staging: rts5208: Remove RTSX_READ_REG and RTSX_WRITE_REG macros
Author: Joe Perches <joe@perches.com>
Macros with hidden flow control are bad form as the code path
taken can be unexpected for the reader.
Expand these in-place and remove the macros.
Done with coccinelle script:
expression chip;
expression arg1;
expression arg2;
expression arg3;
-	RTSX_WRITE_REG(chip, arg1, arg2, arg3);
+	retval = rtsx_write_register(chip, arg1, arg2, arg3);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
expression chip;
expression arg1;
expression arg2;
-	RTSX_READ_REG(chip, arg1, arg2);
+	retval = rtsx_read_register(chip, arg1, arg2);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
Signed-off-by: Joe Perches
 drivers/staging/rts5208/ms.c        | 250 ++++++++++++---
 drivers/staging/rts5208/rtsx_card.c |  96 +++++-
 drivers/staging/rts5208/rtsx_card.h |   8 +-
 drivers/staging/rts5208/rtsx_chip.c | 607 +++++++++++++++++++++++++++++-------
 drivers/staging/rts5208/rtsx_chip.h |  18 --
 drivers/staging/rts5208/sd.c        | 494 +++++++++++++++++++++++------
 drivers/staging/rts5208/spi.c       | 117 +++++--
 drivers/staging/rts5208/xd.c        | 154 +++++++--
 8 files changed, 1410 insertions(+), 334 deletions(-)
diff --git a/drivers/staging/rts5208/ms.c b/drivers/staging/rts5208/ms.c
index dcaec19..ee818b0 100644
--- a/drivers/staging/rts5208/ms.c
+++ b/drivers/staging/rts5208/ms.c
@@ -169,7 +169,11 @@ static int ms_transfer_data(struct rtsx_chip *chip, u8 trans_mode,
 		return retval;
-	RTSX_READ_REG(chip, MS_TRANS_CFG, &val);
+	retval = rtsx_read_register(chip, MS_TRANS_CFG, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (val & (MS_INT_CMDNK | MS_INT_ERR | MS_CRC16_ERR | MS_RDY_TIMEOUT)) {
 		rtsx_trace(chip);
 		return STATUS_FAIL;
@@ -424,25 +428,71 @@ static int ms_switch_clock(struct rtsx_chip *chip)
 static int ms_pull_ctl_disable(struct rtsx_chip *chip)
+	int retval;
 	if (CHECK_PID(chip, 0x5208)) {
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL1, 0xFF,
-			MS_D1_PD | MS_D2_PD | MS_CLK_PD | MS_D6_PD);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL2, 0xFF,
-			MS_D3_PD | MS_D0_PD | MS_BS_PD | XD_D4_PD);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL3, 0xFF,
-			MS_D7_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL4, 0xFF,
-			XD_RDY_PD | SD_D3_PD | SD_D2_PD | XD_ALE_PD);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL5, 0xFF,
-			MS_INS_PU | SD_WP_PD | SD_CD_PU | SD_CMD_PD);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL6, 0xFF,
-			MS_D5_PD | MS_D4_PD);
+		retval = rtsx_write_register(chip, CARD_PULL_CTL1, 0xFF,
+					     MS_D1_PD | MS_D2_PD | MS_CLK_PD | MS_D6_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CARD_PULL_CTL2, 0xFF,
+					     MS_D3_PD | MS_D0_PD | MS_BS_PD | XD_D4_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CARD_PULL_CTL3, 0xFF,
+					     MS_D7_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CARD_PULL_CTL4, 0xFF,
+					     XD_RDY_PD | SD_D3_PD | SD_D2_PD | XD_ALE_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CARD_PULL_CTL5, 0xFF,
+					     MS_INS_PU | SD_WP_PD | SD_CD_PU | SD_CMD_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CARD_PULL_CTL6, 0xFF,
+					     MS_D5_PD | MS_D4_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	} else if (CHECK_PID(chip, 0x5288)) {
 		if (CHECK_BARO_PKG(chip, QFN)) {
-			RTSX_WRITE_REG(chip, CARD_PULL_CTL1, 0xFF, 0x55);
-			RTSX_WRITE_REG(chip, CARD_PULL_CTL2, 0xFF, 0x55);
-			RTSX_WRITE_REG(chip, CARD_PULL_CTL3, 0xFF, 0x4B);
-			RTSX_WRITE_REG(chip, CARD_PULL_CTL4, 0xFF, 0x69);
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x4B);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x69);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
@@ -525,8 +575,12 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 			return STATUS_FAIL;
 	} else {
-		RTSX_WRITE_REG(chip, FPGA_PULL_CTL,
-			FPGA_MS_PULL_CTL_BIT | 0x20, 0);
+		retval = rtsx_write_register(chip, FPGA_PULL_CTL,
+					     FPGA_MS_PULL_CTL_BIT | 0x20, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	if (!chip->ft2_fast_mode) {
@@ -553,21 +607,40 @@ static int ms_prepare_reset(struct rtsx_chip *chip)
 #endif
-	RTSX_WRITE_REG(chip, CARD_OE, MS_OUTPUT_EN, MS_OUTPUT_EN);
+	retval = rtsx_write_register(chip, CARD_OE, MS_OUTPUT_EN,
+				     MS_OUTPUT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (chip->asic_code) {
-		RTSX_WRITE_REG(chip, MS_CFG, 0xFF,
-			SAMPLE_TIME_RISING | PUSH_TIME_DEFAULT |
-			NO_EXTEND_TOGGLE | MS_BUS_WIDTH_1);
+		retval = rtsx_write_register(chip, MS_CFG, 0xFF,
+					     SAMPLE_TIME_RISING | PUSH_TIME_DEFAULT | NO_EXTEND_TOGGLE | MS_BUS_WIDTH_1);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	} else {
-			SAMPLE_TIME_FALLING | PUSH_TIME_DEFAULT |
+					     SAMPLE_TIME_FALLING | PUSH_TIME_DEFAULT | NO_EXTEND_TOGGLE | MS_BUS_WIDTH_1);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+	retval = rtsx_write_register(chip, MS_TRANS_CFG, 0xFF,
+				     NO_WAIT_INT | NO_AUTO_READ_INT_REG);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, CARD_STOP, MS_STOP | MS_CLR_ERR,
+				     MS_STOP | MS_CLR_ERR);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_WRITE_REG(chip, MS_TRANS_CFG,
-		0xFF, NO_WAIT_INT | NO_AUTO_READ_INT_REG);
-	RTSX_WRITE_REG(chip, CARD_STOP,
-		MS_STOP | MS_CLR_ERR, MS_STOP | MS_CLR_ERR);
 	retval = ms_set_init_para(chip);
 	if (retval != STATUS_SUCCESS) {
@@ -601,7 +674,11 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, PPBUF_BASE2 + 2, &val);
+	retval = rtsx_read_register(chip, PPBUF_BASE2 + 2, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "Type register: 0x%x\n", val);
 	if (val != 0x01) {
 		if (val != 0x02)
@@ -611,7 +688,11 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, PPBUF_BASE2 + 4, &val);
+	retval = rtsx_read_register(chip, PPBUF_BASE2 + 4, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "Category register: 0x%x\n", val);
 	if (val != 0) {
 		ms_card->check_ms_flow = 1;
@@ -619,10 +700,18 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, PPBUF_BASE2 + 5, &val);
+	retval = rtsx_read_register(chip, PPBUF_BASE2 + 5, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "Class register: 0x%x\n", val);
 	if (val == 0) {
-		RTSX_READ_REG(chip, PPBUF_BASE2, &val);
+		retval = rtsx_read_register(chip, PPBUF_BASE2, &val);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		if (val & WRT_PRTCT)
 			chip->card_wp |= MS_CARD;
 		else
@@ -638,7 +727,11 @@ static int ms_identify_media_type(struct rtsx_chip *chip, int switch_8bit_bus)
 	ms_card->ms_type |= TYPE_MSPRO;
-	RTSX_READ_REG(chip, PPBUF_BASE2 + 3, &val);
+	retval = rtsx_read_register(chip, PPBUF_BASE2 + 3, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "IF Mode register: 0x%x\n", val);
 	if (val == 0) {
 		ms_card->ms_type &= 0x0F;
@@ -753,8 +846,12 @@ static int ms_switch_8bit_bus(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, MS_CFG, 0x98,
-		MS_BUS_WIDTH_8 | SAMPLE_TIME_FALLING);
+	retval = rtsx_write_register(chip, MS_CFG, 0x98,
+				     MS_BUS_WIDTH_8 | SAMPLE_TIME_FALLING);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	ms_card->ms_type |= MS_8BIT;
@@ -817,8 +914,17 @@ static int ms_pro_reset_flow(struct rtsx_chip *chip, int switch_8bit_bus)
 	/* Switch MS-PRO into Parallel mode */
-	RTSX_WRITE_REG(chip, MS_CFG, 0x18, MS_BUS_WIDTH_4);
-	RTSX_WRITE_REG(chip, MS_CFG, PUSH_TIME_ODD, PUSH_TIME_ODD);
+	retval = rtsx_write_register(chip, MS_CFG, 0x18, MS_BUS_WIDTH_4);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, MS_CFG, PUSH_TIME_ODD,
+				     PUSH_TIME_ODD);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -872,7 +978,11 @@ static int msxc_change_power(struct rtsx_chip *chip, u8 mode)
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, MS_TRANS_CFG, buf);
+	retval = rtsx_read_register(chip, MS_TRANS_CFG, buf);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (buf[0] & (MS_INT_CMDNK | MS_INT_ERR)) {
 		rtsx_trace(chip);
 		return STATUS_FAIL;
@@ -1775,7 +1885,11 @@ static int ms_copy_page(struct rtsx_chip *chip, u16 old_blk, u16 new_blk,
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (val & BUF_FULL) {
 		retval = ms_send_cmd(chip, CLEAR_BUF, WAIT_INT);
@@ -2070,7 +2184,11 @@ static int reset_ms(struct rtsx_chip *chip)
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	else
@@ -2238,8 +2356,16 @@ RE_SEARCH:
 			return STATUS_FAIL;
-		RTSX_WRITE_REG(chip, PPBUF_BASE2, 0xFF, 0x88);
-		RTSX_WRITE_REG(chip, PPBUF_BASE2 + 1, 0xFF, 0);
+		retval = rtsx_write_register(chip, PPBUF_BASE2, 0xFF, 0x88);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, PPBUF_BASE2 + 1, 0xFF, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		retval = ms_transfer_tpc(chip, MS_TM_WRITE_BYTES, WRITE_REG, 1,
 					NO_WAIT_INT);
@@ -2248,8 +2374,13 @@ RE_SEARCH:
 			return STATUS_FAIL;
-		RTSX_WRITE_REG(chip, MS_CFG, 0x58 | MS_NO_CHECK_INT,
-			MS_BUS_WIDTH_4 | PUSH_TIME_ODD | MS_NO_CHECK_INT);
+					     0x58 | MS_NO_CHECK_INT,
+					     MS_BUS_WIDTH_4 | PUSH_TIME_ODD | MS_NO_CHECK_INT);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		ms_card->ms_type |= MS_4BIT;
@@ -2869,7 +3000,11 @@ static int mspro_rw_multi_sector(struct scsi_cmnd *srb,
 	else
 		trans_mode = MS_TM_AUTO_WRITE;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (ms_card->seq_mode) {
 		if ((ms_card->pre_dir != srb->sc_data_direction)
@@ -3154,7 +3289,11 @@ int mspro_format(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, MS_TRANS_CFG, &tmp);
+	retval = rtsx_read_register(chip, MS_TRANS_CFG, &tmp);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (tmp & (MS_INT_CMDNK | MS_INT_ERR)) {
 		rtsx_trace(chip);
@@ -4616,10 +4755,19 @@ int ms_power_off_card3v3(struct rtsx_chip *chip)
 			return STATUS_FAIL;
 	} else {
-			FPGA_MS_PULL_CTL_BIT | 0x20, FPGA_MS_PULL_CTL_BIT);
+					     FPGA_MS_PULL_CTL_BIT);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+	retval = rtsx_write_register(chip, CARD_OE, MS_OUTPUT_EN, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_WRITE_REG(chip, CARD_OE, MS_OUTPUT_EN, 0);
 		retval = card_power_off(chip, MS_CARD);
diff --git a/drivers/staging/rts5208/rtsx_card.c b/drivers/staging/rts5208/rtsx_card.c
index d7ca44f..437436f 100644
--- a/drivers/staging/rts5208/rtsx_card.c
+++ b/drivers/staging/rts5208/rtsx_card.c
@@ -698,7 +698,11 @@ int switch_ssc_clock(struct rtsx_chip *chip, int clk)
 	udelay(10);
-	RTSX_WRITE_REG(chip, CLK_CTL, CLK_LOW_FREQ, 0);
+	retval = rtsx_write_register(chip, CLK_CTL, CLK_LOW_FREQ, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->cur_clk = clk;
@@ -707,6 +711,7 @@ int switch_ssc_clock(struct rtsx_chip *chip, int clk)
 int switch_normal_clock(struct rtsx_chip *chip, int clk)
+	int retval;
 	u8 sel, div, mcu_cnt;
 	int sd_vpclk_phase_reset = 0;
@@ -791,23 +796,58 @@ int switch_normal_clock(struct rtsx_chip *chip, int clk)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CLK_CTL, 0xFF, CLK_LOW_FREQ);
+	retval = rtsx_write_register(chip, CLK_CTL, 0xFF, CLK_LOW_FREQ);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (sd_vpclk_phase_reset) {
-		RTSX_WRITE_REG(chip, SD_VPCLK0_CTL, PHASE_NOT_RESET, 0);
-		RTSX_WRITE_REG(chip, SD_VPCLK1_CTL, PHASE_NOT_RESET, 0);
+		retval = rtsx_write_register(chip, SD_VPCLK0_CTL,
+					     PHASE_NOT_RESET, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, SD_VPCLK1_CTL,
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+	retval = rtsx_write_register(chip, CLK_DIV, 0xFF,
+				     (div << 4) | mcu_cnt);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, CLK_SEL, 0xFF, sel);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_WRITE_REG(chip, CLK_DIV, 0xFF, (div << 4) | mcu_cnt);
-	RTSX_WRITE_REG(chip, CLK_SEL, 0xFF, sel);
 		udelay(200);
-				PHASE_NOT_RESET);
-				PHASE_NOT_RESET);
+					     PHASE_NOT_RESET, PHASE_NOT_RESET);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		udelay(200);
-	RTSX_WRITE_REG(chip, CLK_CTL, 0xFF, 0);
+	retval = rtsx_write_register(chip, CLK_CTL, 0xFF, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -842,6 +882,7 @@ void trans_dma_enable(enum dma_data_direction dir, struct rtsx_chip *chip,
 int enable_card_clock(struct rtsx_chip *chip, u8 card)
+	int retval;
 	u8 clk_en = 0;
 	if (card & XD_CARD)
@@ -851,13 +892,18 @@ int enable_card_clock(struct rtsx_chip *chip, u8 card)
 	if (card & MS_CARD)
 		clk_en |= MS_CLK_EN;
-	RTSX_WRITE_REG(chip, CARD_CLK_EN, clk_en, clk_en);
+	retval = rtsx_write_register(chip, CARD_CLK_EN, clk_en, clk_en);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	return STATUS_SUCCESS;
 int disable_card_clock(struct rtsx_chip *chip, u8 card)
+	int retval;
 	u8 clk_en = 0;
 	if (card & XD_CARD)
@@ -867,7 +913,11 @@ int disable_card_clock(struct rtsx_chip *chip, u8 card)
 	if (card & MS_CARD)
-	RTSX_WRITE_REG(chip, CARD_CLK_EN, clk_en, 0);
+	retval = rtsx_write_register(chip, CARD_CLK_EN, clk_en, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -912,6 +962,7 @@ int card_power_on(struct rtsx_chip *chip, u8 card)
 int card_power_off(struct rtsx_chip *chip, u8 card)
+	int retval;
 	u8 mask, val;
 	if (CHECK_LUN_MODE(chip, SD_MS_2LUN) && (card == MS_CARD)) {
@@ -922,7 +973,11 @@ int card_power_off(struct rtsx_chip *chip, u8 card)
 		val = SD_POWER_OFF;
-	RTSX_WRITE_REG(chip, CARD_PWR_CTL, mask, val);
+	retval = rtsx_write_register(chip, CARD_PWR_CTL, mask, val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -972,6 +1027,7 @@ int card_rw(struct scsi_cmnd *srb, struct rtsx_chip *chip,
 int card_share_mode(struct rtsx_chip *chip, int card)
+	int retval;
 	u8 mask, value;
@@ -1005,7 +1061,11 @@ int card_share_mode(struct rtsx_chip *chip, int card)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CARD_SHARE_MODE, mask, value);
+	retval = rtsx_write_register(chip, CARD_SHARE_MODE, mask, value);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -1031,7 +1091,11 @@ int select_card(struct rtsx_chip *chip, int card)
 			return STATUS_FAIL;
-		RTSX_WRITE_REG(chip, CARD_SELECT, 0x07, mod);
+		retval = rtsx_write_register(chip, CARD_SELECT, 0x07, mod);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		chip->cur_card = card;
 		retval =  card_share_mode(chip, card);
diff --git a/drivers/staging/rts5208/rtsx_card.h b/drivers/staging/rts5208/rtsx_card.h
index 75cf588..8f2cf9a4e 100644
--- a/drivers/staging/rts5208/rtsx_card.h
+++ b/drivers/staging/rts5208/rtsx_card.h
@@ -1061,7 +1061,13 @@ int card_power_off(struct rtsx_chip *chip, u8 card);
 static inline int card_power_off_all(struct rtsx_chip *chip)
-	RTSX_WRITE_REG(chip, CARD_PWR_CTL, 0x0F, 0x0F);
+	int retval;
+	retval = rtsx_write_register(chip, CARD_PWR_CTL, 0x0F, 0x0F);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
diff --git a/drivers/staging/rts5208/rtsx_chip.c b/drivers/staging/rts5208/rtsx_chip.c
index a8feee8..0c1716e 100644
--- a/drivers/staging/rts5208/rtsx_chip.c
+++ b/drivers/staging/rts5208/rtsx_chip.c
@@ -116,22 +116,46 @@ void rtsx_disable_bus_int(struct rtsx_chip *chip)
 static int rtsx_pre_handle_sdio_old(struct rtsx_chip *chip)
+	int retval;
 	if (chip->ignore_sd && CHK_SDIO_EXIST(chip)) {
-				       MS_INS_PU | SD_WP_PU |
-				       SD_CD_PU | SD_CMD_PU);
+						     0xFF,
+						     MS_INS_PU | SD_WP_PU | SD_CD_PU | SD_CMD_PU);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 		} else {
-			RTSX_WRITE_REG(chip, FPGA_PULL_CTL, 0xFF,
-				       FPGA_SD_PULL_CTL_EN);
+						     0xFF,
+						     FPGA_SD_PULL_CTL_EN);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+		retval = rtsx_write_register(chip, CARD_SHARE_MODE, 0xFF,
+					     CARD_SHARE_48_SD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
-		RTSX_WRITE_REG(chip, CARD_SHARE_MODE, 0xFF, CARD_SHARE_48_SD);
 		/* Enable SDIO internal clock */
-		RTSX_WRITE_REG(chip, 0xFF2C, 0x01, 0x01);
+		retval = rtsx_write_register(chip, 0xFF2C, 0x01, 0x01);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
-		RTSX_WRITE_REG(chip, SDIO_CTRL, 0xFF,
-			       SDIO_BUS_CTRL | SDIO_CD_CTRL);
+		retval = rtsx_write_register(chip, SDIO_CTRL, 0xFF,
+					     SDIO_BUS_CTRL | SDIO_CD_CTRL);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		chip->sd_int = 1;
 		chip->sd_io = 1;
@@ -151,11 +175,19 @@ static int rtsx_pre_handle_sdio_new(struct rtsx_chip *chip)
 	if (chip->driver_first_load) {
-			RTSX_READ_REG(chip, 0xFE5A, &tmp);
+			retval = rtsx_read_register(chip, 0xFE5A, &tmp);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			if (tmp & 0x08)
 				sw_bypass_sd = true;
 		} else if (CHECK_PID(chip, 0x5208)) {
-			RTSX_READ_REG(chip, 0xFE70, &tmp);
+			retval = rtsx_read_register(chip, 0xFE70, &tmp);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			if (tmp & 0x80)
@@ -173,17 +205,37 @@ static int rtsx_pre_handle_sdio_new(struct rtsx_chip *chip)
 	if (sw_bypass_sd) {
 		u8 cd_toggle_mask = 0;
-		RTSX_READ_REG(chip, TLPTISTAT, &tmp);
+		retval = rtsx_read_register(chip, TLPTISTAT, &tmp);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		cd_toggle_mask = 0x08;
 		if (tmp & cd_toggle_mask) {
 			/* Disable sdio_bus_auto_switch */
-			if (CHECK_PID(chip, 0x5288))
-				RTSX_WRITE_REG(chip, 0xFE5A, 0x08, 0x00);
-			else if (CHECK_PID(chip, 0x5208))
-				RTSX_WRITE_REG(chip, 0xFE70, 0x80, 0x00);
+			if (CHECK_PID(chip, 0x5288)) {
+				retval = rtsx_write_register(chip, 0xFE5A,
+							     0x08, 0x00);
+				if (retval) {
+					rtsx_trace(chip);
+					return retval;
+			} else if (CHECK_PID(chip, 0x5208)) {
+				retval = rtsx_write_register(chip, 0xFE70,
+							     0x80, 0x00);
+				if (retval) {
+					rtsx_trace(chip);
+					return retval;
-			RTSX_WRITE_REG(chip, TLPTISTAT, 0xFF, tmp);
+			retval = rtsx_write_register(chip, TLPTISTAT, 0xFF,
+						     tmp);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			chip->need_reset |= SD_CARD;
 		} else {
@@ -196,8 +248,14 @@ static int rtsx_pre_handle_sdio_new(struct rtsx_chip *chip)
 					return STATUS_FAIL;
 			} else {
-					       FPGA_SD_PULL_CTL_BIT | 0x20, 0);
+							     FPGA_PULL_CTL,
+							     FPGA_SD_PULL_CTL_BIT | 0x20,
+							     0);
+				if (retval) {
+					rtsx_trace(chip);
+					return retval;
 			retval = card_share_mode(chip, SD_CARD);
@@ -206,16 +264,31 @@ static int rtsx_pre_handle_sdio_new(struct rtsx_chip *chip)
 			/* Enable sdio_bus_auto_switch */
-				RTSX_WRITE_REG(chip, 0xFE5A, 0x08, 0x08);
-				RTSX_WRITE_REG(chip, 0xFE70, 0x80, 0x80);
+							     0x08, 0x08);
+				if (retval) {
+					rtsx_trace(chip);
+					return retval;
+							     0x80, 0x80);
+				if (retval) {
+					rtsx_trace(chip);
+					return retval;
 			chip->chip_insert_with_sdio = 1;
 			chip->sd_io = 1;
 	} else {
-		RTSX_WRITE_REG(chip, TLPTISTAT, 0x08, 0x08);
+		retval = rtsx_write_register(chip, TLPTISTAT, 0x08, 0x08);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
@@ -242,8 +315,13 @@ static int rtsx_reset_aspm(struct rtsx_chip *chip)
-	if (CHECK_PID(chip, 0x5208))
-		RTSX_WRITE_REG(chip, ASPM_FORCE_CTL, 0xFF, 0x3F);
+	if (CHECK_PID(chip, 0x5208)) {
+		ret = rtsx_write_register(chip, ASPM_FORCE_CTL, 0xFF, 0x3F);
+		if (ret) {
+			rtsx_trace(chip);
+			return ret;
 	ret = rtsx_write_config_byte(chip, LCTLR, chip->aspm_l0s_l1_en);
 	if (ret != STATUS_SUCCESS) {
 		rtsx_trace(chip);
@@ -276,7 +354,11 @@ static int rtsx_enable_pcie_intr(struct rtsx_chip *chip)
 	if (chip->phy_debug_mode) {
-		RTSX_WRITE_REG(chip, CDRESUMECTL, 0x77, 0);
+		ret = rtsx_write_register(chip, CDRESUMECTL, 0x77, 0);
+		if (ret) {
+			rtsx_trace(chip);
+			return ret;
 		rtsx_disable_bus_int(chip);
 	} else {
 		rtsx_enable_bus_int(chip);
@@ -327,47 +409,116 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 	rtsx_disable_aspm(chip);
-	RTSX_WRITE_REG(chip, HOST_SLEEP_STATE, 0x03, 0x00);
+	retval = rtsx_write_register(chip, HOST_SLEEP_STATE, 0x03, 0x00);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	/* Disable card clock */
-	RTSX_WRITE_REG(chip, CARD_CLK_EN, 0x1E, 0);
+	retval = rtsx_write_register(chip, CARD_CLK_EN, 0x1E, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 #ifdef SUPPORT_OCP
 	/* SSC power on, OCD power on */
-	if (CHECK_LUN_MODE(chip, SD_MS_2LUN))
-		RTSX_WRITE_REG(chip, FPDCTL, OC_POWER_DOWN, 0);
-	else
-		RTSX_WRITE_REG(chip, FPDCTL, OC_POWER_DOWN, MS_OC_POWER_DOWN);
+	if (CHECK_LUN_MODE(chip, SD_MS_2LUN)) {
+		retval = rtsx_write_register(chip, FPDCTL, OC_POWER_DOWN, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+	} else {
+					     MS_OC_POWER_DOWN);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
-	RTSX_WRITE_REG(chip, OCPPARA1, OCP_TIME_MASK, OCP_TIME_800);
-	RTSX_WRITE_REG(chip, OCPPARA2, OCP_THD_MASK, OCP_THD_244_946);
-	RTSX_WRITE_REG(chip, OCPCTL, 0xFF, CARD_OC_INT_EN | CARD_DETECT_EN);
+	retval = rtsx_write_register(chip, OCPPARA1, OCP_TIME_MASK,
+				     OCP_TIME_800);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, OCPPARA2, OCP_THD_MASK,
+				     OCP_THD_244_946);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, OCPCTL, 0xFF,
+				     CARD_OC_INT_EN | CARD_DETECT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 #else
 	/* OC power down */
-	RTSX_WRITE_REG(chip, FPDCTL, OC_POWER_DOWN, OC_POWER_DOWN);
+				     OC_POWER_DOWN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 #endif
-	if (!CHECK_PID(chip, 0x5288))
-		RTSX_WRITE_REG(chip, CARD_GPIO_DIR, 0xFF, 0x03);
+	if (!CHECK_PID(chip, 0x5288)) {
+		retval = rtsx_write_register(chip, CARD_GPIO_DIR, 0xFF, 0x03);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	/* Turn off LED */
-	RTSX_WRITE_REG(chip, CARD_GPIO, 0xFF, 0x03);
+	retval = rtsx_write_register(chip, CARD_GPIO, 0xFF, 0x03);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	/* Reset delink mode */
-	RTSX_WRITE_REG(chip, CHANGE_LINK_STATE, 0x0A, 0);
+	retval = rtsx_write_register(chip, CHANGE_LINK_STATE, 0x0A, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	/* Card driving select */
-	RTSX_WRITE_REG(chip, CARD_DRIVE_SEL, 0xFF, chip->card_drive_sel);
+	retval = rtsx_write_register(chip, CARD_DRIVE_SEL, 0xFF,
+				     chip->card_drive_sel);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 #ifdef LED_AUTO_BLINK
-	RTSX_WRITE_REG(chip, CARD_AUTO_BLINK, 0xFF,
-		       LED_BLINK_SPEED | BLINK_EN | LED_GPIO0);
+	retval = rtsx_write_register(chip, CARD_AUTO_BLINK, 0xFF,
+				     LED_BLINK_SPEED | BLINK_EN | LED_GPIO0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 #endif
 		/* Enable SSC Clock */
-		RTSX_WRITE_REG(chip, SSC_CTL1, 0xFF, SSC_8X_EN | SSC_SEL_4M);
-		RTSX_WRITE_REG(chip, SSC_CTL2, 0xFF, 0x12);
+		retval = rtsx_write_register(chip, SSC_CTL1, 0xFF,
+					     SSC_8X_EN | SSC_SEL_4M);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, SSC_CTL2, 0xFF, 0x12);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	/* Disable cd_pwr_save (u_force_rst_core_en=0, u_cd_rst_core_en=0)
@@ -377,7 +528,11 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 	      bit[5]    u_mac_phy_rst_n_dbg	rst_value = 1
 	      bit[4]	u_non_sticky_rst_n_dbg	rst_value = 0
-	RTSX_WRITE_REG(chip, CHANGE_LINK_STATE, 0x16, 0x10);
+	retval = rtsx_write_register(chip, CHANGE_LINK_STATE, 0x16, 0x10);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	/* Enable ASPM */
 	if (chip->aspm_l0s_l1_en) {
@@ -433,9 +588,18 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
-	RTSX_WRITE_REG(chip, IRQSTAT0, LINK_RDY_INT, LINK_RDY_INT);
+	retval = rtsx_write_register(chip, IRQSTAT0, LINK_RDY_INT,
+				     LINK_RDY_INT);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_WRITE_REG(chip, PERST_GLITCH_WIDTH, 0xFF, 0x80);
+	retval = rtsx_write_register(chip, PERST_GLITCH_WIDTH, 0xFF, 0x80);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = rtsx_enable_pcie_intr(chip);
@@ -470,8 +634,12 @@ int rtsx_reset_chip(struct rtsx_chip *chip)
 	} else {
 		chip->sd_io = 0;
-		RTSX_WRITE_REG(chip, SDIO_CTRL, SDIO_BUS_CTRL | SDIO_CD_CTRL,
-			       0);
+					     SDIO_BUS_CTRL | SDIO_CD_CTRL, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 nextcard:
@@ -479,30 +647,68 @@ nextcard:
 		chip->need_reset |= XD_CARD;
 	if (chip->int_reg & MS_EXIST)
 		chip->need_reset |= MS_CARD;
-	if (chip->int_reg & CARD_EXIST)
-		RTSX_WRITE_REG(chip, SSC_CTL1, SSC_RSTB, SSC_RSTB);
+	if (chip->int_reg & CARD_EXIST) {
+		retval = rtsx_write_register(chip, SSC_CTL1, SSC_RSTB,
+					     SSC_RSTB);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	dev_dbg(rtsx_dev(chip), "In %s, chip->need_reset = 0x%x\n", __func__,
 		(unsigned int)(chip->need_reset));
-	RTSX_WRITE_REG(chip, RCCTL, 0x01, 0x00);
+	retval = rtsx_write_register(chip, RCCTL, 0x01, 0x00);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (CHECK_PID(chip, 0x5208) || CHECK_PID(chip, 0x5288)) {
 		/* Turn off main power when entering S3/S4 state */
-		RTSX_WRITE_REG(chip, MAIN_PWR_OFF_CTL, 0x03, 0x03);
+		retval = rtsx_write_register(chip, MAIN_PWR_OFF_CTL, 0x03,
+					     0x03);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	if (chip->remote_wakeup_en && !chip->auto_delink_en) {
-		RTSX_WRITE_REG(chip, WAKE_SEL_CTL, 0x07, 0x07);
-		if (chip->aux_pwr_exist)
-			RTSX_WRITE_REG(chip, PME_FORCE_CTL, 0xFF, 0x33);
+		retval = rtsx_write_register(chip, WAKE_SEL_CTL, 0x07, 0x07);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (chip->aux_pwr_exist) {
+			retval = rtsx_write_register(chip, PME_FORCE_CTL,
+						     0xFF, 0x33);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 	} else {
-		RTSX_WRITE_REG(chip, WAKE_SEL_CTL, 0x07, 0x04);
-		RTSX_WRITE_REG(chip, PME_FORCE_CTL, 0xFF, 0x30);
+		retval = rtsx_write_register(chip, WAKE_SEL_CTL, 0x07, 0x04);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, PME_FORCE_CTL, 0xFF, 0x30);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
-	if (CHECK_PID(chip, 0x5208) && (chip->ic_version >= IC_VER_D))
-		RTSX_WRITE_REG(chip, PETXCFG, 0x1C, 0x14);
+	if (CHECK_PID(chip, 0x5208) && (chip->ic_version >= IC_VER_D)) {
+		retval = rtsx_write_register(chip, PETXCFG, 0x1C, 0x14);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	if (chip->asic_code && CHECK_PID(chip, 0x5208)) {
 		retval = rtsx_clr_phy_reg_bit(chip, 0x1C, 2);
@@ -513,11 +719,19 @@ nextcard:
 	if (chip->ft2_fast_mode) {
-		RTSX_WRITE_REG(chip, CARD_PWR_CTL, 0xFF,
-			       MS_PARTIAL_POWER_ON | SD_PARTIAL_POWER_ON);
+		retval = rtsx_write_register(chip, CARD_PWR_CTL, 0xFF,
+					     MS_PARTIAL_POWER_ON | SD_PARTIAL_POWER_ON);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		udelay(chip->pmos_pwr_on_interval);
-			       MS_POWER_ON | SD_POWER_ON);
+					     MS_POWER_ON | SD_POWER_ON);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		wait_timeout(200);
@@ -570,8 +784,16 @@ static int rts5208_init(struct rtsx_chip *chip)
 	u16 reg = 0;
 	u8 val = 0;
-	RTSX_WRITE_REG(chip, CLK_SEL, 0x03, 0x03);
-	RTSX_READ_REG(chip, CLK_SEL, &val);
+	retval = rtsx_write_register(chip, CLK_SEL, 0x03, 0x03);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_read_register(chip, CLK_SEL, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->asic_code = val == 0 ? 1 : 0;
@@ -587,16 +809,28 @@ static int rts5208_init(struct rtsx_chip *chip)
 		chip->phy_debug_mode = reg & PHY_DEBUG_MODE ? 1 : 0;
 	} else {
-		RTSX_READ_REG(chip, 0xFE80, &val);
+		retval = rtsx_read_register(chip, 0xFE80, &val);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		chip->ic_version = val;
 		chip->phy_debug_mode = 0;
-	RTSX_READ_REG(chip, PDINFO, &val);
+	retval = rtsx_read_register(chip, PDINFO, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "PDINFO: 0x%x\n", val);
 	chip->aux_pwr_exist = val & AUX_PWR_DETECTED ? 1 : 0;
-	RTSX_READ_REG(chip, 0xFE50, &val);
+	retval = rtsx_read_register(chip, 0xFE50, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->hw_bypass_sd = val & 0x01 ? 1 : 0;
 	rtsx_read_config_byte(chip, 0x0E, &val);
@@ -606,7 +840,11 @@ static int rts5208_init(struct rtsx_chip *chip)
 		CLR_SDIO_EXIST(chip);
 	if (chip->use_hw_setting) {
-		RTSX_READ_REG(chip, CHANGE_LINK_STATE, &val);
+		retval = rtsx_read_register(chip, CHANGE_LINK_STATE, &val);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		chip->auto_delink_en = val & 0x80 ? 1 : 0;
@@ -619,22 +857,42 @@ static int rts5288_init(struct rtsx_chip *chip)
 	u8 val = 0, max_func;
 	u32 lval = 0;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->ic_version = 0;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_READ_REG(chip, CARD_SHARE_MODE, &val);
+	retval = rtsx_read_register(chip, CARD_SHARE_MODE, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "CARD_SHARE_MODE: 0x%x\n", val);
 	chip->baro_pkg = val & 0x04 ? QFN : LQFP;
-	RTSX_READ_REG(chip, 0xFE5A, &val);
+	retval = rtsx_read_register(chip, 0xFE5A, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->hw_bypass_sd = val & 0x10 ? 1 : 0;
 	retval = rtsx_read_cfg_dw(chip, 0, 0x718, &lval);
@@ -651,7 +909,11 @@ static int rts5288_init(struct rtsx_chip *chip)
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		if (CHECK_BARO_PKG(chip, LQFP))
@@ -730,9 +992,17 @@ int rtsx_init_chip(struct rtsx_chip *chip)
 	if ((chip->mmc_ddr_tx_phase > 31) || (chip->mmc_ddr_tx_phase < 0))
 		chip->mmc_ddr_tx_phase = 0;
-	RTSX_WRITE_REG(chip, FPDCTL, SSC_POWER_DOWN, 0);
+	retval = rtsx_write_register(chip, FPDCTL, SSC_POWER_DOWN, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	wait_timeout(200);
-	RTSX_WRITE_REG(chip, CLK_DIV, 0x07, 0x07);
+	retval = rtsx_write_register(chip, CLK_DIV, 0x07, 0x07);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "chip->use_hw_setting = %d\n",
 		chip->use_hw_setting);
@@ -1241,13 +1511,19 @@ int rtsx_read_register(struct rtsx_chip *chip, u16 addr, u8 *data)
 int rtsx_write_cfg_dw(struct rtsx_chip *chip, u8 func_no, u16 addr, u32 mask,
 		      u32 val)
+	int retval;
 	u8 mode = 0, tmp;
 	int i;
 	for (i = 0; i < 4; i++) {
 		if (mask & 0xFF) {
-			RTSX_WRITE_REG(chip, CFGDATA0 + i,
-				       0xFF, (u8)(val & mask & 0xFF));
+			retval = rtsx_write_register(chip, CFGDATA0 + i,
+						     0xFF,
+						     (u8)(val & mask & 0xFF));
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			mode |= (1 << i);
 		mask >>= 8;
@@ -1255,14 +1531,31 @@ int rtsx_write_cfg_dw(struct rtsx_chip *chip, u8 func_no, u16 addr, u32 mask,
 	if (mode) {
-		RTSX_WRITE_REG(chip, CFGADDR0, 0xFF, (u8)addr);
-		RTSX_WRITE_REG(chip, CFGADDR1, 0xFF, (u8)(addr >> 8));
+		retval = rtsx_write_register(chip, CFGADDR0, 0xFF, (u8)addr);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CFGADDR1, 0xFF,
+					     (u8)(addr >> 8));
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
-		RTSX_WRITE_REG(chip, CFGRWCTL, 0xFF,
-			       0x80 | mode | ((func_no & 0x03) << 4));
+		retval = rtsx_write_register(chip, CFGRWCTL, 0xFF,
+					     0x80 | mode | ((func_no & 0x03) << 4));
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		for (i = 0; i < MAX_RW_REG_CNT; i++) {
-			RTSX_READ_REG(chip, CFGRWCTL, &tmp);
+			retval = rtsx_read_register(chip, CFGRWCTL, &tmp);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			if ((tmp & 0x80) == 0)
 				break;
@@ -1273,22 +1566,44 @@ int rtsx_write_cfg_dw(struct rtsx_chip *chip, u8 func_no, u16 addr, u32 mask,
 int rtsx_read_cfg_dw(struct rtsx_chip *chip, u8 func_no, u16 addr, u32 *val)
+	int retval;
 	int i;
 	u8 tmp;
 	u32 data = 0;
-	RTSX_WRITE_REG(chip, CFGRWCTL, 0xFF, 0x80 | ((func_no & 0x03) << 4));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, CFGADDR1, 0xFF, (u8)(addr >> 8));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+				     0x80 | ((func_no & 0x03) << 4));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 			break;
-		RTSX_READ_REG(chip, CFGDATA0 + i, &tmp);
+		retval = rtsx_read_register(chip, CFGDATA0 + i, &tmp);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		data |= (u32)tmp << (i * 8);
@@ -1415,17 +1730,38 @@ int rtsx_read_cfg_seq(struct rtsx_chip *chip, u8 func, u16 addr, u8 *buf,
 int rtsx_write_phy_register(struct rtsx_chip *chip, u8 addr, u16 val)
+	int retval;
 	bool finished = false;
 	int i;
 	u8 tmp;
-	RTSX_WRITE_REG(chip, PHYDATA0, 0xFF, (u8)val);
-	RTSX_WRITE_REG(chip, PHYDATA1, 0xFF, (u8)(val >> 8));
-	RTSX_WRITE_REG(chip, PHYADDR, 0xFF, addr);
-	RTSX_WRITE_REG(chip, PHYRWCTL, 0xFF, 0x81);
+	retval = rtsx_write_register(chip, PHYDATA0, 0xFF, (u8)val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, PHYDATA1, 0xFF, (u8)(val >> 8));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, PHYADDR, 0xFF, addr);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, PHYRWCTL, 0xFF, 0x81);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	for (i = 0; i < 100000; i++) {
-		RTSX_READ_REG(chip, PHYRWCTL, &tmp);
+		retval = rtsx_read_register(chip, PHYRWCTL, &tmp);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		if (!(tmp & 0x80)) {
 			finished = true;
 			break;
@@ -1442,16 +1778,29 @@ int rtsx_write_phy_register(struct rtsx_chip *chip, u8 addr, u16 val)
 int rtsx_read_phy_register(struct rtsx_chip *chip, u8 addr, u16 *val)
+	int retval;
 	int i;
 	u16 data = 0;
 	u8 tmp;
-	RTSX_WRITE_REG(chip, PHYRWCTL, 0xFF, 0x80);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, PHYRWCTL, 0xFF, 0x80);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 			finished = true;
 			break;
@@ -1463,9 +1812,17 @@ int rtsx_read_phy_register(struct rtsx_chip *chip, u8 addr, u16 *val)
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, PHYDATA0, &tmp);
+	retval = rtsx_read_register(chip, PHYDATA0, &tmp);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	data = tmp;
-	RTSX_READ_REG(chip, PHYDATA1, &tmp);
+	retval = rtsx_read_register(chip, PHYDATA1, &tmp);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	data |= (u16)tmp << 8;
 	if (val)
@@ -1476,13 +1833,22 @@ int rtsx_read_phy_register(struct rtsx_chip *chip, u8 addr, u16 *val)
 int rtsx_read_efuse(struct rtsx_chip *chip, u8 addr, u8 *val)
+	int retval;
 	int i;
 	u8 data = 0;
-	RTSX_WRITE_REG(chip, EFUSE_CTRL, 0xFF, 0x80|addr);
+	retval = rtsx_write_register(chip, EFUSE_CTRL, 0xFF, 0x80 | addr);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	for (i = 0; i < 100; i++) {
-		RTSX_READ_REG(chip, EFUSE_CTRL, &data);
+		retval = rtsx_read_register(chip, EFUSE_CTRL, &data);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		if (!(data & 0x80))
 			break;
 		udelay(1);
@@ -1493,7 +1859,11 @@ int rtsx_read_efuse(struct rtsx_chip *chip, u8 addr, u8 *val)
 		return STATUS_TIMEDOUT;
-	RTSX_READ_REG(chip, EFUSE_DATA, &data);
+	retval = rtsx_read_register(chip, EFUSE_DATA, &data);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (val)
 		*val = data;
@@ -1502,6 +1872,7 @@ int rtsx_read_efuse(struct rtsx_chip *chip, u8 addr, u8 *val)
 int rtsx_write_efuse(struct rtsx_chip *chip, u8 addr, u8 val)
+	int retval;
 	int i, j;
 	u8 data = 0, tmp = 0xFF;
@@ -1512,11 +1883,24 @@ int rtsx_write_efuse(struct rtsx_chip *chip, u8 addr, u8 val)
 		tmp &= (~(u8)(1 << i));
 		dev_dbg(rtsx_dev(chip), "Write 0x%x to 0x%x\n", tmp, addr);
-		RTSX_WRITE_REG(chip, EFUSE_DATA, 0xFF, tmp);
-		RTSX_WRITE_REG(chip, EFUSE_CTRL, 0xFF, 0xA0|addr);
+		retval = rtsx_write_register(chip, EFUSE_DATA, 0xFF, tmp);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     0xA0 | addr);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		for (j = 0; j < 100; j++) {
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			if (!(data & 0x80))
 				break;
 			wait_timeout(3);
@@ -1581,9 +1965,14 @@ int rtsx_set_phy_reg_bit(struct rtsx_chip *chip, u8 reg, u8 bit)
 int rtsx_check_link_ready(struct rtsx_chip *chip)
+	int retval;
 	u8 val;
-	RTSX_READ_REG(chip, IRQSTAT0, &val);
+	retval = rtsx_read_register(chip, IRQSTAT0, &val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "IRQSTAT0: 0x%x\n", val);
 	if (val & LINK_RDY_INT) {
diff --git a/drivers/staging/rts5208/rtsx_chip.h b/drivers/staging/rts5208/rtsx_chip.h
index 93fd7b2..c295b1e 100644
--- a/drivers/staging/rts5208/rtsx_chip.h
+++ b/drivers/staging/rts5208/rtsx_chip.h
@@ -988,22 +988,4 @@ int rtsx_read_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len);
 int rtsx_write_ppbuf(struct rtsx_chip *chip, u8 *buf, int buf_len);
 int rtsx_check_chip_exist(struct rtsx_chip *chip);
-#define RTSX_WRITE_REG(chip, addr, mask, data)				\
-do {									\
-	int retval = rtsx_write_register(chip, addr, mask, data);	\
-	if (retval != STATUS_SUCCESS) {					\
-		rtsx_trace(chip);					\
-		return retval;						\
-} while (0)
-#define RTSX_READ_REG(chip, addr, data)					\
-do {									\
-	int retval = rtsx_read_register(chip, addr, data);		\
-		return retval;						\
-} while (0)
 #endif  /* __REALTEK_RTSX_CHIP_H */
diff --git a/drivers/staging/rts5208/sd.c b/drivers/staging/rts5208/sd.c
index 0eee676..a8d657b 100644
--- a/drivers/staging/rts5208/sd.c
+++ b/drivers/staging/rts5208/sd.c
@@ -105,9 +105,14 @@ static void sd_init_reg_addr(struct rtsx_chip *chip)
 static int sd_check_data0_status(struct rtsx_chip *chip)
+	int retval;
 	u8 stat;
-	RTSX_READ_REG(chip, REG_SD_STAT1, &stat);
+	retval = rtsx_read_register(chip, REG_SD_STAT1, &stat);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (!(stat & SD_DAT0_STATUS)) {
 		sd_set_err_code(chip, SD_BUSY);
@@ -529,8 +534,8 @@ static int sd_check_csd(struct rtsx_chip *chip, char check_wp)
 static int sd_set_sample_push_timing(struct rtsx_chip *chip)
+	int retval;
 	struct sd_info *sd_card = &(chip->sd_card);
 	u8 val = 0;
 	if ((chip->sd_ctl & SD_PUSH_POINT_CTL_MASK) == SD_PUSH_POINT_DELAY)
@@ -558,7 +563,11 @@ static int sd_set_sample_push_timing(struct rtsx_chip *chip)
 			val |= 0x08;
-	RTSX_WRITE_REG(chip, REG_SD_CFG1, 0x1C, val);
+	retval = rtsx_write_register(chip, REG_SD_CFG1, 0x1C, val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -607,6 +616,7 @@ static void sd_choose_proper_clock(struct rtsx_chip *chip)
 static int sd_set_clock_divider(struct rtsx_chip *chip, u8 clk_div)
+	int retval;
 	u8 mask = 0, val = 0;
 	mask = 0x60;
@@ -617,7 +627,11 @@ static int sd_set_clock_divider(struct rtsx_chip *chip, u8 clk_div)
 	else if (clk_div == SD_CLK_DIVIDE_256)
 		val = 0x20;
-	RTSX_WRITE_REG(chip, REG_SD_CFG1, mask, val);
+	retval = rtsx_write_register(chip, REG_SD_CFG1, mask, val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -740,7 +754,12 @@ static int sd_change_bank_voltage(struct rtsx_chip *chip, u8 voltage)
 				return STATUS_FAIL;
 		} else {
-			RTSX_WRITE_REG(chip, SD_PAD_CTL, SD_IO_USING_1V8, 0);
+			retval = rtsx_write_register(chip, SD_PAD_CTL,
+						     SD_IO_USING_1V8, 0);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 	} else if (voltage == SD_IO_1V8) {
@@ -752,8 +771,13 @@ static int sd_change_bank_voltage(struct rtsx_chip *chip, u8 voltage)
 				return STATUS_FAIL;
 		} else {
-				SD_IO_USING_1V8);
+						     SD_IO_USING_1V8,
+						     SD_IO_USING_1V8);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 	} else {
 		rtsx_trace(chip);
@@ -768,8 +792,13 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 	int retval;
 	u8 stat;
-	RTSX_WRITE_REG(chip, SD_BUS_STAT, SD_CLK_TOGGLE_EN | SD_CLK_FORCE_STOP,
-		SD_CLK_TOGGLE_EN);
+	retval = rtsx_write_register(chip, SD_BUS_STAT,
+				     SD_CLK_TOGGLE_EN | SD_CLK_FORCE_STOP,
+				     SD_CLK_TOGGLE_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = sd_send_cmd_get_rsp(chip, VOLTAGE_SWITCH, 0, SD_RSP_TYPE_R1,
 				NULL, 0);
@@ -780,14 +809,23 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 	udelay(chip->sd_voltage_switch_delay);
-	RTSX_READ_REG(chip, SD_BUS_STAT, &stat);
+	retval = rtsx_read_register(chip, SD_BUS_STAT, &stat);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (stat & (SD_CMD_STATUS | SD_DAT3_STATUS | SD_DAT2_STATUS |
 				SD_DAT1_STATUS | SD_DAT0_STATUS)) {
 		rtsx_trace(chip);
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, SD_BUS_STAT, 0xFF, SD_CLK_FORCE_STOP);
+	retval = rtsx_write_register(chip, SD_BUS_STAT, 0xFF,
+				     SD_CLK_FORCE_STOP);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = sd_change_bank_voltage(chip, SD_IO_1V8);
 		rtsx_trace(chip);
@@ -796,10 +834,19 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 	wait_timeout(50);
-	RTSX_WRITE_REG(chip, SD_BUS_STAT, 0xFF, SD_CLK_TOGGLE_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	wait_timeout(10);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if ((stat & (SD_CMD_STATUS | SD_DAT3_STATUS | SD_DAT2_STATUS |
 				SD_DAT1_STATUS | SD_DAT0_STATUS)) !=
@@ -812,20 +859,44 @@ static int sd_voltage_switch(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-		0);
+				     SD_CLK_TOGGLE_EN | SD_CLK_FORCE_STOP, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 static int sd_reset_dcm(struct rtsx_chip *chip, u8 tune_dir)
+	int retval;
 	if (tune_dir == TUNE_RX) {
-		RTSX_WRITE_REG(chip, DCM_DRP_CTL, 0xFF, DCM_RESET | DCM_RX);
-		RTSX_WRITE_REG(chip, DCM_DRP_CTL, 0xFF, DCM_RX);
+		retval = rtsx_write_register(chip, DCM_DRP_CTL, 0xFF,
+					     DCM_RESET | DCM_RX);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, DCM_DRP_CTL, 0xFF, DCM_RX);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	} else {
-		RTSX_WRITE_REG(chip, DCM_DRP_CTL, 0xFF, DCM_RESET | DCM_TX);
-		RTSX_WRITE_REG(chip, DCM_DRP_CTL, 0xFF, DCM_TX);
+					     DCM_RESET | DCM_TX);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, DCM_DRP_CTL, 0xFF, DCM_TX);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
@@ -853,12 +924,35 @@ static int sd_change_phase(struct rtsx_chip *chip, u8 sample_point, u8 tune_dir)
-		RTSX_WRITE_REG(chip, CLK_CTL, CHANGE_CLK, CHANGE_CLK);
-		RTSX_WRITE_REG(chip, SD_VP_CTL, 0x1F, sample_point);
-			PHASE_NOT_RESET);
-		RTSX_WRITE_REG(chip, CLK_CTL, CHANGE_CLK, 0);
+		retval = rtsx_write_register(chip, CLK_CTL, CHANGE_CLK,
+					     CHANGE_CLK);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, SD_VP_CTL, 0x1F,
+					     sample_point);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, CLK_CTL, CHANGE_CLK, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 	} else {
 		rtsx_read_register(chip, SD_VP_CTL, &val);
 		dev_dbg(rtsx_dev(chip), "SD_VP_CTL: 0x%x\n", val);
@@ -866,16 +960,34 @@ static int sd_change_phase(struct rtsx_chip *chip, u8 sample_point, u8 tune_dir)
 		dev_dbg(rtsx_dev(chip), "SD_DCMPS_CTL: 0x%x\n", val);
 		if (ddr_rx) {
-			RTSX_WRITE_REG(chip, SD_VP_CTL, PHASE_CHANGE,
-				PHASE_CHANGE);
+						     PHASE_CHANGE,
+						     PHASE_CHANGE);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			udelay(50);
-			RTSX_WRITE_REG(chip, SD_VP_CTL, 0xFF,
-				PHASE_CHANGE | PHASE_NOT_RESET | sample_point);
+			retval = rtsx_write_register(chip, SD_VP_CTL, 0xFF,
+						     PHASE_CHANGE | PHASE_NOT_RESET | sample_point);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 		} else {
+						     CHANGE_CLK, CHANGE_CLK);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			udelay(50);
-					PHASE_NOT_RESET | sample_point);
+						     PHASE_NOT_RESET | sample_point);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 		udelay(100);
@@ -901,16 +1013,36 @@ static int sd_change_phase(struct rtsx_chip *chip, u8 sample_point, u8 tune_dir)
 			goto Fail;
-		RTSX_WRITE_REG(chip, SD_DCMPS_CTL, DCMPS_CHANGE, 0);
-		if (ddr_rx)
-			RTSX_WRITE_REG(chip, SD_VP_CTL, PHASE_CHANGE, 0);
-		else
+		retval = rtsx_write_register(chip, SD_DCMPS_CTL,
+					     DCMPS_CHANGE, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (ddr_rx) {
+						     PHASE_CHANGE, 0);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+		} else {
+						     CHANGE_CLK, 0);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 		udelay(50);
-	RTSX_WRITE_REG(chip, SD_CFG1, SD_ASYNC_FIFO_NOT_RST, 0);
+	retval = rtsx_write_register(chip, SD_CFG1, SD_ASYNC_FIFO_NOT_RST, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -1160,10 +1292,20 @@ static int sd_check_switch_mode(struct rtsx_chip *chip, u8 mode,
 		if ((cc > 400) || (func_to_switch > CURRENT_LIMIT_400)) {
-			RTSX_WRITE_REG(chip, OCPPARA2, SD_OCP_THD_MASK,
-				chip->sd_800mA_ocp_thd);
-			RTSX_WRITE_REG(chip, CARD_PWR_CTL, PMOS_STRG_MASK,
-				PMOS_STRG_800mA);
+						     SD_OCP_THD_MASK,
+						     chip->sd_800mA_ocp_thd);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     PMOS_STRG_MASK,
+						     PMOS_STRG_800mA);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
@@ -1210,7 +1352,11 @@ static int sd_check_switch(struct rtsx_chip *chip,
 				break;
-			RTSX_READ_REG(chip, SD_STAT1, &stat);
+			retval = rtsx_read_register(chip, SD_STAT1, &stat);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			if (stat & SD_CRC16_ERR) {
 				dev_dbg(rtsx_dev(chip), "SD CRC16 error when switching mode\n");
 				rtsx_trace(chip);
@@ -1328,7 +1474,12 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 	if (CHK_SD_DDR50(sd_card)) {
-		RTSX_WRITE_REG(chip, SD_PUSH_POINT_CTL, 0x06, 0x04);
+		retval = rtsx_write_register(chip, SD_PUSH_POINT_CTL, 0x06,
+					     0x04);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		retval = sd_set_sample_push_timing(chip);
 			rtsx_trace(chip);
@@ -1396,8 +1547,13 @@ static int sd_switch_function(struct rtsx_chip *chip, u8 bus_width)
 			retval);
-	if (CHK_SD_DDR50(sd_card))
-		RTSX_WRITE_REG(chip, SD_PUSH_POINT_CTL, 0x06, 0);
+	if (CHK_SD_DDR50(sd_card)) {
+		retval = rtsx_write_register(chip, SD_PUSH_POINT_CTL, 0x06, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
@@ -1409,7 +1565,11 @@ static int sd_wait_data_idle(struct rtsx_chip *chip)
 	u8 val = 0;
-		RTSX_READ_REG(chip, SD_DATA_STATE, &val);
+		retval = rtsx_read_register(chip, SD_DATA_STATE, &val);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		if (val & SD_DATA_IDLE) {
 			retval = STATUS_SUCCESS;
 			break;
@@ -1542,8 +1702,12 @@ static int sd_sdr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN,
-		SD_RSP_80CLK_TIMEOUT_EN);
+	retval = rtsx_write_register(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN,
+				     SD_RSP_80CLK_TIMEOUT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = sd_send_cmd_get_rsp(chip, SEND_STATUS, sd_card->sd_addr,
 		SD_RSP_TYPE_R1, NULL, 0);
@@ -1556,7 +1720,12 @@ static int sd_sdr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
-	RTSX_WRITE_REG(chip, SD_CFG3, SD_RSP_80CLK_TIMEOUT_EN, 0);
+				     0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -1590,8 +1759,12 @@ static int sd_ddr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	cmd[0] = 0x40 | PROGRAM_CSD;
 	cmd[1] = 0;
@@ -1608,7 +1781,12 @@ static int sd_ddr_tuning_tx_cmd(struct rtsx_chip *chip, u8 sample_point)
 		return STATUS_FAIL;
+				     0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	sd_send_cmd_get_rsp(chip, SEND_STATUS, sd_card->sd_addr, SD_RSP_TYPE_R1,
 			NULL, 0);
@@ -1804,8 +1982,12 @@ static int sd_ddr_pre_tuning_tx(struct rtsx_chip *chip)
 	u32 phase_map;
 	u8 final_phase;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	phase_map = 0;
 	for (i = MAX_PHASE; i >= 0; i--) {
@@ -1829,7 +2011,12 @@ static int sd_ddr_pre_tuning_tx(struct rtsx_chip *chip)
 			phase_map |= 1 << i;
+				     0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	dev_dbg(rtsx_dev(chip), "DDR TX pre tune phase_map = 0x%08x\n",
 		phase_map);
@@ -2073,10 +2260,18 @@ static int sd_prepare_reset(struct rtsx_chip *chip)
 		return retval;
-	RTSX_WRITE_REG(chip, REG_SD_CFG1, 0xFF, 0x40);
+	retval = rtsx_write_register(chip, REG_SD_CFG1, 0xFF, 0x40);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
-	RTSX_WRITE_REG(chip, CARD_STOP, SD_STOP | SD_CLR_ERR,
-		SD_STOP | SD_CLR_ERR);
+	retval = rtsx_write_register(chip, CARD_STOP, SD_STOP | SD_CLR_ERR,
+				     SD_STOP | SD_CLR_ERR);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = select_card(chip, SD_CARD);
@@ -2089,24 +2284,71 @@ static int sd_prepare_reset(struct rtsx_chip *chip)
 static int sd_pull_ctl_disable(struct rtsx_chip *chip)
+	int retval;
-			XD_D3_PD | SD_D7_PD | SD_CLK_PD | SD_D5_PD);
-			SD_D6_PD | SD_D0_PD | SD_D1_PD | XD_D5_PD);
-			SD_D4_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
-		RTSX_WRITE_REG(chip, CARD_PULL_CTL6, 0xFF, MS_D5_PD | MS_D4_PD);
+					     XD_D3_PD | SD_D7_PD | SD_CLK_PD | SD_D5_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     SD_D6_PD | SD_D0_PD | SD_D1_PD | XD_D5_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     SD_D4_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x4B);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x69);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
@@ -2180,8 +2422,12 @@ static int sd_init_power(struct rtsx_chip *chip)
 			return STATUS_FAIL;
 	} else {
-		RTSX_WRITE_REG(chip, FPGA_PULL_CTL, FPGA_SD_PULL_CTL_BIT | 0x20,
-			0);
+					     FPGA_SD_PULL_CTL_BIT | 0x20, 0);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
@@ -2203,16 +2449,31 @@ static int sd_init_power(struct rtsx_chip *chip)
 #endif
-	RTSX_WRITE_REG(chip, CARD_OE, SD_OUTPUT_EN, SD_OUTPUT_EN);
+	retval = rtsx_write_register(chip, CARD_OE, SD_OUTPUT_EN,
+				     SD_OUTPUT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 static int sd_dummy_clock(struct rtsx_chip *chip)
-	RTSX_WRITE_REG(chip, REG_SD_CFG3, 0x01, 0x01);
+	int retval;
+	retval = rtsx_write_register(chip, REG_SD_CFG3, 0x01, 0x01);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	wait_timeout(5);
-	RTSX_WRITE_REG(chip, REG_SD_CFG3, 0x01, 0);
+	retval = rtsx_write_register(chip, REG_SD_CFG3, 0x01, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -2622,8 +2883,12 @@ SD_UNLOCK_ENTRY:
 	if (!sd20_mode && CHK_SD30_SPEED(sd_card)) {
 		int read_lba0 = 1;
-		RTSX_WRITE_REG(chip, SD30_DRIVE_SEL, 0x07,
-			chip->sd30_drive_sel_1v8);
+		retval = rtsx_write_register(chip, SD30_DRIVE_SEL, 0x07,
+					     chip->sd30_drive_sel_1v8);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 		retval = sd_set_init_para(chip);
@@ -2693,8 +2958,18 @@ SD_UNLOCK_ENTRY:
 #ifdef SUPPORT_SD_LOCK
 	if (sd_card->sd_lock_status & SD_UNLOCK_POW_ON) {
-		RTSX_WRITE_REG(chip, REG_SD_BLOCK_CNT_H, 0xFF, 0x02);
-		RTSX_WRITE_REG(chip, REG_SD_BLOCK_CNT_L, 0xFF, 0x00);
+		retval = rtsx_write_register(chip, REG_SD_BLOCK_CNT_H, 0xFF,
+					     0x02);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		retval = rtsx_write_register(chip, REG_SD_BLOCK_CNT_L, 0xFF,
+					     0x00);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 #endif
@@ -3149,8 +3424,18 @@ MMC_UNLOCK_ENTRY:
+					     0x02);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     0x00);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
 #endif
@@ -3251,8 +3536,16 @@ int reset_sd_card(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, REG_SD_BYTE_CNT_L, 0xFF, 0);
-	RTSX_WRITE_REG(chip, REG_SD_BYTE_CNT_H, 0xFF, 2);
+	retval = rtsx_write_register(chip, REG_SD_BYTE_CNT_L, 0xFF, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, REG_SD_BYTE_CNT_H, 0xFF, 2);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	chip->capacity[chip->card2lun[SD_CARD]] = sd_card->capacity;
@@ -3309,8 +3602,16 @@ static int reset_mmc_only(struct rtsx_chip *chip)
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -4950,7 +5251,11 @@ int sd_power_off_card3v3(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CARD_OE, SD_OUTPUT_EN, 0);
+	retval = rtsx_write_register(chip, CARD_OE, SD_OUTPUT_EN, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 		retval = card_power_off(chip, SD_CARD);
@@ -4969,8 +5274,13 @@ int sd_power_off_card3v3(struct rtsx_chip *chip)
 			return STATUS_FAIL;
 	} else {
-			FPGA_SD_PULL_CTL_BIT | 0x20, FPGA_SD_PULL_CTL_BIT);
+					     FPGA_SD_PULL_CTL_BIT);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
diff --git a/drivers/staging/rts5208/spi.c b/drivers/staging/rts5208/spi.c
index d3ac6c0..e67e7ec 100644
--- a/drivers/staging/rts5208/spi.c
+++ b/drivers/staging/rts5208/spi.c
@@ -36,10 +36,20 @@ static inline void spi_set_err_code(struct rtsx_chip *chip, u8 err_code)
 static int spi_init(struct rtsx_chip *chip)
-	RTSX_WRITE_REG(chip, SPI_CONTROL, 0xFF,
-		CS_POLARITY_LOW | DTO_MSB_FIRST | SPI_MASTER | SPI_MODE0 |
-		SPI_AUTO);
-	RTSX_WRITE_REG(chip, SPI_TCTL, EDO_TIMING_MASK, SAMPLE_DELAY_HALF);
+	int retval;
+	retval = rtsx_write_register(chip, SPI_CONTROL, 0xFF,
+				     CS_POLARITY_LOW | DTO_MSB_FIRST | SPI_MASTER | SPI_MODE0 | SPI_AUTO);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, SPI_TCTL, EDO_TIMING_MASK,
+				     SAMPLE_DELAY_HALF);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -49,8 +59,18 @@ static int spi_set_init_para(struct rtsx_chip *chip)
 	struct spi_info *spi = &(chip->spi);
 	int retval;
-	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER1, 0xFF, (u8)(spi->clk_div >> 8));
-	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER0, 0xFF, (u8)(spi->clk_div));
+	retval = rtsx_write_register(chip, SPI_CLK_DIVIDER1, 0xFF,
+				     (u8)(spi->clk_div >> 8));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, SPI_CLK_DIVIDER0, 0xFF,
+				     (u8)(spi->clk_div));
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = switch_clock(chip, spi->spi_clock);
@@ -64,8 +84,18 @@ static int spi_set_init_para(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CARD_CLK_EN, SPI_CLK_EN, SPI_CLK_EN);
-	RTSX_WRITE_REG(chip, CARD_OE, SPI_OUTPUT_EN, SPI_OUTPUT_EN);
+	retval = rtsx_write_register(chip, CARD_CLK_EN, SPI_CLK_EN,
+				     SPI_CLK_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, CARD_OE, SPI_OUTPUT_EN,
+				     SPI_OUTPUT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	wait_timeout(10);
@@ -228,8 +258,16 @@ static int spi_init_eeprom(struct rtsx_chip *chip)
 	else
 		clk = CLK_30;
-	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER1, 0xFF, 0x00);
-	RTSX_WRITE_REG(chip, SPI_CLK_DIVIDER0, 0xFF, 0x27);
+	retval = rtsx_write_register(chip, SPI_CLK_DIVIDER1, 0xFF, 0x00);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	retval = rtsx_write_register(chip, SPI_CLK_DIVIDER0, 0xFF, 0x27);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	retval = switch_clock(chip, clk);
@@ -243,14 +281,33 @@ static int spi_init_eeprom(struct rtsx_chip *chip)
 		return STATUS_FAIL;
+				     SPI_CLK_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+				     SPI_OUTPUT_EN);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	wait_timeout(10);
-		CS_POLARITY_HIGH | SPI_EEPROM_AUTO);
+				     CS_POLARITY_HIGH | SPI_EEPROM_AUTO);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -310,7 +367,11 @@ int spi_erase_eeprom_chip(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CARD_GPIO_DIR, 0x01, 0x01);
+	retval = rtsx_write_register(chip, CARD_GPIO_DIR, 0x01, 0x01);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -350,7 +411,11 @@ int spi_erase_eeprom_byte(struct rtsx_chip *chip, u16 addr)
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -388,12 +453,20 @@ int spi_read_eeprom(struct rtsx_chip *chip, u16 addr, u8 *val)
 	wait_timeout(5);
-	RTSX_READ_REG(chip, SPI_DATA, &data);
+	retval = rtsx_read_register(chip, SPI_DATA, &data);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (val)
 		*val = data;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
@@ -434,7 +507,11 @@ int spi_write_eeprom(struct rtsx_chip *chip, u16 addr, u8 val)
 		return STATUS_FAIL;
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
diff --git a/drivers/staging/rts5208/xd.c b/drivers/staging/rts5208/xd.c
index 2afa602..8fd108e 100644
--- a/drivers/staging/rts5208/xd.c
+++ b/drivers/staging/rts5208/xd.c
@@ -252,14 +252,22 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, XD_PAGE_STATUS, &reg);
+	retval = rtsx_read_register(chip, XD_PAGE_STATUS, &reg);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (reg != XD_GPG) {
 		rtsx_clear_xd_error(chip);
 		rtsx_trace(chip);
 		return STATUS_FAIL;
-	RTSX_READ_REG(chip, XD_CTL, &reg);
+	retval = rtsx_read_register(chip, XD_CTL, &reg);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (!(reg & XD_ECC1_ERROR) || !(reg & XD_ECC1_UNCORRECTABLE)) {
 		retval = xd_read_data_from_ppb(chip, 0, buf, buf_len);
@@ -269,8 +277,18 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 		if (reg & XD_ECC1_ERROR) {
 			u8 ecc_bit, ecc_byte;
-			RTSX_READ_REG(chip, XD_ECC_BIT1, &ecc_bit);
-			RTSX_READ_REG(chip, XD_ECC_BYTE1, &ecc_byte);
+			retval = rtsx_read_register(chip, XD_ECC_BIT1,
+						    &ecc_bit);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+			retval = rtsx_read_register(chip, XD_ECC_BYTE1,
+						    &ecc_byte);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			dev_dbg(rtsx_dev(chip), "ECC_BIT1 = 0x%x, ECC_BYTE1 = 0x%x\n",
 				ecc_bit, ecc_byte);
@@ -293,8 +311,18 @@ static int xd_read_cis(struct rtsx_chip *chip, u32 page_addr, u8 *buf,
 		if (reg & XD_ECC2_ERROR) {
-			RTSX_READ_REG(chip, XD_ECC_BIT2, &ecc_bit);
-			RTSX_READ_REG(chip, XD_ECC_BYTE2, &ecc_byte);
+			retval = rtsx_read_register(chip, XD_ECC_BIT2,
+						    &ecc_bit);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+			retval = rtsx_read_register(chip, XD_ECC_BYTE2,
+						    &ecc_byte);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
 			dev_dbg(rtsx_dev(chip), "ECC_BIT2 = 0x%x, ECC_BYTE2 = 0x%x\n",
 				ecc_bit, ecc_byte);
@@ -385,24 +413,71 @@ static void xd_fill_pull_ctl_enable(struct rtsx_chip *chip)
 static int xd_pull_ctl_disable(struct rtsx_chip *chip)
+	int retval;
-			XD_D3_PD | XD_D2_PD | XD_D1_PD | XD_D0_PD);
-			XD_D7_PD | XD_D6_PD | XD_D5_PD | XD_D4_PD);
-			XD_WP_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
-			XD_RDY_PD | XD_WE_PD | XD_RE_PD | XD_ALE_PD);
+					     XD_D3_PD | XD_D2_PD | XD_D1_PD | XD_D0_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     XD_D7_PD | XD_D6_PD | XD_D5_PD | XD_D4_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     XD_WP_PD | XD_CE_PD | XD_CLE_PD | XD_CD_PU);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+					     XD_RDY_PD | XD_WE_PD | XD_RE_PD | XD_ALE_PD);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x55);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x4B);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
+						     0xFF, 0x69);
+			if (retval) {
+				rtsx_trace(chip);
+				return retval;
@@ -1144,7 +1219,12 @@ static int xd_copy_page(struct rtsx_chip *chip, u32 old_blk, u32 new_blk,
 	XD_CLR_BAD_NEWBLK(xd_card);
-	RTSX_WRITE_REG(chip, CARD_DATA_SOURCE, 0x01, PINGPONG_BUFFER);
+	retval = rtsx_write_register(chip, CARD_DATA_SOURCE, 0x01,
+				     PINGPONG_BUFFER);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	for (i = start_page; i < end_page; i++) {
 		if (detect_card_cd(chip, XD_CARD) != STATUS_SUCCESS) {
@@ -1619,12 +1699,20 @@ static int xd_read_multiple_pages(struct rtsx_chip *chip, u32 phy_blk,
 Fail:
-	RTSX_READ_REG(chip, XD_PAGE_STATUS, &reg_val);
+	retval = rtsx_read_register(chip, XD_PAGE_STATUS, &reg_val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (reg_val !=  XD_GPG)
 		xd_set_err_code(chip, XD_PRG_ERROR);
-	RTSX_READ_REG(chip, XD_CTL, &reg_val);
+	retval = rtsx_read_register(chip, XD_CTL, &reg_val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (((reg_val & (XD_ECC1_ERROR | XD_ECC1_UNCORRECTABLE))
 				== (XD_ECC1_ERROR | XD_ECC1_UNCORRECTABLE))
@@ -1847,7 +1935,11 @@ static int xd_write_multiple_pages(struct rtsx_chip *chip, u32 old_blk,
 Fail:
-	RTSX_READ_REG(chip, XD_DAT, &reg_val);
+	retval = rtsx_read_register(chip, XD_DAT, &reg_val);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 	if (reg_val & PROGRAM_ERROR) {
 		xd_mark_bad_block(chip, new_blk);
@@ -2197,7 +2289,11 @@ int xd_power_off_card3v3(struct rtsx_chip *chip)
 		return STATUS_FAIL;
-	RTSX_WRITE_REG(chip, CARD_OE, XD_OUTPUT_EN, 0);
+	retval = rtsx_write_register(chip, CARD_OE, XD_OUTPUT_EN, 0);
+	if (retval) {
+		rtsx_trace(chip);
+		return retval;
 		retval = card_power_off(chip, XD_CARD);
@@ -2216,7 +2312,11 @@ int xd_power_off_card3v3(struct rtsx_chip *chip)
 			return STATUS_FAIL;
 	} else {
-		RTSX_WRITE_REG(chip, FPGA_PULL_CTL, 0xFF, 0xDF);
+		retval = rtsx_write_register(chip, FPGA_PULL_CTL, 0xFF, 0xDF);
+		if (retval) {
+			rtsx_trace(chip);
+			return retval;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
