staging: rtl8723au: Remove unnecessary parantheses
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Removed parantheses on the right hand side of assignments as they are
not needed.
This was done with Coccinelle:
@@ expression a, b; @@
a =
b
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
index 908b84c..8850898 100644
--- a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
+++ b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
@@ -458,7 +458,7 @@ static int set_group_key(struct rtw_adapter *padapter, struct key_params *parms,
 	pcmd->cmdcode = _SetKey_CMD_;
 	pcmd->parmbuf = (u8 *) psetkeyparm;
-	pcmd->cmdsz = (sizeof(struct setkey_parm));
+	pcmd->cmdsz = sizeof(struct setkey_parm);
 	pcmd->rsp = NULL;
 	pcmd->rspsz = 0;
@@ -2197,7 +2197,7 @@ static int cfg80211_rtw_get_txpower(struct wiphy *wiphy,
 				    struct wireless_dev *wdev, int *dbm)
 	DBG_8723A("%s\n", __func__);
-	*dbm = (12);
+	*dbm = 12;
 	return 0;
BtrLinux
Privacy Overview
