Staging: rtl8723au: Use put_unaligned_le32
Author: Shraddha Barke <shraddha.6596@gmail.com>
Introduce the use of function put_unaligned_le32.
A simplified version of Coccinelle semantic patch used -
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le32(y);
  <+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le32(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Shraddha Barke
 drivers/staging/rtl8723au/hal/rtl8723a_cmd.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c b/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
index 9733aa6..1662c03c 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
@@ -127,8 +127,7 @@ int rtl8723a_set_raid_cmd(struct rtw_adapter *padapter, u32 mask, u8 arg)
 	u8 buf[5];
 	memset(buf, 0, 5);
-	mask = cpu_to_le32(mask);
-	memcpy(buf, &mask, 4);
+	put_unaligned_le32(mask, buf);
 	buf[4]  = arg;
 	FillH2CCmd(padapter, MACID_CONFIG_EID, 5, buf);
BtrLinux
Privacy Overview
