
@@ -2889,7 +3022,8 @@ static int get_ms_information(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			(!CHK_MSXC(ms_card) && (dev_info_id == 0x13)) ||
+		rtsx_trace(chip);
 	if (dev_info_id == 0x15)
@@ -2898,8 +3032,10 @@ static int get_ms_information(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		buf_len = data_len = 0x6A;
-	if (!buf)
+	if (!buf) {
+		rtsx_trace(chip);
 	i = 0;
 	/*  GET Memory Stick Media Information Response Header */
@@ -2986,11 +3122,13 @@ static int sd_extention_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	switch (srb->cmnd[0]) {
@@ -3020,7 +3158,8 @@ static int sd_extention_cmnd(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	default:
+		rtsx_trace(chip);
 	return result;
@@ -3047,21 +3186,25 @@ static int mg_report_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (srb->cmnd[7] != KC_MG_R_PRO) {
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	key_format = srb->cmnd[10] & 0x3F;
@@ -3073,13 +3216,16 @@ static int mg_report_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			(srb->cmnd[8] == 0x04) &&
 			(srb->cmnd[9] == 0x1C)) {
 			retval = mg_get_local_EKB(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
@@ -3088,13 +3234,16 @@ static int mg_report_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			(srb->cmnd[8] == 0x00) &&
 			(srb->cmnd[9] == 0x24)) {
 			retval = mg_get_rsp_chg(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
@@ -3108,19 +3257,23 @@ static int mg_report_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			(srb->cmnd[4] == 0x00) &&
 			(srb->cmnd[5] < 32)) {
 			retval = mg_get_ICV(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
 	default:
+		rtsx_trace(chip);
@@ -3146,25 +3299,30 @@ static int mg_send_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	if (check_card_wp(chip, lun)) {
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -3176,13 +3334,16 @@ static int mg_send_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			(srb->cmnd[9] == 0x0C)) {
 			retval = mg_set_leaf_id(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
@@ -3191,13 +3352,16 @@ static int mg_send_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			retval = mg_chg(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
@@ -3206,13 +3370,16 @@ static int mg_send_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			retval = mg_rsp(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
@@ -3226,19 +3393,23 @@ static int mg_send_key(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			retval = mg_set_ICV(srb, chip);
+				rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
 		break;
 	default:
+		rtsx_trace(chip);
@@ -3267,7 +3438,8 @@ int rtsx_scsi_handler(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			/* Logical Unit Not Ready Format in Progress */
 			set_sense_data(chip, lun, CUR_ERR,
 				       0x02, 0, 0x04, 0x04, 0, 0);
+			rtsx_trace(chip);
 #endif
@@ -3279,7 +3451,8 @@ int rtsx_scsi_handler(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			set_sense_data(chip, lun, CUR_ERR, 0x02, 0, 0x04, 0x04,
 					0, (u16)(ms_card->progress));
+			rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/rtsx_transport.c b/drivers/staging/rts5208/rtsx_transport.c
index 03caa9b..f27491e 100644
--- a/drivers/staging/rts5208/rtsx_transport.c
+++ b/drivers/staging/rts5208/rtsx_transport.c
@@ -25,10 +25,6 @@
 #include <linux/sched.h>
 #include "rtsx.h"
-#include "rtsx_scsi.h"
-#include "rtsx_transport.h"
-#include "rtsx_card.h"
  * Scatter-gather transfer buffer access routines
@@ -276,7 +272,8 @@ int rtsx_send_cmd(struct rtsx_chip *chip, u8 card, int timeout)
 		dev_dbg(rtsx_dev(chip), "chip->int_reg = 0x%x\n",
 			chip->int_reg);
 		err = -ETIMEDOUT;
-		TRACE_GOTO(chip, finish_send_cmd);
+		rtsx_trace(chip);
+		goto finish_send_cmd;
 	spin_lock_irq(&rtsx->reg_lock);
diff --git a/drivers/staging/rts5208/sd.c b/drivers/staging/rts5208/sd.c
index a03cbe9..0eee676 100644
--- a/drivers/staging/rts5208/sd.c
+++ b/drivers/staging/rts5208/sd.c
@@ -25,9 +25,6 @@
 #include "rtsx.h"
 #include "sd.h"
 #define SD_MAX_RETRY_COUNT	3
@@ -114,7 +111,8 @@ static int sd_check_data0_status(struct rtsx_chip *chip)
 	if (!(stat & SD_DAT0_STATUS)) {
 		sd_set_err_code(chip, SD_BUSY);
-		TRACE_RET(chip, STATUS_FAIL);
+		rtsx_trace(chip);
+		return STATUS_FAIL;
 	return STATUS_SUCCESS;
@@ -187,7 +185,8 @@ RTY_SEND_CMD:
 				retval = sd_check_data0_status(chip);
 					rtsx_clear_sd_error(chip);
-					TRACE_RET(chip, retval);
+					rtsx_trace(chip);
+					return retval;
 			} else {
 				sd_set_err_code(chip, SD_TO_ERR);
@@ -198,7 +197,8 @@ RTY_SEND_CMD:
+		rtsx_trace(chip);
+		return retval;
 	if (rsp_type == SD_RSP_TYPE_R0)
@@ -208,14 +208,16 @@ RTY_SEND_CMD:
 	if ((ptr[0] & 0xC0) != 0) {
 		sd_set_err_code(chip, SD_STS_ERR);
+		rtsx_trace(chip);
 	if (!(rsp_type & SD_NO_CHECK_CRC7)) {
 		if (ptr[stat_idx] & SD_CRC7_ERR) {
 			if (cmd_idx == WRITE_MULTIPLE_BLOCK) {
 				sd_set_err_code(chip, SD_CRC_ERR);
+				rtsx_trace(chip);
 			if (rty_cnt < SD_MAX_RETRY_COUNT) {
 				wait_timeout(20);
@@ -223,7 +225,8 @@ RTY_SEND_CMD:
 				goto RTY_SEND_CMD;
 			} else {
+				rtsx_trace(chip);
@@ -232,8 +235,10 @@ RTY_SEND_CMD:
 		if ((cmd_idx != SEND_RELATIVE_ADDR) &&
 			(cmd_idx != SEND_IF_COND)) {
 			if (cmd_idx != STOP_TRANSMISSION) {
-				if (ptr[1] & 0x80)
+				if (ptr[1] & 0x80) {
+					rtsx_trace(chip);
 #ifdef SUPPORT_SD_LOCK
 			if (ptr[1] & 0x7D)
@@ -243,17 +248,20 @@ RTY_SEND_CMD:
 				dev_dbg(rtsx_dev(chip), "ptr[1]: 0x%02x\n",
 					ptr[1]);
+				rtsx_trace(chip);
 			if (ptr[2] & 0xFF) {
 				dev_dbg(rtsx_dev(chip), "ptr[2]: 0x%02x\n",
 					ptr[2]);
+				rtsx_trace(chip);
 			if (ptr[3] & 0x80) {
 				dev_dbg(rtsx_dev(chip), "ptr[3]: 0x%02x\n",
 					ptr[3]);
+				rtsx_trace(chip);
 			if (ptr[3] & 0x01)
 				sd_card->sd_data_buf_ready = 1;
@@ -282,8 +290,10 @@ static int sd_read_data(struct rtsx_chip *chip,
 	if (!buf)
 		buf_len = 0;
-	if (buf_len > 512)
+	if (buf_len > 512) {
+		rtsx_trace(chip);
 	rtsx_init_cmd(chip);
@@ -323,13 +333,16 @@ static int sd_read_data(struct rtsx_chip *chip,
 					    SD_RSP_TYPE_R1, NULL, 0);
+		rtsx_trace(chip);
 		retval = rtsx_read_ppbuf(chip, buf, buf_len);
+			rtsx_trace(chip);
@@ -350,13 +363,16 @@ static int sd_write_data(struct rtsx_chip *chip, u8 trans_mode,
 		/* This function can't write data more than one page */
+		rtsx_trace(chip);
 		retval = rtsx_write_ppbuf(chip, buf, buf_len);
+			rtsx_trace(chip);
@@ -395,7 +411,8 @@ static int sd_write_data(struct rtsx_chip *chip, u8 trans_mode,
 				sd_card->sd_addr, SD_RSP_TYPE_R1, NULL, 0);
+		rtsx_trace(chip);
@@ -412,7 +429,8 @@ static int sd_check_csd(struct rtsx_chip *chip, char check_wp)
 	for (i = 0; i < 6; i++) {
 		if (detect_card_cd(chip, SD_CARD) != STATUS_SUCCESS) {
 			sd_set_err_code(chip, SD_NO_CARD);
+			rtsx_trace(chip);
 		retval = sd_send_cmd_get_rsp(chip, SEND_CSD, sd_card->sd_addr,
@@ -421,8 +439,10 @@ static int sd_check_csd(struct rtsx_chip *chip, char check_wp)
 			break;
-	if (i == 6)
+	if (i == 6) {
+		rtsx_trace(chip);
 	memcpy(sd_card->raw_csd, rsp + 1, 15);
@@ -464,10 +484,12 @@ static int sd_check_csd(struct rtsx_chip *chip, char check_wp)
 			else
 				sd_card->sd_clock = CLK_20;
 		} else {
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
 	if (CHK_MMC_SECTOR_MODE(sd_card)) {
@@ -606,14 +628,18 @@ static int sd_set_init_para(struct rtsx_chip *chip)
 	int retval;
 	retval = sd_set_sample_push_timing(chip);
+		rtsx_trace(chip);
 	sd_choose_proper_clock(chip);
 	retval = switch_clock(chip, sd_card->sd_clock);
+		rtsx_trace(chip);
@@ -636,8 +662,10 @@ int sd_select_card(struct rtsx_chip *chip, int select)
 	retval = sd_send_cmd_get_rsp(chip, cmd_idx, addr, cmd_type, NULL, 0);
+		rtsx_trace(chip);
@@ -651,8 +679,10 @@ static int sd_update_lock_status(struct rtsx_chip *chip)
 	retval = sd_send_cmd_get_rsp(chip, SEND_STATUS, sd_card->sd_addr,
 				SD_RSP_TYPE_R1, rsp, 5);
+		rtsx_trace(chip);
 	if (rsp[1] & 0x02)
 		sd_card->sd_lock_status |= SD_LOCKED;
@@ -662,8 +692,10 @@ static int sd_update_lock_status(struct rtsx_chip *chip)
 	dev_dbg(rtsx_dev(chip), "sd_card->sd_lock_status = 0x%x\n",
 		sd_card->sd_lock_status);
-	if (rsp[1] & 0x01)
+	if (rsp[1] & 0x01) {
+		rtsx_trace(chip);
@@ -680,15 +712,18 @@ static int sd_wait_state_data_ready(struct rtsx_chip *chip, u8 state,
 					sd_card->sd_addr, SD_RSP_TYPE_R1, rsp,
 					5);
+			rtsx_trace(chip);
 		if (((rsp[3] & 0x1E) == state) &&
 			((rsp[3] & 0x01) == data_ready))
+	rtsx_trace(chip);
 static int sd_change_bank_voltage(struct rtsx_chip *chip, u8 voltage)
@@ -700,8 +735,10 @@ static int sd_change_bank_voltage(struct rtsx_chip *chip, u8 voltage)
 							0x4FC0 |
 							chip->phy_voltage);
+				rtsx_trace(chip);
 		} else {
 			RTSX_WRITE_REG(chip, SD_PAD_CTL, SD_IO_USING_1V8, 0);
@@ -710,14 +747,17 @@ static int sd_change_bank_voltage(struct rtsx_chip *chip, u8 voltage)
 							0x4C40 |
 							chip->phy_voltage);
+				rtsx_trace(chip);
 		} else {
 				SD_IO_USING_1V8);
 	} else {
+		rtsx_trace(chip);
@@ -733,21 +773,26 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 	retval = sd_send_cmd_get_rsp(chip, VOLTAGE_SWITCH, 0, SD_RSP_TYPE_R1,
 				NULL, 0);
+		rtsx_trace(chip);
 	udelay(chip->sd_voltage_switch_delay);
 	RTSX_READ_REG(chip, SD_BUS_STAT, &stat);
 	if (stat & (SD_CMD_STATUS | SD_DAT3_STATUS | SD_DAT2_STATUS |
 				SD_DAT1_STATUS | SD_DAT0_STATUS)) {
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, SD_BUS_STAT, 0xFF, SD_CLK_FORCE_STOP);
 	retval = sd_change_bank_voltage(chip, SD_IO_1V8);
+		rtsx_trace(chip);
 	wait_timeout(50);
@@ -763,7 +808,8 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 		rtsx_write_register(chip, SD_BUS_STAT,
 				SD_CLK_TOGGLE_EN | SD_CLK_FORCE_STOP, 0);
 		rtsx_write_register(chip, CARD_CLK_EN, 0xFF, 0);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, SD_BUS_STAT, SD_CLK_TOGGLE_EN | SD_CLK_FORCE_STOP,
@@ -839,15 +885,21 @@ static int sd_change_phase(struct rtsx_chip *chip, u8 sample_point, u8 tune_dir)
 		rtsx_add_cmd(chip, CHECK_REG_CMD, SD_DCMPS_CTL,
 			DCMPS_CHANGE_DONE, DCMPS_CHANGE_DONE);
 		retval = rtsx_send_cmd(chip, SD_CARD, 100);
-			TRACE_GOTO(chip, Fail);
+			rtsx_trace(chip);
+			goto Fail;
-		if (val & DCMPS_ERROR)
+		if (val & DCMPS_ERROR) {
+			rtsx_trace(chip);
+			goto Fail;
-		if ((val & DCMPS_CURRENT_PHASE) != sample_point)
+		if ((val & DCMPS_CURRENT_PHASE) != sample_point) {
+			rtsx_trace(chip);
+			goto Fail;
 		RTSX_WRITE_REG(chip, SD_DCMPS_CTL, DCMPS_CHANGE, 0);
 		if (ddr_rx)
@@ -883,8 +935,10 @@ static int sd_check_spec(struct rtsx_chip *chip, u8 bus_width)
 	retval = sd_send_cmd_get_rsp(chip, APP_CMD, sd_card->sd_addr,
+		rtsx_trace(chip);
 	cmd[0] = 0x40 | SEND_SCR;
 	cmd[1] = 0;
@@ -896,13 +950,16 @@ static int sd_check_spec(struct rtsx_chip *chip, u8 bus_width)
 			buf, 8, 250);
+		rtsx_trace(chip);
 	memcpy(sd_card->raw_scr, buf, 8);
-	if ((buf[0] & 0x0F) == 0)
+	if ((buf[0] & 0x0F) == 0) {
+		rtsx_trace(chip);
@@ -944,7 +1001,8 @@ static int sd_query_switch_result(struct rtsx_chip *chip, u8 func_group,
 			break;
 		default:
+			rtsx_trace(chip);
 	} else if (func_group == SD_FUNC_GROUP_3) {
 		support_offset = FUNCTION_GROUP3_SUPPORT_OFFSET;
@@ -971,7 +1029,8 @@ static int sd_query_switch_result(struct rtsx_chip *chip, u8 func_group,
 			break;
 		default:
+			rtsx_trace(chip);
 	} else if (func_group == SD_FUNC_GROUP_4) {
 		support_offset = FUNCTION_GROUP4_SUPPORT_OFFSET;
@@ -998,23 +1057,27 @@ static int sd_query_switch_result(struct rtsx_chip *chip, u8 func_group,
 			break;
 		default:
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
 	if (func_group == SD_FUNC_GROUP_1) {
 		if (!(buf[support_offset] & support_mask) ||
 			((buf[query_switch_offset] & 0x0F) != query_switch)) {
+			rtsx_trace(chip);
 	/* Check 'Busy Status' */
 	if ((buf[DATA_STRUCTURE_VER_OFFSET] == 0x01) &&
 		    ((buf[check_busy_offset] & switch_busy) == switch_busy)) {
+		rtsx_trace(chip);
@@ -1056,7 +1119,8 @@ static int sd_check_switch_mode(struct rtsx_chip *chip, u8 mode,
 			buf, 64, 250);
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "%*ph\n", 64, buf);
@@ -1083,13 +1147,17 @@ static int sd_check_switch_mode(struct rtsx_chip *chip, u8 mode,
 		dev_dbg(rtsx_dev(chip), "Maximum current consumption: %dmA\n",
 			cc);
-		if ((cc == 0) || (cc > 800))
+		if ((cc == 0) || (cc > 800)) {
+			rtsx_trace(chip);
 		retval = sd_query_switch_result(chip, func_group,
 						func_to_switch, buf, 64);
+			rtsx_trace(chip);
 		if ((cc > 400) || (func_to_switch > CURRENT_LIMIT_400)) {
 			RTSX_WRITE_REG(chip, OCPPARA2, SD_OCP_THD_MASK,
@@ -1126,7 +1194,8 @@ static int sd_check_switch(struct rtsx_chip *chip,
 	for (i = 0; i < 3; i++) {
+			rtsx_trace(chip);
 		retval = sd_check_switch_mode(chip, SD_CHECK_MODE, func_group,
@@ -1144,7 +1213,8 @@ static int sd_check_switch(struct rtsx_chip *chip,
 			RTSX_READ_REG(chip, SD_STAT1, &stat);
 			if (stat & SD_CRC16_ERR) {
 				dev_dbg(rtsx_dev(chip), "SD CRC16 error when switching mode\n");
+				rtsx_trace(chip);
@@ -1154,8 +1224,10 @@ static int sd_check_switch(struct rtsx_chip *chip,
 		wait_timeout(20);
-	if (!switch_good)
+	if (!switch_good) {
+		rtsx_trace(chip);
@@ -1170,8 +1242,10 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 	/* Get supported functions */
 			NO_ARGUMENT, NO_ARGUMENT, bus_width);
+		rtsx_trace(chip);
 	sd_card->func_group1_mask &= ~(sd_card->sd_switch_fail);
@@ -1239,7 +1313,8 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 				sd_card->sd_switch_fail = SDR104_SUPPORT_MASK |
 					DDR50_SUPPORT_MASK | SDR50_SUPPORT_MASK;
+			rtsx_trace(chip);
 		if (func_to_switch == SDR104_SUPPORT)
@@ -1255,8 +1330,10 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 	if (CHK_SD_DDR50(sd_card)) {
 		RTSX_WRITE_REG(chip, SD_PUSH_POINT_CTL, 0x06, 0x04);
+			rtsx_trace(chip);
 	if (!func_to_switch || (func_to_switch == HS_SUPPORT)) {
@@ -1310,8 +1387,10 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 		retval = sd_check_switch(chip, SD_FUNC_GROUP_4, func_to_switch,
 					bus_width);
-			if (sd_check_err_code(chip, SD_NO_CARD))
+			if (sd_check_err_code(chip, SD_NO_CARD)) {
+				rtsx_trace(chip);
 		dev_dbg(rtsx_dev(chip), "Switch current limit finished! (%d)\n",
 			retval);
@@ -1348,8 +1427,10 @@ static int sd_sdr_tuning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
 	u8 cmd[5];
 	retval = sd_change_phase(chip, sample_point, TUNE_RX);
+		rtsx_trace(chip);
 	cmd[0] = 0x40 | SEND_TUNING_PATTERN;
 	cmd[1] = 0;
@@ -1363,7 +1444,8 @@ static int sd_sdr_tuning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		(void)sd_wait_data_idle(chip);
+		rtsx_trace(chip);
@@ -1376,15 +1458,19 @@ static int sd_ddr_tuning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
 	u8 cmd[5];
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "sd ddr tuning rx\n");
+		rtsx_trace(chip);
 	cmd[0] = 0x40 | SD_STATUS;
 	cmd[1] = 0;
@@ -1398,7 +1484,8 @@ static int sd_ddr_tuning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
+		rtsx_trace(chip);
@@ -1418,8 +1505,10 @@ static int mmc_ddr_tunning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		bus_width = SD_BUS_WIDTH_1;
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "mmc ddr tuning rx\n");
@@ -1435,7 +1524,8 @@ static int mmc_ddr_tunning_rx_cmd(struct rtsx_chip *chip, u8 sample_point)
+		rtsx_trace(chip);
@@ -1447,8 +1537,10 @@ static int sd_sdr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 	int retval;
 	retval = sd_change_phase(chip, sample_point, TUNE_TX);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN,
 		SD_RSP_80CLK_TIMEOUT_EN);
@@ -1459,7 +1551,8 @@ static int sd_sdr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		if (sd_check_err_code(chip, SD_RSP_TIMEOUT)) {
 			rtsx_write_register(chip, SD_CFG3,
 					SD_RSP_80CLK_TIMEOUT_EN, 0);
+			rtsx_trace(chip);
@@ -1475,8 +1568,10 @@ static int sd_ddr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 	u8 cmd[5], bus_width;
+		rtsx_trace(chip);
 	if (CHK_SD(sd_card)) {
 		bus_width = SD_BUS_WIDTH_4;
@@ -1490,8 +1585,10 @@ static int sd_ddr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 	retval = sd_wait_state_data_ready(chip, 0x08, 1, 1000);
+		rtsx_trace(chip);
@@ -1507,7 +1604,8 @@ static int sd_ddr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		rtsx_write_register(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN, 0);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN, 0);
@@ -1655,8 +1753,10 @@ static int sd_tuning_rx(struct rtsx_chip *chip)
 	} else {
 		if (CHK_MMC_DDR52(sd_card))
 			tuning_cmd = mmc_ddr_tunning_rx_cmd;
-		else
+		else {
+			rtsx_trace(chip);
@@ -1664,7 +1764,8 @@ static int sd_tuning_rx(struct rtsx_chip *chip)
 		for (j = MAX_PHASE; j >= 0; j--) {
+				rtsx_trace(chip);
 			retval = tuning_cmd(chip, (u8)j);
@@ -1681,12 +1782,16 @@ static int sd_tuning_rx(struct rtsx_chip *chip)
 	dev_dbg(rtsx_dev(chip), "RX phase_map = 0x%08x\n", phase_map);
 	final_phase = sd_search_final_phase(chip, phase_map, TUNE_RX);
-	if (final_phase == 0xFF)
+	if (final_phase == 0xFF) {
+		rtsx_trace(chip);
 	retval = sd_change_phase(chip, final_phase, TUNE_RX);
+		rtsx_trace(chip);
@@ -1708,7 +1813,8 @@ static int sd_ddr_pre_tuning_tx(struct rtsx_chip *chip)
+			rtsx_trace(chip);
 		retval = sd_change_phase(chip, (u8)i, TUNE_TX);
@@ -1729,12 +1835,16 @@ static int sd_ddr_pre_tuning_tx(struct rtsx_chip *chip)
 		phase_map);
 	final_phase = sd_search_final_phase(chip, phase_map, TUNE_TX);
+		rtsx_trace(chip);
 	retval = sd_change_phase(chip, final_phase, TUNE_TX);
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "DDR TX pre tune phase: %d\n",
 		(int)final_phase);
@@ -1760,8 +1870,10 @@ static int sd_tuning_tx(struct rtsx_chip *chip)
 	} else {
 			tuning_cmd = sd_ddr_tuning_tx_cmd;
-		else
+		else {
+			rtsx_trace(chip);
@@ -1771,7 +1883,8 @@ static int sd_tuning_tx(struct rtsx_chip *chip)
+				rtsx_trace(chip);
@@ -1788,12 +1901,16 @@ static int sd_tuning_tx(struct rtsx_chip *chip)
 	dev_dbg(rtsx_dev(chip), "TX phase_map = 0x%08x\n", phase_map);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -1803,12 +1920,16 @@ static int sd_sdr_tuning(struct rtsx_chip *chip)
 	int retval;
 	retval = sd_tuning_tx(chip);
+		rtsx_trace(chip);
 	retval = sd_tuning_rx(chip);
+		rtsx_trace(chip);
@@ -1819,23 +1940,31 @@ static int sd_ddr_tuning(struct rtsx_chip *chip)
 	if (!(chip->sd_ctl & SD_DDR_TX_PHASE_SET_BY_USER)) {
 		retval = sd_ddr_pre_tuning_tx(chip);
+			rtsx_trace(chip);
 	} else {
 		retval = sd_change_phase(chip, (u8)chip->sd_ddr_tx_phase,
 					TUNE_TX);
+			rtsx_trace(chip);
+		rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -1847,23 +1976,31 @@ static int mmc_ddr_tuning(struct rtsx_chip *chip)
 	if (!(chip->sd_ctl & MMC_DDR_TX_PHASE_SET_BY_USER)) {
+			rtsx_trace(chip);
 	} else {
 		retval = sd_change_phase(chip, (u8)chip->mmc_ddr_tx_phase,
 					TUNE_TX);
+			rtsx_trace(chip);
+		rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -1876,12 +2013,16 @@ int sd_switch_clock(struct rtsx_chip *chip)
 	int re_tuning = 0;
 	retval = select_card(chip, SD_CARD);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (re_tuning) {
@@ -1894,8 +2035,10 @@ int sd_switch_clock(struct rtsx_chip *chip)
 				retval = mmc_ddr_tuning(chip);
+			rtsx_trace(chip);
@@ -1925,8 +2068,10 @@ static int sd_prepare_reset(struct rtsx_chip *chip)
 	chip->sd_io = 0;
 	retval = sd_set_init_para(chip);
+		rtsx_trace(chip);
+		return retval;
 	RTSX_WRITE_REG(chip, REG_SD_CFG1, 0xFF, 0x40);
@@ -1934,8 +2079,10 @@ static int sd_prepare_reset(struct rtsx_chip *chip)
 		SD_STOP | SD_CLR_ERR);
+		rtsx_trace(chip);
@@ -1999,8 +2146,10 @@ int sd_pull_ctl_enable(struct rtsx_chip *chip)
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -2010,20 +2159,26 @@ static int sd_init_power(struct rtsx_chip *chip)
 	int retval;
 	retval = sd_power_off_card3v3(chip);
+		rtsx_trace(chip);
 	if (!chip->ft2_fast_mode)
 		wait_timeout(250);
 	retval = enable_card_clock(chip, SD_CARD);
+		rtsx_trace(chip);
 	if (chip->asic_code) {
+			rtsx_trace(chip);
 	} else {
 		RTSX_WRITE_REG(chip, FPGA_PULL_CTL, FPGA_SD_PULL_CTL_BIT | 0x20,
 			0);
@@ -2031,8 +2186,10 @@ static int sd_init_power(struct rtsx_chip *chip)
 	if (!chip->ft2_fast_mode) {
 		retval = card_power_on(chip, SD_CARD);
+			rtsx_trace(chip);
 		wait_timeout(260);
@@ -2040,7 +2197,8 @@ static int sd_init_power(struct rtsx_chip *chip)
 		if (chip->ocp_stat & (SD_OC_NOW | SD_OC_EVER)) {
 			dev_dbg(rtsx_dev(chip), "Over current, OCPSTAT is 0x%x\n",
 				chip->ocp_stat);
+			rtsx_trace(chip);
 #endif
@@ -2086,7 +2244,8 @@ static int sd_read_lba0(struct rtsx_chip *chip)
 		5, 512, 1, bus_width, NULL, 0, 100);
+		rtsx_trace(chip);
@@ -2102,8 +2261,10 @@ static int sd_check_wp_state(struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	cmd[1] = 0;
@@ -2118,7 +2279,8 @@ static int sd_check_wp_state(struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "ACMD13:\n");
@@ -2167,12 +2329,16 @@ Switch_Fail:
 #endif
 	retval = sd_prepare_reset(chip);
+		rtsx_trace(chip);
 	retval = sd_dummy_clock(chip);
+		rtsx_trace(chip);
 	if (CHK_SDIO_EXIST(chip) && !CHK_SDIO_IGNORED(chip) && try_sdio) {
 		int rty_cnt = 0;
@@ -2180,7 +2346,8 @@ Switch_Fail:
 		for (; rty_cnt < chip->sdio_retry_cnt; rty_cnt++) {
+				rtsx_trace(chip);
 			retval = sd_send_cmd_get_rsp(chip, IO_SEND_OP_COND, 0,
@@ -2192,7 +2359,8 @@ Switch_Fail:
 					dev_dbg(rtsx_dev(chip), "SD_IO card (Function number: %d)!\n",
 						func_num);
 					chip->sd_io = 1;
+					rtsx_trace(chip);
 				break;
@@ -2210,8 +2378,10 @@ Switch_Fail:
 RTY_SD_RST:
 	retval = sd_send_cmd_get_rsp(chip, GO_IDLE_STATE, 0, SD_RSP_TYPE_R0,
 				NULL, 0);
+		rtsx_trace(chip);
 	wait_timeout(20);
@@ -2229,8 +2399,10 @@ RTY_SD_RST:
 					SD_RSP_TYPE_R0, NULL, 0);
+			rtsx_trace(chip);
 		wait_timeout(20);
@@ -2241,14 +2413,17 @@ RTY_SD_RST:
+				rtsx_trace(chip);
 			j++;
 			if (j < 3)
 				goto RTY_SD_RST;
-			else
+			else {
+				rtsx_trace(chip);
 		retval = sd_send_cmd_get_rsp(chip, SD_APP_OP_COND, voltage,
@@ -2257,16 +2432,20 @@ RTY_SD_RST:
 			k++;
 			if (k < 3)
 				goto RTY_SD_RST;
-			else
+			else {
+				rtsx_trace(chip);
 		i++;
 		wait_timeout(20);
 	} while (!(rsp[1] & 0x80) && (i < 255));
-	if (i == 255)
+	if (i == 255) {
+		rtsx_trace(chip);
 	if (hi_cap_flow) {
 		if (rsp[1] & 0x40)
@@ -2283,20 +2462,26 @@ RTY_SD_RST:
 	if (support_1v8) {
 		retval = sd_voltage_switch(chip);
+			rtsx_trace(chip);
 	retval = sd_send_cmd_get_rsp(chip, ALL_SEND_CID, 0, SD_RSP_TYPE_R2,
 				NULL, 0);
+		rtsx_trace(chip);
 		retval = sd_send_cmd_get_rsp(chip, SEND_RELATIVE_ADDR, 0,
 					SD_RSP_TYPE_R6, rsp, 5);
+			rtsx_trace(chip);
 		sd_card->sd_addr = (u32)rsp[1] << 24;
 		sd_card->sd_addr += (u32)rsp[2] << 16;
@@ -2306,18 +2491,24 @@ RTY_SD_RST:
 	retval = sd_check_csd(chip, 1);
+		rtsx_trace(chip);
 	retval = sd_select_card(chip, 1);
+		rtsx_trace(chip);
 SD_UNLOCK_ENTRY:
 	retval = sd_update_lock_status(chip);
+		rtsx_trace(chip);
 	if (sd_card->sd_lock_status & SD_LOCKED) {
 		sd_card->sd_lock_status |= (SD_LOCK_1BIT_MODE | SD_PWD_EXIST);
@@ -2329,24 +2520,32 @@ SD_UNLOCK_ENTRY:
+		rtsx_trace(chip);
 	retval = sd_send_cmd_get_rsp(chip, SET_CLR_CARD_DETECT, 0,
+		rtsx_trace(chip);
 	if (support_1v8) {
+			rtsx_trace(chip);
 		retval = sd_send_cmd_get_rsp(chip, SET_BUS_WIDTH, 2,
+			rtsx_trace(chip);
 		switch_bus_width = SD_BUS_WIDTH_4;
 	} else {
@@ -2355,12 +2554,16 @@ SD_UNLOCK_ENTRY:
 	retval = sd_send_cmd_get_rsp(chip, SET_BLOCKLEN, 0x200, SD_RSP_TYPE_R1,
 				NULL, 0);
+		rtsx_trace(chip);
 	retval = sd_set_clock_divider(chip, SD_CLK_DIVIDE_0);
+		rtsx_trace(chip);
 	if (!(sd_card->raw_csd[4] & 0x40))
 		sd_dont_switch = true;
@@ -2399,13 +2602,17 @@ SD_UNLOCK_ENTRY:
 	if (!support_1v8) {
+			rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -2419,8 +2626,10 @@ SD_UNLOCK_ENTRY:
 			chip->sd30_drive_sel_1v8);
+			rtsx_trace(chip);
 			retval = sd_ddr_tuning(chip);
@@ -2429,11 +2638,14 @@ SD_UNLOCK_ENTRY:
 			if (sd20_mode) {
+				rtsx_trace(chip);
 			} else {
 				retval = sd_init_power(chip);
+					rtsx_trace(chip);
 				try_sdio = false;
 				sd20_mode = true;
@@ -2454,11 +2666,14 @@ SD_UNLOCK_ENTRY:
 			retval = sd_read_lba0(chip);
 				if (sd20_mode) {
+					rtsx_trace(chip);
 				} else {
+						rtsx_trace(chip);
 					try_sdio = false;
 					sd20_mode = true;
@@ -2469,8 +2684,10 @@ SD_UNLOCK_ENTRY:
 	retval = sd_check_wp_state(chip);
+		rtsx_trace(chip);
 	chip->card_bus_width[chip->card2lun[SD_CARD]] = 4;
@@ -2495,8 +2712,10 @@ static int mmc_test_switch_bus(struct rtsx_chip *chip, u8 width)
 	retval = sd_send_cmd_get_rsp(chip, BUSTEST_W, 0, SD_RSP_TYPE_R1, NULL,
 				0);
-		TRACE_RET(chip, SWITCH_FAIL);
+		rtsx_trace(chip);
+		return SWITCH_FAIL;
 	if (width == MMC_8BIT_BUS) {
 		buf[0] = 0x55;
@@ -2512,20 +2731,25 @@ static int mmc_test_switch_bus(struct rtsx_chip *chip, u8 width)
 	retval = rtsx_write_register(chip, REG_SD_CFG3, 0x02, 0x02);
-		TRACE_RET(chip, SWITCH_ERR);
+		rtsx_trace(chip);
+		return SWITCH_ERR;
 	retval = sd_write_data(chip, SD_TM_AUTO_WRITE_3,
 			NULL, 0, byte_cnt, 1, bus_width, buf, len, 100);
 		rtsx_write_register(chip, REG_SD_CFG3, 0x02, 0);
+		rtsx_trace(chip);
 	retval = rtsx_write_register(chip, REG_SD_CFG3, 0x02, 0);
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "SD/MMC CMD %d\n", BUSTEST_R);
@@ -2560,7 +2784,8 @@ static int mmc_test_switch_bus(struct rtsx_chip *chip, u8 width)
 	if (retval < 0) {
+		rtsx_trace(chip);
 	ptr = rtsx_get_cmd_data(chip) + 1;
@@ -2602,7 +2827,8 @@ static int mmc_test_switch_bus(struct rtsx_chip *chip, u8 width)
+	rtsx_trace(chip);
@@ -2653,14 +2879,16 @@ static int mmc_switch_timing_bus(struct rtsx_chip *chip, bool switch_ddr)
+		rtsx_trace(chip);
 	ptr = rtsx_get_cmd_data(chip);
 	if (ptr[0] & SD_TRANSFER_ERR) {
+		rtsx_trace(chip);
@@ -2692,8 +2920,10 @@ static int mmc_switch_timing_bus(struct rtsx_chip *chip, bool switch_ddr)
+		rtsx_trace(chip);
 	/* Test Bus Procedure */
 	retval = mmc_test_switch_bus(chip, MMC_8BIT_BUS);
@@ -2715,10 +2945,12 @@ static int mmc_switch_timing_bus(struct rtsx_chip *chip, bool switch_ddr)
 			CLR_MMC_8BIT(sd_card);
 			CLR_MMC_4BIT(sd_card);
 		} else {
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
@@ -2741,21 +2973,26 @@ static int reset_mmc(struct rtsx_chip *chip)
 Switch_Fail:
+		rtsx_trace(chip);
+		return retval;
 	SET_MMC(sd_card);
 RTY_MMC_RST:
 				NULL, 0);
+		rtsx_trace(chip);
 	do {
+			rtsx_trace(chip);
 		retval = sd_send_cmd_get_rsp(chip, SEND_OP_COND,
@@ -2769,7 +3006,8 @@ RTY_MMC_RST:
 					sd_clr_err_code(chip);
 					goto RTY_MMC_RST;
 				} else {
+					rtsx_trace(chip);
 			} else {
 				j++;
@@ -2777,7 +3015,8 @@ RTY_MMC_RST:
 					goto RTY_MMC_RST;
 				} else {
+					rtsx_trace(chip);
@@ -2786,8 +3025,10 @@ RTY_MMC_RST:
 		i++;
-	if (i == 255)
+	if (i == 255) {
+		rtsx_trace(chip);
 	if ((rsp[1] & 0x60) == 0x40)
 		SET_MMC_SECTOR_MODE(sd_card);
@@ -2796,40 +3037,54 @@ RTY_MMC_RST:
 				NULL, 0);
+		rtsx_trace(chip);
 	sd_card->sd_addr = 0x00100000;
 	retval = sd_send_cmd_get_rsp(chip, SET_RELATIVE_ADDR, sd_card->sd_addr,
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	spec_ver = (sd_card->raw_csd[0] & 0x3C) >> 2;
+		rtsx_trace(chip);
 				NULL, 0);
+		rtsx_trace(chip);
 MMC_UNLOCK_ENTRY:
+		rtsx_trace(chip);
 #endif
+		rtsx_trace(chip);
 	chip->card_bus_width[chip->card2lun[SD_CARD]] = 1;
@@ -2839,29 +3094,39 @@ MMC_UNLOCK_ENTRY:
 			retval = mmc_switch_timing_bus(chip, switch_ddr);
+					rtsx_trace(chip);
 				sd_card->mmc_dont_switch_bus = 1;
-				TRACE_GOTO(chip, Switch_Fail);
+				rtsx_trace(chip);
+				goto Switch_Fail;
-		if (CHK_MMC_SECTOR_MODE(sd_card) && (sd_card->capacity == 0))
+		if (CHK_MMC_SECTOR_MODE(sd_card) && (sd_card->capacity == 0)) {
+			rtsx_trace(chip);
 		if (switch_ddr && CHK_MMC_DDR52(sd_card)) {
+				rtsx_trace(chip);
+					rtsx_trace(chip);
 				switch_ddr = false;
+				rtsx_trace(chip);
+				goto Switch_Fail;
@@ -2869,11 +3134,14 @@ MMC_UNLOCK_ENTRY:
+						rtsx_trace(chip);
 					switch_ddr = false;
+					rtsx_trace(chip);
+					goto Switch_Fail;
@@ -2904,62 +3172,84 @@ int reset_sd_card(struct rtsx_chip *chip)
 	chip->capacity[chip->card2lun[SD_CARD]] = 0;
+		rtsx_trace(chip);
 	if (chip->ignore_sd && CHK_SDIO_EXIST(chip) &&
 		!CHK_SDIO_IGNORED(chip)) {
+				rtsx_trace(chip);
 		} else {
 			retval = rtsx_write_register(chip, FPGA_PULL_CTL,
+				rtsx_trace(chip);
+			rtsx_trace(chip);
 		chip->sd_io = 1;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (chip->sd_ctl & RESET_MMC_FIRST) {
 		retval = reset_mmc(chip);
+				rtsx_trace(chip);
 			retval = reset_sd(chip);
+				rtsx_trace(chip);
 	} else {
+				rtsx_trace(chip);
 			if (chip->sd_io) {
+				rtsx_trace(chip);
 			} else {
+					rtsx_trace(chip);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, REG_SD_BYTE_CNT_L, 0xFF, 0);
 	RTSX_WRITE_REG(chip, REG_SD_BYTE_CNT_H, 0xFF, 2);
@@ -2967,8 +3257,10 @@ int reset_sd_card(struct rtsx_chip *chip)
 	chip->capacity[chip->card2lun[SD_CARD]] = sd_card->capacity;
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "sd_card->sd_type = 0x%x\n", sd_card->sd_type);
@@ -2994,20 +3286,28 @@ static int reset_mmc_only(struct rtsx_chip *chip)
 	chip->capacity[chip->card2lun[SD_CARD]] = sd_card->capacity = 0;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -3015,8 +3315,10 @@ static int reset_mmc_only(struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "In reset_mmc_only, sd_card->sd_type = 0x%x\n",
 		sd_card->sd_type);
@@ -3034,15 +3336,18 @@ static int wait_data_buf_ready(struct rtsx_chip *chip)
 	for (i = 0; i < WAIT_DATA_READY_RTY_CNT; i++) {
+			rtsx_trace(chip);
 		sd_card->sd_data_buf_ready = 0;
+			rtsx_trace(chip);
 		if (sd_card->sd_data_buf_ready) {
 			return sd_send_cmd_get_rsp(chip, SEND_STATUS,
@@ -3052,7 +3357,8 @@ static int wait_data_buf_ready(struct rtsx_chip *chip)
+	rtsx_trace(chip);
 void sd_stop_seq_mode(struct rtsx_chip *chip)
@@ -3120,8 +3426,10 @@ static inline int sd_auto_tune_clock(struct rtsx_chip *chip)
 	retval = sd_switch_clock(chip);
+		rtsx_trace(chip);
@@ -3158,7 +3466,8 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
 			chip->card_fail |= SD_CARD;
 			chip->rw_need_retry = 1;
+			rtsx_trace(chip);
@@ -3172,7 +3481,8 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
 		sd_set_err_code(chip, SD_IO_ERR);
-		TRACE_GOTO(chip, RW_FAIL);
+		rtsx_trace(chip);
+		goto RW_FAIL;
 	if (sd_card->seq_mode &&
@@ -3193,7 +3503,8 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
+			rtsx_trace(chip);
+			goto RW_FAIL;
 		sd_card->seq_mode = 0;
@@ -3201,7 +3512,8 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
 		retval = rtsx_write_register(chip, RBCTL, RB_FLUSH, RB_FLUSH);
+			rtsx_trace(chip);
+			goto RW_FAIL;
 		if ((sd_card->pre_sec_cnt < 0x80)
@@ -3292,21 +3604,24 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
+				rtsx_trace(chip);
+				goto RW_FAIL;
 			retval = wait_data_buf_ready(chip);
+				rtsx_trace(chip);
+				goto RW_FAIL;
 			retval = sd_send_cmd_get_rsp(chip, WRITE_MULTIPLE_BLOCK,
 					data_addr, SD_RSP_TYPE_R1, NULL, 0);
+				rtsx_trace(chip);
+				goto RW_FAIL;
@@ -3350,7 +3665,8 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
 			chip->rw_need_retry = 0;
 			dev_dbg(rtsx_dev(chip), "No card exist, exit sd_rw\n");
+			rtsx_trace(chip);
@@ -3359,21 +3675,25 @@ int sd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip, u32 start_sector,
 					SD_RSP_TYPE_R1b, NULL, 0);
+			rtsx_trace(chip);
+			goto RW_FAIL;
 		if (stat & (SD_CRC7_ERR | SD_CRC16_ERR | SD_CRC_WRITE_ERR)) {
 			dev_dbg(rtsx_dev(chip), "SD CRC error, tune clock!\n");
+			rtsx_trace(chip);
+			goto RW_FAIL;
 		if (err == STATUS_TIMEDOUT) {
+			rtsx_trace(chip);
+			goto RW_FAIL;
-		TRACE_RET(chip, err);
+		rtsx_trace(chip);
+		return err;
 	sd_card->pre_sec_addr = start_sector;
@@ -3388,7 +3708,8 @@ RW_FAIL:
+		rtsx_trace(chip);
 	if (sd_check_err_code(chip, SD_CRC_ERR)) {
@@ -3409,7 +3730,8 @@ RW_FAIL:
+	rtsx_trace(chip);
 #ifdef SUPPORT_CPRM
@@ -3475,13 +3797,16 @@ RTY_SEND_CMD:
 			if (rsp_type & SD_WAIT_BUSY_END) {
+					rtsx_trace(chip);
+					return retval;
 			} else {
+		rtsx_trace(chip);
@@ -3491,14 +3816,16 @@ RTY_SEND_CMD:
+		rtsx_trace(chip);
+				rtsx_trace(chip);
 				wait_timeout(20);
@@ -3506,7 +3833,8 @@ RTY_SEND_CMD:
 				goto RTY_SEND_CMD;
 			} else {
+				rtsx_trace(chip);
@@ -3514,8 +3842,10 @@ RTY_SEND_CMD:
 	if ((cmd_idx == SELECT_CARD) || (cmd_idx == APP_CMD) ||
 		(cmd_idx == SEND_STATUS) || (cmd_idx == STOP_TRANSMISSION)) {
 		if ((cmd_idx != STOP_TRANSMISSION) && !special_check) {
+				rtsx_trace(chip);
 		if (ptr[1] & 0x7D)
@@ -3523,19 +3853,26 @@ RTY_SEND_CMD:
 		if (ptr[1] & 0x7F)
 #endif
+			rtsx_trace(chip);
+		if (ptr[2] & 0xF8) {
+			rtsx_trace(chip);
-		if (ptr[2] & 0xF8)
 		if (cmd_idx == SELECT_CARD) {
 			if (rsp_type == SD_RSP_TYPE_R2) {
-				if ((ptr[3] & 0x1E) != 0x04)
+				if ((ptr[3] & 0x1E) != 0x04) {
+					rtsx_trace(chip);
 			} else if (rsp_type == SD_RSP_TYPE_R0) {
-				if ((ptr[3] & 0x1E) != 0x03)
+				if ((ptr[3] & 0x1E) != 0x03) {
+					rtsx_trace(chip);
@@ -3572,8 +3909,10 @@ int ext_sd_get_rsp(struct rtsx_chip *chip, int len, u8 *rsp, u8 rsp_type)
 	rtsx_add_cmd(chip, READ_REG_CMD, REG_SD_CMD5, 0xFF, 0);
+		rtsx_trace(chip);
 	if (rsp) {
 		int min_len = (rsp_len < len) ? rsp_len : len;
@@ -3619,7 +3958,8 @@ int sd_pass_thru_mode(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		SET_BIT(chip->lun_mc, lun);
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_CHANGE);
+		rtsx_trace(chip);
 	if ((0x53 != srb->cmnd[2]) || (0x44 != srb->cmnd[3]) ||
@@ -3627,7 +3967,8 @@ int sd_pass_thru_mode(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		(0x61 != srb->cmnd[6]) || (0x72 != srb->cmnd[7]) ||
 		(0x64 != srb->cmnd[8])) {
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_INVALID_CMD_FIELD);
+		rtsx_trace(chip);
 	switch (srb->cmnd[1] & 0x0F) {
@@ -3641,7 +3982,8 @@ int sd_pass_thru_mode(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	default:
+		rtsx_trace(chip);
 	buf[5] = (1 == CHK_SD(sd_card)) ?  0x01 : 0x02;
@@ -3709,17 +4051,21 @@ int sd_execute_no_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (!sd_card->sd_pass_thru_en) {
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (sd_card->pre_cmd_err) {
 		sd_card->pre_cmd_err = 0;
+		rtsx_trace(chip);
 	cmd_idx = srb->cmnd[2] & 0x3F;
@@ -3735,64 +4081,83 @@ int sd_execute_no_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	retval = get_rsp_type(srb, &rsp_type, &rsp_len);
+		rtsx_trace(chip);
 	sd_card->last_rsp_type = rsp_type;
+		rtsx_trace(chip);
 	if ((sd_card->sd_lock_status & SD_LOCK_1BIT_MODE) == 0) {
 		if (CHK_MMC_8BIT(sd_card)) {
 			retval = rtsx_write_register(chip, REG_SD_CFG1, 0x03,
 						SD_BUS_WIDTH_8);
+				rtsx_trace(chip);
 		} else if (CHK_SD(sd_card) || CHK_MMC_4BIT(sd_card)) {
 						SD_BUS_WIDTH_4);
+				rtsx_trace(chip);
 #else
 	retval = rtsx_write_register(chip, REG_SD_CFG1, 0x03, SD_BUS_WIDTH_4);
+		rtsx_trace(chip);
 #endif
 	if (standby) {
 		retval = sd_select_card(chip, 0);
-			TRACE_GOTO(chip, SD_Execute_Cmd_Failed);
+			rtsx_trace(chip);
+			goto SD_Execute_Cmd_Failed;
 	if (acmd) {
 		retval = ext_sd_send_cmd_get_rsp(chip, APP_CMD,
 						sd_card->sd_addr,
 						SD_RSP_TYPE_R1, NULL, 0, false);
+			rtsx_trace(chip);
 	retval = ext_sd_send_cmd_get_rsp(chip, cmd_idx, arg, rsp_type,
 			sd_card->rsp, rsp_len, false);
+		rtsx_trace(chip);
 	if (standby) {
+			rtsx_trace(chip);
+		rtsx_trace(chip);
 #endif
@@ -3806,7 +4171,8 @@ SD_Execute_Cmd_Failed:
 	if (!(chip->card_ready & SD_CARD))
 		set_sense_type(chip, lun, SENSE_TYPE_MEDIA_NOT_PRESENT);
+	rtsx_trace(chip);
 int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
@@ -3821,18 +4187,22 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	if (srb->cmnd[1] & 0x04)
@@ -3850,13 +4220,16 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -3877,22 +4250,28 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (data_len < 512) {
 		retval = ext_sd_send_cmd_get_rsp(chip, SET_BLOCKLEN, data_len,
-			TRACE_GOTO(chip, SD_Execute_Read_Cmd_Failed);
+			rtsx_trace(chip);
+			goto SD_Execute_Read_Cmd_Failed;
 	if (standby) {
+			rtsx_trace(chip);
 	if (acmd) {
 						sd_card->sd_addr,
+			rtsx_trace(chip);
 	if (data_len <= 512) {
@@ -3911,8 +4290,10 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		cmd[4] = srb->cmnd[6];
 		buf = kmalloc(data_len, GFP_KERNEL);
-		if (buf == NULL)
+		if (buf == NULL) {
+			rtsx_trace(chip);
 		retval = sd_read_data(chip, SD_TM_NORMAL_READ, cmd, 5, byte_cnt,
 				       blk_cnt, bus_width, buf, data_len, 2000);
@@ -3920,7 +4301,8 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			read_err = true;
 			kfree(buf);
+			rtsx_trace(chip);
 		min_len = min(data_len, scsi_bufflen(srb));
@@ -3968,43 +4350,57 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (retval < 0) {
 			read_err = true;
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
 	retval = ext_sd_get_rsp(chip, rsp_len, sd_card->rsp, rsp_type);
+		rtsx_trace(chip);
 	if (standby) {
+			rtsx_trace(chip);
 	if (send_cmd12) {
 		retval = ext_sd_send_cmd_get_rsp(chip, STOP_TRANSMISSION,
 				0, SD_RSP_TYPE_R1b, NULL, 0, false);
+			rtsx_trace(chip);
 		retval = ext_sd_send_cmd_get_rsp(chip, SET_BLOCKLEN, 0x200,
+			rtsx_trace(chip);
 		retval = rtsx_write_register(chip, SD_BYTE_CNT_H, 0xFF, 0x02);
+			rtsx_trace(chip);
 		retval = rtsx_write_register(chip, SD_BYTE_CNT_L, 0xFF, 0x00);
+			rtsx_trace(chip);
 	if ((srb->cmnd[1] & 0x02) || (srb->cmnd[1] & 0x04))
@@ -4018,8 +4414,10 @@ int sd_execute_read_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		if (retval == STATUS_SUCCESS)
 			break;
+		rtsx_trace(chip);
@@ -4035,7 +4433,8 @@ SD_Execute_Read_Cmd_Failed:
+	rtsx_trace(chip);
 int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
@@ -4055,18 +4454,22 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -4093,68 +4496,87 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 						SD_BUS_WIDTH_8);
+				rtsx_trace(chip);
 						SD_BUS_WIDTH_4);
+				rtsx_trace(chip);
 #else
+		rtsx_trace(chip);
 #endif
-			TRACE_GOTO(chip, SD_Execute_Write_Cmd_Failed);
+			rtsx_trace(chip);
+			goto SD_Execute_Write_Cmd_Failed;
 	if (standby) {
+			rtsx_trace(chip);
 	if (acmd) {
 						sd_card->sd_addr,
+			rtsx_trace(chip);
+		rtsx_trace(chip);
 		u16 i;
 		u8 *buf;
-		if (buf == NULL)
+			rtsx_trace(chip);
 		rtsx_stor_get_xfer_buf(buf, data_len, srb);
@@ -4172,7 +4594,8 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
@@ -4183,7 +4606,8 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
 		} else {
@@ -4194,7 +4618,8 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
@@ -4245,13 +4670,15 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 					DMA_TO_DEVICE, 10000);
 	} else {
+		rtsx_trace(chip);
 	if (retval < 0) {
 		write_err = true;
+		rtsx_trace(chip);
@@ -4277,30 +4704,40 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (standby) {
+			rtsx_trace(chip);
 	if (send_cmd12) {
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
@@ -4314,8 +4751,10 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			break;
+		rtsx_trace(chip);
 	if (cmd_idx == LOCK_UNLOCK) {
@@ -4341,7 +4780,8 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 							sd_card->sd_lock_status &= ~(SD_UNLOCK_POW_ON | SD_SDR_RST);
+							rtsx_trace(chip);
@@ -4354,7 +4794,8 @@ int sd_execute_write_data(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (lock_cmd_fail) {
 		set_sense_type(chip, lun, SENSE_TYPE_NO_SENSE);
+		rtsx_trace(chip);
 #endif  /* SUPPORT_SD_LOCK */
@@ -4372,7 +4813,8 @@ SD_Execute_Write_Cmd_Failed:
+	rtsx_trace(chip);
 int sd_get_cmd_rsp(struct scsi_cmnd *srb, struct rtsx_chip *chip)
@@ -4384,20 +4826,23 @@ int sd_get_cmd_rsp(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
 	data_len = ((u16)srb->cmnd[7] << 8) | srb->cmnd[8];
 	if (sd_card->last_rsp_type == SD_RSP_TYPE_R0) {
+		rtsx_trace(chip);
 	} else if (sd_card->last_rsp_type == SD_RSP_TYPE_R2) {
 		count = (data_len < 17) ? data_len : 17;
 	} else {
@@ -4422,13 +4867,15 @@ int sd_hw_rst(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -4436,7 +4883,8 @@ int sd_hw_rst(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
@@ -4452,7 +4900,8 @@ int sd_hw_rst(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 #endif
 			sd_card->pre_cmd_err = 1;
+			rtsx_trace(chip);
 		sd_card->sd_lock_status &= ~SD_SDR_RST;
@@ -4464,13 +4913,15 @@ int sd_hw_rst(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+			rtsx_trace(chip);
 		break;
 	default:
+		rtsx_trace(chip);
@@ -4494,23 +4945,29 @@ int sd_power_off_card3v3(struct rtsx_chip *chip)
 	int retval;
 	retval = disable_card_clock(chip, SD_CARD);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CARD_OE, SD_OUTPUT_EN, 0);
 		retval = card_power_off(chip, SD_CARD);
+			rtsx_trace(chip);
 		wait_timeout(50);
 		retval = sd_pull_ctl_disable(chip);
+			rtsx_trace(chip);
 	} else {
 			FPGA_SD_PULL_CTL_BIT | 0x20, FPGA_SD_PULL_CTL_BIT);
@@ -4540,8 +4997,10 @@ int release_sd_card(struct rtsx_chip *chip)
 	memset(sd_card->raw_scr, 0, 8);
+		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/spi.c b/drivers/staging/rts5208/spi.c
index 29f4a80..d3ac6c0 100644
--- a/drivers/staging/rts5208/spi.c
+++ b/drivers/staging/rts5208/spi.c
@@ -25,9 +25,6 @@
 #include "rtsx.h"
 #include "spi.h"
 static inline void spi_set_err_code(struct rtsx_chip *chip, u8 err_code)
@@ -56,12 +53,16 @@ static int spi_set_init_para(struct rtsx_chip *chip)
 	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER0, 0xFF, (u8)(spi->clk_div));
 	retval = switch_clock(chip, spi->spi_clock);
+		rtsx_trace(chip);
 	retval = select_card(chip, SPI_CARD);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CARD_CLK_EN, SPI_CLK_EN, SPI_CLK_EN);
 	RTSX_WRITE_REG(chip, CARD_OE, SPI_OUTPUT_EN, SPI_OUTPUT_EN);
@@ -69,8 +70,10 @@ static int spi_set_init_para(struct rtsx_chip *chip)
 	wait_timeout(10);
 	retval = spi_init(chip);
+		rtsx_trace(chip);
@@ -91,7 +94,8 @@ static int sf_polling_status(struct rtsx_chip *chip, int msec)
 	if (retval < 0) {
 		rtsx_clear_spi_error(chip);
 		spi_set_err_code(chip, SPI_BUSY_ERR);
+		rtsx_trace(chip);
@@ -119,7 +123,8 @@ static int sf_enable_write(struct rtsx_chip *chip, u8 ins)
 	if (retval < 0) {
 		spi_set_err_code(chip, SPI_HW_ERR);
+		rtsx_trace(chip);
@@ -147,7 +152,8 @@ static int sf_disable_write(struct rtsx_chip *chip, u8 ins)
 	if (retval < 0) {
+		rtsx_trace(chip);
@@ -205,7 +211,8 @@ static int sf_erase(struct rtsx_chip *chip, u8 ins, u8 addr_mode, u32 addr)
 	if (retval < 0) {
+		rtsx_trace(chip);
@@ -225,12 +232,16 @@ static int spi_init_eeprom(struct rtsx_chip *chip)
 	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER0, 0xFF, 0x27);
 	retval = switch_clock(chip, clk);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -258,8 +269,10 @@ static int spi_eeprom_program_enable(struct rtsx_chip *chip)
 		SPI_TRANSFER0_END);
 	retval = rtsx_send_cmd(chip, 0, 100);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -269,12 +282,16 @@ int spi_erase_eeprom_chip(struct rtsx_chip *chip)
 	int retval;
 	retval = spi_init_eeprom(chip);
+		rtsx_trace(chip);
 	retval = spi_eeprom_program_enable(chip);
+		rtsx_trace(chip);
@@ -288,8 +305,10 @@ int spi_erase_eeprom_chip(struct rtsx_chip *chip)
 		SPI_TRANSFER0_END);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CARD_GPIO_DIR, 0x01, 0x01);
@@ -301,12 +320,16 @@ int spi_erase_eeprom_byte(struct rtsx_chip *chip, u16 addr)
 	int retval;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -322,8 +345,10 @@ int spi_erase_eeprom_byte(struct rtsx_chip *chip, u16 addr)
 		SPI_TRANSFER0_END);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -337,8 +362,10 @@ int spi_read_eeprom(struct rtsx_chip *chip, u16 addr, u8 *val)
 	u8 data;
+		rtsx_trace(chip);
@@ -355,8 +382,10 @@ int spi_read_eeprom(struct rtsx_chip *chip, u16 addr, u8 *val)
 		SPI_TRANSFER0_END);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	wait_timeout(5);
 	RTSX_READ_REG(chip, SPI_DATA, &data);
@@ -374,12 +403,16 @@ int spi_write_eeprom(struct rtsx_chip *chip, u16 addr, u8 val)
 	int retval;
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -396,8 +429,10 @@ int spi_write_eeprom(struct rtsx_chip *chip, u16 addr, u8 val)
 		SPI_TRANSFER0_END);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -449,13 +484,15 @@ int spi_read_flash_id(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	len = ((u16)(srb->cmnd[7]) << 8) | srb->cmnd[8];
 	if (len > 512) {
 		spi_set_err_code(chip, SPI_INVALID_COMMAND);
+		rtsx_trace(chip);
 	retval = spi_set_init_para(chip);
+		rtsx_trace(chip);
@@ -497,19 +534,23 @@ int spi_read_flash_id(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 	if (retval < 0) {
+		rtsx_trace(chip);
 	if (len) {
 		buf = kmalloc(len, GFP_KERNEL);
-		if (!buf)
-			TRACE_RET(chip, STATUS_ERROR);
+		if (!buf) {
+			rtsx_trace(chip);
+			return STATUS_ERROR;
 		retval = rtsx_read_ppbuf(chip, buf, len);
 			spi_set_err_code(chip, SPI_READ_ERR);
 			kfree(buf);
+			rtsx_trace(chip);
 		rtsx_stor_set_xfer_buf(buf, scsi_bufflen(srb), srb);
@@ -541,12 +582,15 @@ int spi_read_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	buf = kmalloc(SF_PAGE_LEN, GFP_KERNEL);
-	if (buf == NULL)
+		rtsx_trace(chip);
 	while (len) {
 		u16 pagelen = SF_PAGE_LEN - (u8)addr;
@@ -598,7 +642,8 @@ int spi_read_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 			kfree(buf);
+			rtsx_trace(chip);
 		rtsx_stor_access_xfer_buf(buf, pagelen, srb, &index, &offset,
@@ -634,19 +679,23 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	if (program_mode == BYTE_PROGRAM) {
 		buf = kmalloc(4, GFP_KERNEL);
-		if (!buf)
+		if (!buf) {
+			rtsx_trace(chip);
 		while (len) {
 			retval = sf_enable_write(chip, SPI_WREN);
 				kfree(buf);
+				rtsx_trace(chip);
 			rtsx_stor_access_xfer_buf(buf, 1, srb, &index, &offset,
@@ -665,13 +714,15 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
 			retval = sf_polling_status(chip, 100);
 			if (retval != STATUS_SUCCESS) {
 				kfree(buf);
+				rtsx_trace(chip);
 			addr++;
@@ -684,12 +735,16 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		int first_byte = 1;
-		if (retval != STATUS_SUCCESS)
+		if (retval != STATUS_SUCCESS) {
+			rtsx_trace(chip);
-		if (!buf)
+		if (!buf) {
+			rtsx_trace(chip);
 		while (len) {
@@ -713,13 +768,15 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
 				kfree(buf);
+				rtsx_trace(chip);
 			len--;
@@ -728,16 +785,22 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		kfree(buf);
 		retval = sf_disable_write(chip, SPI_WRDI);
+			rtsx_trace(chip);
+			rtsx_trace(chip);
 	} else if (program_mode == PAGE_PROGRAM) {
-		if (!buf)
-			TRACE_RET(chip, STATUS_NOMEM);
+		if (!buf) {
+			rtsx_trace(chip);
+			return STATUS_NOMEM;
 		while (len) {
@@ -748,7 +811,8 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
@@ -767,13 +831,15 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 				kfree(buf);
+				rtsx_trace(chip);
 				kfree(buf);
+				rtsx_trace(chip);
 			addr += pagelen;
@@ -783,7 +849,8 @@ int spi_write_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
 		kfree(buf);
 	} else {
+		rtsx_trace(chip);
@@ -805,28 +872,38 @@ int spi_erase_flash(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	if (erase_mode == PAGE_ERASE) {
+			rtsx_trace(chip);
 		retval = sf_erase(chip, ins, 1, addr);
+			rtsx_trace(chip);
 	} else if (erase_mode == CHIP_ERASE) {
+			rtsx_trace(chip);
 		retval = sf_erase(chip, ins, 0, 0);
+			rtsx_trace(chip);
 	} else {
+		rtsx_trace(chip);
@@ -844,12 +921,15 @@ int spi_write_flash_status(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
 	retval = sf_enable_write(chip, ewsr);
+		rtsx_trace(chip);
@@ -871,7 +951,8 @@ int spi_write_flash_status(struct scsi_cmnd *srb, struct rtsx_chip *chip)
+		rtsx_trace(chip);
diff --git a/drivers/staging/rts5208/trace.c b/drivers/staging/rts5208/trace.c
new file mode 100644
index 0000000..1bddbdf
--- /dev/null
+++ b/drivers/staging/rts5208/trace.c
@@ -0,0 +1,26 @@
+#include <linux/kernel.h>
+#include <linux/string.h>
+#include "rtsx.h"
+#ifdef _MSG_TRACE
+void _rtsx_trace(struct rtsx_chip *chip, const char *file, const char *func,
+		 int line)
+	struct trace_msg_t *msg = &chip->trace_msg[chip->msg_idx];
+	file = kbasename(file);
+	dev_dbg(rtsx_dev(chip), "[%s][%s]:[%d]\n", file, func, line);
+	strncpy(msg->file, file, MSG_FILE_LEN - 1);
+	strncpy(msg->func, func, MSG_FUNC_LEN - 1);
+	msg->line = (u16)line;
+	get_current_time(msg->timeval_buf, TIME_VAL_LEN);
+	msg->valid = 1;
+	chip->msg_idx++;
+	if (chip->msg_idx >= TRACE_ITEM_CNT)
+		chip->msg_idx = 0;
+#endif
diff --git a/drivers/staging/rts5208/trace.h b/drivers/staging/rts5208/trace.h
index a9ab407..5b80787 100644
--- a/drivers/staging/rts5208/trace.h
+++ b/drivers/staging/rts5208/trace.h
@@ -24,64 +24,17 @@
 #ifndef __REALTEK_RTSX_TRACE_H
 #define __REALTEK_RTSX_TRACE_H
-#define _MSG_TRACE
+struct rtsx_chip;
 #ifdef _MSG_TRACE
-static inline char *filename(char *path)
+		 int line);
+#define rtsx_trace(chip)						\
+	_rtsx_trace(chip, __FILE__, __func__, __LINE__)
+#else
+static inline void rtsx_trace(struct rtsx_chip *chip)
-	char *ptr;
-	if (path == NULL)
-		return NULL;
-	ptr = path;
-	while (*ptr != '\0') {
-		if ((*ptr == '\\') || (*ptr == '/'))
-			path = ptr + 1;
-		ptr++;
-	return path;
-#define TRACE_RET(chip, ret)						\
-	do {								\
-		char *_file = filename(__FILE__);			\
-		dev_dbg(rtsx_dev(chip), "[%s][%s]:[%d]\n", _file,	\
-			__func__, __LINE__);				\
-		(chip)->trace_msg[(chip)->msg_idx].line = (u16)(__LINE__); \
-		strncpy((chip)->trace_msg[(chip)->msg_idx].func, __func__, MSG_FUNC_LEN-1); \
-		strncpy((chip)->trace_msg[(chip)->msg_idx].file, _file, MSG_FILE_LEN-1); \
-		get_current_time((chip)->trace_msg[(chip)->msg_idx].timeval_buf, TIME_VAL_LEN);	\
-		(chip)->trace_msg[(chip)->msg_idx].valid = 1;		\
-		(chip)->msg_idx++;					\
-		if ((chip)->msg_idx >= TRACE_ITEM_CNT) {		\
-			(chip)->msg_idx = 0;				\
-		return ret;						\
-	} while (0)
-#define TRACE_GOTO(chip, label)						\
-	do {								\
-		goto label;						\
-	} while (0)
-#else
-#define TRACE_RET(chip, ret)	return ret
-#define TRACE_GOTO(chip, label)	goto label
 #endif
 #endif  /* __REALTEK_RTSX_TRACE_H */
diff --git a/drivers/staging/rts5208/xd.c b/drivers/staging/rts5208/xd.c
index 0d029fe..2afa602 100644
--- a/drivers/staging/rts5208/xd.c
+++ b/drivers/staging/rts5208/xd.c
@@ -60,8 +60,10 @@ static int xd_set_init_para(struct rtsx_chip *chip)
 		xd_card->xd_clock = CLK_50;
 	retval = switch_clock(chip, xd_card->xd_clock);
+		rtsx_trace(chip);
@@ -72,12 +74,16 @@ static int xd_switch_clock(struct rtsx_chip *chip)
 	int retval;
 	retval = select_card(chip, XD_CARD);
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -99,8 +105,10 @@ static int xd_read_id(struct rtsx_chip *chip, u8 id_cmd, u8 *id_buf, u8 buf_len)
 		rtsx_add_cmd(chip, READ_REG_CMD, (u16)(XD_ADDRESS1 + i), 0, 0);
 	retval = rtsx_send_cmd(chip, XD_CARD, 20);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	if (id_buf && buf_len) {
@@ -167,8 +175,10 @@ static int xd_read_redundant(struct rtsx_chip *chip, u32 page_addr,
 	rtsx_add_cmd(chip, READ_REG_CMD, XD_PARITY, 0, 0);
 	retval = rtsx_send_cmd(chip, XD_CARD, 500);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	if (buf && buf_len) {
 		u8 *ptr = rtsx_get_cmd_data(chip) + 1;
@@ -186,8 +196,10 @@ static int xd_read_data_from_ppb(struct rtsx_chip *chip, int offset,
 	int retval, i;
-	if (!buf || (buf_len < 0))
+	if (!buf || (buf_len < 0)) {
+		rtsx_trace(chip);
@@ -198,7 +210,8 @@ static int xd_read_data_from_ppb(struct rtsx_chip *chip, int offset,
 	retval = rtsx_send_cmd(chip, 0, 250);
 	if (retval < 0) {
 		rtsx_clear_xd_error(chip);
+		rtsx_trace(chip);
 	memcpy(buf, rtsx_get_cmd_data(chip), buf_len);
@@ -212,8 +225,10 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 	int retval;
 	u8 reg;
-	if (!buf || (buf_len < 10))
+	if (!buf || (buf_len < 10)) {
+		rtsx_trace(chip);
@@ -233,20 +248,24 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 	retval = rtsx_send_cmd(chip, XD_CARD, 250);
 	if (retval == -ETIMEDOUT) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, XD_PAGE_STATUS, &reg);
 	if (reg != XD_GPG) {
+		rtsx_trace(chip);
 	RTSX_READ_REG(chip, XD_CTL, &reg);
 	if (!(reg & XD_ECC1_ERROR) || !(reg & XD_ECC1_UNCORRECTABLE)) {
 		retval = xd_read_data_from_ppb(chip, 0, buf, buf_len);
+			rtsx_trace(chip);
 		if (reg & XD_ECC1_ERROR) {
 			u8 ecc_bit, ecc_byte;
@@ -267,8 +286,10 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 		retval = xd_read_data_from_ppb(chip, 256, buf, buf_len);
+			rtsx_trace(chip);
 		if (reg & XD_ECC2_ERROR) {
@@ -287,7 +308,8 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 	} else {
+		rtsx_trace(chip);
@@ -394,8 +416,10 @@ static int reset_xd(struct rtsx_chip *chip)
 	u8 *ptr, id_buf[4], redunt[11];
+		rtsx_trace(chip);
@@ -418,13 +442,17 @@ static int reset_xd(struct rtsx_chip *chip)
 	rtsx_add_cmd(chip, WRITE_REG_CMD, CARD_OE, XD_OUTPUT_EN, 0);
 	retval = rtsx_send_cmd(chip, XD_CARD, 100);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 		retval = card_power_off(chip, XD_CARD);
+			rtsx_trace(chip);
 		wait_timeout(250);
@@ -439,19 +467,24 @@ static int reset_xd(struct rtsx_chip *chip)
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
 		retval = card_power_on(chip, XD_CARD);
+			rtsx_trace(chip);
 #ifdef SUPPORT_OCP
 		wait_timeout(50);
 				chip->ocp_stat);
+			rtsx_trace(chip);
 #endif
@@ -472,15 +505,19 @@ static int reset_xd(struct rtsx_chip *chip)
 	rtsx_add_cmd(chip, WRITE_REG_CMD, XD_CTL, XD_CE_DISEN, XD_CE_DISEN);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 		wait_timeout(200);
 	retval = xd_set_init_para(chip);
+		rtsx_trace(chip);
 	/* Read ID to check if the timing setting is right */
 	for (i = 0; i < 4; i++) {
@@ -502,8 +539,10 @@ static int reset_xd(struct rtsx_chip *chip)
 		rtsx_add_cmd(chip, READ_REG_CMD, XD_CTL, 0, 0);
-		if (retval < 0)
+		if (retval < 0) {
+			rtsx_trace(chip);
@@ -515,8 +554,10 @@ static int reset_xd(struct rtsx_chip *chip)
 			continue;
 		retval = xd_read_id(chip, READ_ID, id_buf, 4);
+			rtsx_trace(chip);
 		dev_dbg(rtsx_dev(chip), "READ_ID: 0x%x 0x%x 0x%x 0x%x\n",
 			id_buf[0], id_buf[1], id_buf[2], id_buf[3]);
@@ -596,8 +637,10 @@ static int reset_xd(struct rtsx_chip *chip)
 		/* Confirm timing setting */
 		for (j = 0; j < 10; j++) {
+				rtsx_trace(chip);
 			if (id_buf[1] != xd_card->device_code)
 				break;
@@ -613,23 +656,30 @@ static int reset_xd(struct rtsx_chip *chip)
 		xd_card->addr_cycle = 0;
 		xd_card->capacity = 0;
+		rtsx_trace(chip);
 	retval = xd_read_id(chip, READ_xD_ID, id_buf, 4);
+		rtsx_trace(chip);
 	dev_dbg(rtsx_dev(chip), "READ_xD_ID: 0x%x 0x%x 0x%x 0x%x\n",
-	if (id_buf[2] != XD_ID_CODE)
+	if (id_buf[2] != XD_ID_CODE) {
+		rtsx_trace(chip);
 	/* Search CIS block */
 	for (i = 0; i < 24; i++) {
 		u32 page_addr;
-		if (detect_card_cd(chip, XD_CARD) != STATUS_SUCCESS)
+		if (detect_card_cd(chip, XD_CARD) != STATUS_SUCCESS) {
+			rtsx_trace(chip);
 		page_addr = (u32)i << xd_card->block_shift;
@@ -667,8 +717,10 @@ static int reset_xd(struct rtsx_chip *chip)
 			page_addr += j;
 			retval = xd_read_cis(chip, page_addr, buf, 10);
+				rtsx_trace(chip);
 			if ((buf[0] == 0x01) && (buf[1] == 0x03) &&
 				(buf[2] == 0xD9)
@@ -684,8 +736,10 @@ static int reset_xd(struct rtsx_chip *chip)
 	dev_dbg(rtsx_dev(chip), "CIS block: 0x%x\n", xd_card->cis_block);
-	if (xd_card->cis_block == 0xFFFF)
+	if (xd_card->cis_block == 0xFFFF) {
+		rtsx_trace(chip);
 	chip->capacity[chip->card2lun[XD_CARD]] = xd_card->capacity;
@@ -739,15 +793,19 @@ static int xd_init_l2p_tbl(struct rtsx_chip *chip)
 	dev_dbg(rtsx_dev(chip), "xd_init_l2p_tbl: zone_cnt = %d\n",
 		xd_card->zone_cnt);
-	if (xd_card->zone_cnt < 1)
+	if (xd_card->zone_cnt < 1) {
+		rtsx_trace(chip);
 	size = xd_card->zone_cnt * sizeof(struct zone_entry);
 	dev_dbg(rtsx_dev(chip), "Buffer size for l2p table is %d\n", size);
 	xd_card->zone = vmalloc(size);
-	if (!xd_card->zone)
+	if (!xd_card->zone) {
+		rtsx_trace(chip);
 	for (i = 0; i < xd_card->zone_cnt; i++) {
 		xd_card->zone[i].build_flag = 0;
@@ -927,16 +985,22 @@ int reset_xd_card(struct rtsx_chip *chip)
 	xd_card->delay_write.delay_write_flag = 0;
 	retval = enable_card_clock(chip, XD_CARD);
+		rtsx_trace(chip);
 	retval = reset_xd(chip);
+		rtsx_trace(chip);
 	retval = xd_init_l2p_tbl(chip);
+		rtsx_trace(chip);
@@ -950,8 +1014,10 @@ static int xd_mark_bad_block(struct rtsx_chip *chip, u32 phy_blk)
 	dev_dbg(rtsx_dev(chip), "mark block 0x%x as bad block\n", phy_blk);
-	if (phy_blk == BLK_NOT_FOUND)
+	if (phy_blk == BLK_NOT_FOUND) {
+		rtsx_trace(chip);
@@ -986,7 +1052,8 @@ static int xd_mark_bad_block(struct rtsx_chip *chip, u32 phy_blk)
 			xd_set_err_code(chip, XD_PRG_ERROR);
 		else
 			xd_set_err_code(chip, XD_TO_ERROR);
+		rtsx_trace(chip);
@@ -1002,10 +1069,14 @@ static int xd_init_page(struct rtsx_chip *chip, u32 phy_blk,
 	dev_dbg(rtsx_dev(chip), "Init block 0x%x\n", phy_blk);
-	if (start_page > end_page)
+	if (start_page > end_page) {
+		rtsx_trace(chip);
+		rtsx_trace(chip);
@@ -1040,7 +1111,8 @@ static int xd_init_page(struct rtsx_chip *chip, u32 phy_blk,
 		} else {
+		rtsx_trace(chip);
@@ -1057,11 +1129,15 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
 	dev_dbg(rtsx_dev(chip), "Copy page from block 0x%x to block 0x%x\n",
 		old_blk, new_blk);
+		rtsx_trace(chip);
-	if ((old_blk == BLK_NOT_FOUND) || (new_blk == BLK_NOT_FOUND))
+	if ((old_blk == BLK_NOT_FOUND) || (new_blk == BLK_NOT_FOUND)) {
+		rtsx_trace(chip);
 	old_page = (old_blk << xd_card->block_shift) + start_page;
 	new_page = (new_blk << xd_card->block_shift) + start_page;
@@ -1074,7 +1150,8 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
 			xd_set_err_code(chip, XD_NO_CARD);
+			rtsx_trace(chip);
@@ -1100,7 +1177,8 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
+					rtsx_trace(chip);
 				if (((reg & (XD_ECC1_ERROR | XD_ECC1_UNCORRECTABLE)) ==
@@ -1119,7 +1197,8 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
 			} else {
+				rtsx_trace(chip);
@@ -1147,7 +1226,8 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
 			} else {
+			rtsx_trace(chip);
 		old_page++;
@@ -1172,14 +1252,17 @@ static int xd_reset_cmd(struct rtsx_chip *chip)
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
 	if (((ptr[0] & READY_FLAG) == READY_STATE) && (ptr[1] & XD_RDY))
+	rtsx_trace(chip);
 static int xd_erase_block(struct rtsx_chip *chip, u32 phy_blk)
@@ -1189,8 +1272,10 @@ static int xd_erase_block(struct rtsx_chip *chip, u32 phy_blk)
 	u8 reg = 0, *ptr;
 	int i, retval;
+		rtsx_trace(chip);
 	page_addr = phy_blk << xd_card->block_shift;
@@ -1212,13 +1297,16 @@ static int xd_erase_block(struct rtsx_chip *chip, u32 phy_blk)
 			if (reg & PROGRAM_ERROR) {
 				xd_mark_bad_block(chip, phy_blk);
+				rtsx_trace(chip);
 			} else {
 				xd_set_err_code(chip, XD_ERASE_FAIL);
 			retval = xd_reset_cmd(chip);
+				rtsx_trace(chip);
 			continue;
@@ -1226,7 +1314,8 @@ static int xd_erase_block(struct rtsx_chip *chip, u32 phy_blk)
 		if (*ptr & PROGRAM_ERROR) {
+			rtsx_trace(chip);
@@ -1234,7 +1323,8 @@ static int xd_erase_block(struct rtsx_chip *chip, u32 phy_blk)
+	rtsx_trace(chip);
@@ -1266,15 +1356,19 @@ static int xd_build_l2p_tbl(struct rtsx_chip *chip, int zone_no)
 	if (zone->l2p_table == NULL) {
 		zone->l2p_table = vmalloc(2000);
-		if (zone->l2p_table == NULL)
-			TRACE_GOTO(chip, Build_Fail);
+		if (zone->l2p_table == NULL) {
+			rtsx_trace(chip);
+			goto Build_Fail;
 	memset((u8 *)(zone->l2p_table), 0xff, 2000);
 	if (zone->free_table == NULL) {
 		zone->free_table = vmalloc(XD_FREE_TABLE_CNT * 2);
-		if (zone->free_table == NULL)
+		if (zone->free_table == NULL) {
+			rtsx_trace(chip);
+			goto Build_Fail;
 	memset((u8 *)(zone->free_table), 0xff, XD_FREE_TABLE_CNT * 2);
@@ -1440,8 +1534,10 @@ static int xd_send_cmd(struct rtsx_chip *chip, u8 cmd)
 		XD_TRANSFER_END, XD_TRANSFER_END);
 	retval = rtsx_send_cmd(chip, XD_CARD, 200);
-	if (retval < 0)
+	if (retval < 0) {
+		rtsx_trace(chip);
@@ -1457,8 +1553,10 @@ static int xd_read_multiple_pages(struct rtsx_chip *chip, u32 phy_blk,
 	u8 reg_val, page_cnt;
 	int zone_no, retval, i;
+		rtsx_trace(chip);
 	page_cnt = end_page - start_page;
 	zone_no = (int)(log_blk / 1000);
@@ -1474,7 +1572,8 @@ static int xd_read_multiple_pages(struct rtsx_chip *chip, u32 phy_blk,
+				rtsx_trace(chip);
@@ -1509,9 +1608,11 @@ static int xd_read_multiple_pages(struct rtsx_chip *chip, u32 phy_blk,
+			rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
+			goto Fail;
@@ -1533,7 +1634,8 @@ Fail:
+			rtsx_trace(chip);
 		xd_set_err_code(chip, XD_ECC_ERROR);
@@ -1541,7 +1643,8 @@ Fail:
 		new_blk = xd_get_unused_block(chip, zone_no);
 		if (new_blk == NO_NEW_BLK) {
 			XD_CLR_BAD_OLDBLK(xd_card);
+			rtsx_trace(chip);
 		retval = xd_copy_page(chip, phy_blk, new_blk, 0,
@@ -1555,7 +1658,8 @@ Fail:
 				XD_CLR_BAD_NEWBLK(xd_card);
+			rtsx_trace(chip);
 		xd_set_l2p_tbl(chip, zone_no, log_off, (u16)(new_blk & 0x3FF));
 		xd_erase_block(chip, phy_blk);
@@ -1563,7 +1667,8 @@ Fail:
+	rtsx_trace(chip);
 static int xd_finish_write(struct rtsx_chip *chip,
@@ -1576,8 +1681,10 @@ static int xd_finish_write(struct rtsx_chip *chip,
 	dev_dbg(rtsx_dev(chip), "xd_finish_write, old_blk = 0x%x, new_blk = 0x%x, log_blk = 0x%x\n",
 		old_blk, new_blk, log_blk);
-	if (page_off > xd_card->page_off)
+	if (page_off > xd_card->page_off) {
+		rtsx_trace(chip);
 	log_off = (u16)(log_blk % 1000);
@@ -1589,7 +1696,8 @@ static int xd_finish_write(struct rtsx_chip *chip,
 			retval = xd_erase_block(chip, new_blk);
 				xd_set_unused_block(chip, new_blk);
+			rtsx_trace(chip);
 	} else {
 		retval = xd_copy_page(chip, old_blk, new_blk,
@@ -1601,7 +1709,8 @@ static int xd_finish_write(struct rtsx_chip *chip,
+			rtsx_trace(chip);
 		retval = xd_erase_block(chip, old_blk);
@@ -1633,8 +1742,10 @@ static int xd_prepare_write(struct rtsx_chip *chip,
 	if (page_off) {
 		retval = xd_copy_page(chip, old_blk, new_blk, 0, page_off);
+			rtsx_trace(chip);
@@ -1655,8 +1766,10 @@ static int xd_write_multiple_pages(struct rtsx_chip *chip, u32 old_blk,
 	dev_dbg(rtsx_dev(chip), "%s, old_blk = 0x%x, new_blk = 0x%x, log_blk = 0x%x\n",
 		__func__, old_blk, new_blk, log_blk);
+		rtsx_trace(chip);
@@ -1665,8 +1778,10 @@ static int xd_write_multiple_pages(struct rtsx_chip *chip, u32 old_blk,
 	page_addr = (new_blk << xd_card->block_shift) + start_page;
 	retval = xd_send_cmd(chip, READ1_1);
+		rtsx_trace(chip);
@@ -1701,9 +1816,11 @@ static int xd_write_multiple_pages(struct rtsx_chip *chip, u32 old_blk,
+			rtsx_trace(chip);
 		} else {
+			rtsx_trace(chip);
+			goto Fail;
@@ -1736,7 +1853,8 @@ Fail:
 		xd_mark_bad_block(chip, new_blk);
+	rtsx_trace(chip);
 #ifdef XD_DELAY_WRITE
@@ -1749,16 +1867,20 @@ int xd_delay_write(struct rtsx_chip *chip)
 	if (delay_write->delay_write_flag) {
 		dev_dbg(rtsx_dev(chip), "xd_delay_write\n");
 		retval = xd_switch_clock(chip);
+			rtsx_trace(chip);
 		delay_write->delay_write_flag = 0;
 		retval = xd_finish_write(chip,
 				delay_write->old_phyblock,
 					delay_write->new_phyblock,
 				delay_write->logblock, delay_write->pageoff);
+			rtsx_trace(chip);
@@ -1790,14 +1912,17 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 	ptr = (u8 *)scsi_sglist(srb);
+		rtsx_trace(chip);
 		chip->card_fail |= XD_CARD;
+		rtsx_trace(chip);
 	log_blk = start_sector >> xd_card->block_shift;
@@ -1810,7 +1935,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+			rtsx_trace(chip);
@@ -1828,7 +1954,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 						SENSE_TYPE_MEDIA_WRITE_ERR);
+					rtsx_trace(chip);
 			old_blk = delay_write->old_phyblock;
@@ -1844,7 +1971,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 #endif
 			old_blk = xd_get_l2p_tbl(chip, zone_no, log_off);
@@ -1853,7 +1981,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 			retval = xd_prepare_write(chip, old_blk, new_blk,
@@ -1863,11 +1992,13 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 					STATUS_SUCCESS) {
+					rtsx_trace(chip);
+				rtsx_trace(chip);
@@ -1879,11 +2010,13 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 				SENSE_TYPE_MEDIA_UNRECOVER_READ_ERR);
+			rtsx_trace(chip);
 #endif
@@ -1891,7 +2024,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 		if (old_blk == BLK_NOT_FOUND) {
+			rtsx_trace(chip);
@@ -1901,7 +2035,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+			rtsx_trace(chip);
 		if ((start_page + total_sec_cnt) > (xd_card->page_off + 1))
@@ -1917,7 +2052,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 		} else {
 			retval = xd_write_multiple_pages(chip, old_blk,
@@ -1927,7 +2063,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
@@ -1948,7 +2085,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
@@ -1961,7 +2099,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+			rtsx_trace(chip);
 		if (srb->sc_data_direction == DMA_TO_DEVICE) {
@@ -1969,7 +2108,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 			if (new_blk == BLK_NOT_FOUND) {
+				rtsx_trace(chip);
@@ -1988,7 +2128,8 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+			rtsx_trace(chip);
 		retval = xd_finish_write(chip, old_blk, new_blk,
@@ -1997,10 +2138,12 @@ int xd_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
+				rtsx_trace(chip);
 			set_sense_type(chip, lun, SENSE_TYPE_MEDIA_WRITE_ERR);
+			rtsx_trace(chip);
 #endif
@@ -2049,23 +2192,29 @@ int xd_power_off_card3v3(struct rtsx_chip *chip)
 	int retval;
 	retval = disable_card_clock(chip, XD_CARD);
+		rtsx_trace(chip);
 	RTSX_WRITE_REG(chip, CARD_OE, XD_OUTPUT_EN, 0);
+			rtsx_trace(chip);
 		wait_timeout(50);
 		retval = xd_pull_ctl_disable(chip);
+			rtsx_trace(chip);
 	} else {
 		RTSX_WRITE_REG(chip, FPGA_PULL_CTL, 0xFF, 0xDF);
@@ -2087,8 +2236,10 @@ int release_xd_card(struct rtsx_chip *chip)
 	xd_free_l2p_tbl(chip);
 	retval = xd_power_off_card3v3(chip);
-		TRACE_RET(chip, STATUS_FAIL);
+		rtsx_trace(chip);
+		return STATUS_FAIL;
 	return STATUS_SUCCESS;
BtrLinux
Privacy Overview
