Staging: rtl8723au: Remove parentheses around right side an assignment
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
Parentheses are not needed around the right hand side of an assignment.
This patch remove parenthese of such occurenses. Issue was detected and
solved using the following coccinelle script:
@rule1@
identifier x, y, z;
expression E1, E2;
x = (y == z);
x = (E1 == E2);
 x =
Signed-off-by: Haneen Mohammed
 drivers/staging/rtl8723au/core/rtw_mlme_ext.c       | 16 ++++++++--------
 drivers/staging/rtl8723au/core/rtw_recv.c           |  4 ++--
 drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c |  2 +-
 drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c   | 12 ++++++------
 drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c     |  4 ++--
 drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c     |  4 ++--
 drivers/staging/rtl8723au/hal/rtl8723au_recv.c      |  4 ++--
 drivers/staging/rtl8723au/hal/usb_halinit.c         |  4 ++--
 8 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
index 0e0f73c..d01ca1d 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
@@ -3842,7 +3842,7 @@ void issue_action_BA23a(struct rtw_adapter *padapter,
 				IEEE80211_ADDBA_PARAM_BUF_SIZE_MASK;
 		} else {
 			/* immediate ack & 64 buffer size */
-			BA_para_set = (0x1002 | ((status & 0xf) << 2));
+			BA_para_set = 0x1002 | ((status & 0xf) << 2);
 		put_unaligned_le16(BA_para_set,
@@ -4745,7 +4745,7 @@ void report_survey_event23a(struct rtw_adapter *padapter,
 	if (!pcmd_obj)
 		return;
-	cmdsz = (sizeof(struct survey_event) + sizeof(struct C2HEvent_Header));
+	cmdsz = sizeof(struct survey_event) + sizeof(struct C2HEvent_Header);
 	pevtcmd = kzalloc(cmdsz, GFP_ATOMIC);
 	if (!pevtcmd) {
 		kfree(pcmd_obj);
@@ -4796,7 +4796,7 @@ void report_surveydone_event23a(struct rtw_adapter *padapter)
 	if (!pcmd_obj)
 		return;
-	cmdsz = (sizeof(struct surveydone_event) + sizeof(struct C2HEvent_Header));
+	cmdsz = sizeof(struct surveydone_event) + sizeof(struct C2HEvent_Header);
 	if (!pevtcmd) {
 		kfree(pcmd_obj);
@@ -4840,7 +4840,7 @@ void report_join_res23a(struct rtw_adapter *padapter, int res)
 	if (!pcmd_obj)
 		return;
-	cmdsz = (sizeof(struct joinbss_event) + sizeof(struct C2HEvent_Header));
+	cmdsz = sizeof(struct joinbss_event) + sizeof(struct C2HEvent_Header);
 	if (!pevtcmd) {
 		kfree(pcmd_obj);
@@ -4890,7 +4890,7 @@ void report_del_sta_event23a(struct rtw_adapter *padapter,
 	if (!pcmd_obj)
 		return;
-	cmdsz = (sizeof(struct stadel_event) + sizeof(struct C2HEvent_Header));
+	cmdsz = sizeof(struct stadel_event) + sizeof(struct C2HEvent_Header);
 	if (!pevtcmd) {
 		kfree(pcmd_obj);
@@ -4918,7 +4918,7 @@ void report_del_sta_event23a(struct rtw_adapter *padapter,
 	if (psta)
 		mac_id = (int)psta->mac_id;
 	else
-		mac_id = (-1);
+		mac_id = -1;
 	pdel_sta_evt->mac_id = mac_id;
@@ -4944,7 +4944,7 @@ void report_add_sta_event23a(struct rtw_adapter *padapter,
 	if (!pcmd_obj)
 		return;
-	cmdsz = (sizeof(struct stassoc_event) + sizeof(struct C2HEvent_Header));
+	cmdsz = sizeof(struct stassoc_event) + sizeof(struct C2HEvent_Header);
 	if (!pevtcmd) {
 		kfree(pcmd_obj);
@@ -5951,7 +5951,7 @@ int set_stakey_hdl23a(struct rtw_adapter *padapter, const u8 *pbuf)
 			/* 0~3 for default key, cmd_id = macid + 3,
 			   macid = aid+1; */
-			cam_id = (psta->mac_id + 3);
+			cam_id = psta->mac_id + 3;
 			DBG_8723A("Write CAM, mac_addr =%x:%x:%x:%x:%x:%x, "
 				  "cam_entry =%d\n", pparm->addr[0],
diff --git a/drivers/staging/rtl8723au/core/rtw_recv.c b/drivers/staging/rtl8723au/core/rtw_recv.c
index 559ddde..9c78300 100644
--- a/drivers/staging/rtl8723au/core/rtw_recv.c
+++ b/drivers/staging/rtl8723au/core/rtw_recv.c
@@ -2334,8 +2334,8 @@ void rtw_signal_stat_timer_hdl23a(unsigned long data)
 	/* update value of signal_strength, rssi, signal_qual */
 	if (!check_fwstate(&adapter->mlmepriv, _FW_UNDER_SURVEY)) {
-		tmp_s = (avg_signal_strength + (_alpha - 1) *
-			 recvpriv->signal_strength);
+		tmp_s = avg_signal_strength + (_alpha - 1) *
+			 recvpriv->signal_strength;
 		if (tmp_s %_alpha)
 			tmp_s = tmp_s / _alpha + 1;
 		else
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c b/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
index e46032e..7f091da 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
@@ -3208,7 +3208,7 @@ bthci_CmdDisconnectPhysicalLink(struct rtw_adapter *padapter,
 	pBtDbg->dbgHciInfo.hciCmdCntDisconnectPhyLink++;
 	PLH = *((u8 *)pHciCmd->Data);
-	PhysLinkDisconnectReason = (*((u8 *)pHciCmd->Data+1));
+	PhysLinkDisconnectReason = *((u8 *)pHciCmd->Data+1);
 	RTPRINT(FIOCTL, IOCTL_BT_HCICMD, ("HCI_DISCONNECT_PHYSICAL_LINK  PhyHandle = 0x%x, Reason = 0x%x\n",
 		PLH, PhysLinkDisconnectReason));
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
index ebe3339..d3dc24b 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
@@ -428,10 +428,10 @@ hal_ReadEFuse_WiFi(struct rtw_adapter *padapter,
 				continue;
 			offset |= ((efuseExtHdr & 0xF0) >> 1);
-			wden = (efuseExtHdr & 0x0F);
+			wden = efuseExtHdr & 0x0F;
 		} else {
-			offset = ((efuseHeader >> 4) & 0x0f);
-			wden = (efuseHeader & 0x0f);
+			offset = (efuseHeader >> 4) & 0x0f;
+			wden = efuseHeader & 0x0f;
 		if (offset < EFUSE_MAX_SECTION_8723A) {
@@ -527,10 +527,10 @@ hal_ReadEFuse_BT(struct rtw_adapter *padapter,
 					continue;
 			} else {
 			if (offset < EFUSE_BT_MAX_SECTION) {
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c b/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
index d34a148..38f8c3d 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
@@ -126,7 +126,7 @@ PHY_SetBBReg(struct rtw_adapter *Adapter, u32 RegAddr, u32 BitMask, u32	Data)
 	if (BitMask != bMaskDWord) {/* if not "double word" write */
 		OriginalValue = rtl8723au_read32(Adapter, RegAddr);
 		BitShift = phy_CalculateBitShift(BitMask);
-		Data = ((OriginalValue & (~BitMask)) | (Data << BitShift));
+		Data = (OriginalValue & (~BitMask)) | (Data << BitShift);
 	rtl8723au_write32(Adapter, RegAddr, Data);
@@ -389,7 +389,7 @@ PHY_SetRFReg(struct rtw_adapter *Adapter, enum RF_RADIO_PATH eRFPath,
 	if (BitMask != bRFRegOffsetMask) {
 		Original_Value = phy_RFSerialRead(Adapter, eRFPath, RegAddr);
-		Data = ((Original_Value & (~BitMask)) | (Data << BitShift));
+		Data = (Original_Value & (~BitMask)) | (Data << BitShift);
 	phy_RFSerialWrite(Adapter, eRFPath, RegAddr, Data);
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c b/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
index 32c58c6..3e3f186 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_rf6052.c
@@ -267,8 +267,8 @@ getTxPowerWriteValByRegulatory(struct rtw_adapter *Adapter, u8 Channel,
 			break;
 		case 2:	/*  Better regulatory */
 			/*  don't increase any power diff */
-			writeVal = ((index < 2) ? powerBase0[rf] :
-				    powerBase1[rf]);
+			writeVal = (index < 2) ? powerBase0[rf] :
+				    powerBase1[rf];
 			break;
 		case 3:	/*  Customer defined power diff. */
 			chnlGroup = 0;
diff --git a/drivers/staging/rtl8723au/hal/rtl8723au_recv.c b/drivers/staging/rtl8723au/hal/rtl8723au_recv.c
index 6075b6d..aae433f 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723au_recv.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723au_recv.c
@@ -194,8 +194,8 @@ void update_recvframe_phyinfo(struct recv_frame *precvframe,
 	bool matchbssid = false;
 	u8 *bssid;
-	matchbssid = (!ieee80211_is_ctl(hdr->frame_control) &&
-		      !pattrib->icv_err && !pattrib->crc_err);
+	matchbssid = !ieee80211_is_ctl(hdr->frame_control) &&
+		      !pattrib->icv_err && !pattrib->crc_err;
 	if (matchbssid) {
 		switch (hdr->frame_control &
diff --git a/drivers/staging/rtl8723au/hal/usb_halinit.c b/drivers/staging/rtl8723au/hal/usb_halinit.c
index bd9c549..0d08863 100644
--- a/drivers/staging/rtl8723au/hal/usb_halinit.c
+++ b/drivers/staging/rtl8723au/hal/usb_halinit.c
@@ -736,8 +736,8 @@ int rtl8723au_hal_init(struct rtw_adapter *Adapter)
 	rtl8723a_InitHalDm(Adapter);
-	val8 = ((WiFiNavUpperUs + HAL_8723A_NAV_UPPER_UNIT - 1) /
-		HAL_8723A_NAV_UPPER_UNIT);
+	val8 = (WiFiNavUpperUs + HAL_8723A_NAV_UPPER_UNIT - 1) /
+		HAL_8723A_NAV_UPPER_UNIT;
 	rtl8723au_write8(Adapter, REG_NAV_UPPER, val8);
 	/*  2011/03/09 MH debug only, UMC-B cut pass 2500 S5 test, but we need to fin root cause. */
BtrLinux
Privacy Overview
