staging: rtl8723au: hal: Remove unnecessary function and its call
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The function odm_DynamicBBPowerSaving23a on being called, simply returns
back. The function hasn't been mentioned in the TODO and doesn't have FIXME
code around. Hence, odm_DynamicBBPowerSaving23a and its calls have been
removed.
This was done using Coccinelle.
identifier f;
void f(...) {
-return;
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8723au/hal/odm.c | 6 ------
 1 file changed, 6 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/odm.c b/drivers/staging/rtl8723au/hal/odm.c
index 45d70fd..e279c34 100644
--- a/drivers/staging/rtl8723au/hal/odm.c
+++ b/drivers/staging/rtl8723au/hal/odm.c
@@ -185,7 +185,6 @@ void odm_CCKPacketDetectionThresh23a(struct dm_odm_t *pDM_Odm);
 /* START-------BB POWER SAVE----------------------- */
 void odm23a_DynBBPSInit(struct dm_odm_t *pDM_Odm);
-void odm_DynamicBBPowerSaving23a(struct dm_odm_t *pDM_Odm);
 /* END---------BB POWER SAVE----------------------- */
@@ -270,7 +269,6 @@ void ODM_DMWatchdog23a(struct rtw_adapter *adapter)
 	odm_RefreshRateAdaptiveMask(pDM_Odm);
-	odm_DynamicBBPowerSaving23a(pDM_Odm);
 	odm_EdcaTurboCheck23a(pDM_Odm);
@@ -894,10 +892,6 @@ void odm23a_DynBBPSInit(struct dm_odm_t *pDM_Odm)
 	pDM_PSTable->initialize = 0;
-	return;
 void ODM_RF_Saving23a(struct dm_odm_t *pDM_Odm, u8 bForceInNormal)
-	return;
