staging: rtl8723au: rewrite the right hand side of an assignment
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch rewrites the right hand side of an assignment for
expressions of the form:
a = (a  b);
to be:
a = b;
where  = << | >>.
This issue was detected and resolved using the following
coccinelle script:
identifier i;
expression e;
-i = (i >> e);
+i >>= e;
identifier i;
expression e;
-i = (i << e);
+i <<= e;
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8723au/hal/hal_com.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8723au/hal/hal_com.c b/drivers/staging/rtl8723au/hal/hal_com.c
index a7751c9..c9bb3e1 100644
--- a/drivers/staging/rtl8723au/hal/hal_com.c
+++ b/drivers/staging/rtl8723au/hal/hal_com.c
@@ -231,7 +231,7 @@ void HalSetBrateCfg23a(struct rtw_adapter *padapter, u8 *mBratesOS)
 	rate_index = 0;
 	/*  Set RTS initial rate */
 	while (brate_cfg > 0x1) {
-		brate_cfg = (brate_cfg >> 1);
+		brate_cfg >>= 1;
 		rate_index++;
 		/*  Ziv - Check */
