Staging: rtl8723au: rtl8723a_rf6052: Remove unnecessary semicolon.
Author: Sandhya Bankar <bankarsandhya512@gmail.com>
Coccinelle sementic patch as follows:
@r_case@
position p;
switch (...)
case ...: ...;@p
@r_default@
position p;
switch (...)
default: ...;@p
@r1@
statement S;
position p1;
position p != {r_case.p, r_default.p};
identifier label;
label:;
S@p1;@p
Signed-off-by: Sandhya Bankar
drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c b/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
index ce0d8d8..24c0ff3 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
@@ -465,7 +465,7 @@ static int phy_RF6052_Config_ParaFile(struct rtw_adapter *Adapter)
break;
- /*----Restore RFENV control type----*/;
+ /*----Restore RFENV control type----*/
switch (eRFPath) {
case RF_PATH_A:
PHY_SetBBReg(Adapter, pPhyReg->rfintfs, |
break;
switch (eRFPath) {
case RF_PATH_A:
