Staging: rtl8723au: Remove print statements and debug messages
Author: Bhumika Goyal <bhumirks@gmail.com>
The  memory allocation functions generates a call stack containing
all the context information on failure, so print statements and debug
messages can be removed on failure of these functions. Also remove
unwanted {} around if block after removal of these messages.
Done using coccinelle:
expression e;
e=\(kmalloc\|kmalloc\|kmalloc_array\|alloc_netdev\|kzalloc\|
   devm_kzalloc\|devm_ioremap\)(...);
if(!e){
- \(DBG_8723A\|printk\|pr_err\|CERROR\|DBG_88E\)(...);
...when any
Signed-off-by: Bhumika Goyal
 drivers/staging/rtl8723au/hal/usb_ops_linux.c     | 6 +-----
 drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c | 3 ---
 2 files changed, 1 insertion(+), 8 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/usb_ops_linux.c b/drivers/staging/rtl8723au/hal/usb_ops_linux.c
index 371e6b3..5c81ff4 100644
--- a/drivers/staging/rtl8723au/hal/usb_ops_linux.c
+++ b/drivers/staging/rtl8723au/hal/usb_ops_linux.c
@@ -256,12 +256,8 @@ static void usb_read_interrupt_complete(struct urb *purb)
 				c2w = kmalloc(sizeof(struct evt_work),
 						GFP_ATOMIC);
-				if (!c2w) {
-					printk(KERN_WARNING "%s: unable to "
-					       "allocate work buffer\n",
-					       __func__);
+				if (!c2w)
 					goto urb_submit;
 				c2w->adapter = padapter;
 				INIT_WORK(&c2w->work, rtw_evt_work);
diff --git a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
index e64b7e1..12d1844 100644
--- a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
+++ b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
@@ -2610,8 +2610,6 @@ static int rtw_cfg80211_add_monitor_if(struct rtw_adapter *padapter, char *name,
 	/*  wdev */
 	mon_wdev = kzalloc(sizeof(struct wireless_dev), GFP_KERNEL);
 	if (!mon_wdev) {
-		DBG_8723A("%s(%s): allocate mon_wdev fail\n", __func__,
-			  padapter->pnetdev->name);
 		ret = -ENOMEM;
 		goto out;
@@ -3262,7 +3260,6 @@ int rtw_wdev_alloc(struct rtw_adapter *padapter, struct device *dev)
 	/*  wdev */
 	if (!wdev) {
-		DBG_8723A("Couldn't allocate wireless device\n");
 		ret = -ENOMEM;
 		goto free_wiphy;
BtrLinux
Privacy Overview
