staging: rtl8723au: Remove unnecessary else following return
Author: Janani Ravichandran <janani.rvchndrn@gmail.com>
Remove unnecessary else when there is a return statement in the
corresponding if block.
Coccinelle patch used:
@rule1@
expression e1;
	if (e1) { ... return ...; }
-       else{
@rule2@
expression e2;
statement s1;
	if(e2) { ... return ...; }
-       else
		s1
Signed-off-by: Janani Ravichandran
 drivers/staging/rtl8723au/hal/hal_com.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8723au/hal/hal_com.c b/drivers/staging/rtl8723au/hal/hal_com.c
index 530db57..9d7b11b 100644
--- a/drivers/staging/rtl8723au/hal/hal_com.c
+++ b/drivers/staging/rtl8723au/hal/hal_com.c
@@ -328,7 +328,7 @@ int c2h_evt_read23a(struct rtw_adapter *adapter, u8 *buf)
 	if (trigger == C2H_EVT_HOST_CLOSE)
 		goto exit;	/* Not ready */
-	else if (trigger != C2H_EVT_FW_CLOSE)
+	if (trigger != C2H_EVT_FW_CLOSE)
 		goto clear_evt;	/* Not a valid value */
 	c2h_evt = (struct c2h_evt_hdr *)buf;
BtrLinux
Privacy Overview
