staging: rtl8723au: hal: Remove uneeded return variable
Author: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This patch removes uneeded return variables, just using
'return _SUCCESS' or 'return HCI_STATUS_SUCCESS' instead.
This fixes the following warning detected using coccinelle:
Unneeded variable.
It was done using the following semantic patch:
identifier ret;
type T;
expression e;
-T ret = e;
 ... when != ret
     when strict
-return ret;
+return e;
Signed-off-by: Roberta Dobrescu
 drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c | 17 +++++------------
 drivers/staging/rtl8723au/hal/rtl8723a_cmd.c        |  7 ++-----
 drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c   | 14 ++++----------
 drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c     |  3 +--
 4 files changed, 12 insertions(+), 29 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c b/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
index 9054a98..5de806e 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_bt-coexist.c
@@ -1766,9 +1766,7 @@ bthci_CmdSetEventFilter(
 	struct packet_irp_hcicmd_data *pHciCmd
-	enum hci_status status = HCI_STATUS_SUCCESS;
-	return status;
+	return HCI_STATUS_SUCCESS;
 /* 7.3.14 */
@@ -2984,8 +2982,7 @@ bthci_CmdReadLinkQuality(
 static enum hci_status bthci_CmdReadRSSI(struct rtw_adapter *padapter)
-	return status;
@@ -2994,7 +2991,6 @@ bthci_CmdCreateLogicalLink(
 	struct bt_30info *pBTInfo = GET_BT_INFO(padapter);
 	struct bt_dgb *pBtDbg = &pBTInfo->BtDbg;
@@ -3003,7 +2999,7 @@ bthci_CmdCreateLogicalLink(
 	bthci_BuildLogicalLink(padapter, pHciCmd,
 		HCI_CREATE_LOGICAL_LINK);
-	return status;
@@ -3012,7 +3008,6 @@ bthci_CmdAcceptLogicalLink(
@@ -3021,7 +3016,7 @@ bthci_CmdAcceptLogicalLink(
 		HCI_ACCEPT_LOGICAL_LINK);
-	return status;
@@ -4141,9 +4136,7 @@ static enum hci_status
 bthci_CmdHostNumberOfCompletedPackets(struct rtw_adapter *padapter,
 				      struct packet_irp_hcicmd_data *pHciCmd)
-	return status;
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c b/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
index 271c33d..7b56411 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_cmd.c
@@ -115,19 +115,16 @@ exit:
 int rtl8723a_set_rssi_cmd(struct rtw_adapter *padapter, u8 *param)
-	int res = _SUCCESS;
 	*((u32 *)param) = cpu_to_le32(*((u32 *)param));
 	FillH2CCmd(padapter, RSSI_SETTING_EID, 3, param);
-	return res;
+	return _SUCCESS;
 int rtl8723a_set_raid_cmd(struct rtw_adapter *padapter, u32 mask, u8 arg)
 	u8 buf[5];
 	memset(buf, 0, 5);
 	mask = cpu_to_le32(mask);
@@ -136,7 +133,7 @@ int rtl8723a_set_raid_cmd(struct rtw_adapter *padapter, u32 mask, u8 arg)
 	FillH2CCmd(padapter, MACID_CONFIG_EID, 5, buf);
-	return res;
+	return _SUCCESS;
 /* bitmap[0:27] = tx_rate_bitmap */
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
index 1ccf60a..9a75eb6 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
@@ -1522,10 +1522,8 @@ static void _DisableAnalog(struct rtw_adapter *padapter, bool bWithoutHWSM)
 /*  HW Auto state machine */
 int CardDisableHWSM(struct rtw_adapter *padapter, u8 resetMCU)
-	int rtStatus = _SUCCESS;
 	if (padapter->bSurpriseRemoved) {
-		return rtStatus;
+		return _SUCCESS;
 	/*  RF Off Sequence ==== */
 	_DisableRFAFEAndResetBB(padapter);
@@ -1542,18 +1540,14 @@ int CardDisableHWSM(struct rtw_adapter *padapter, u8 resetMCU)
 	RT_TRACE(_module_hci_hal_init_c_, _drv_info_,
 		 ("======> Card disable finished.\n"));
-	return rtStatus;
+	return _SUCCESS;
 /*  without HW Auto state machine */
 int CardDisableWithoutHWSM(struct rtw_adapter *padapter)
-	/* RT_TRACE(COMP_INIT, DBG_LOUD,
-	   ("======> Card Disable Without HWSM .\n")); */
-		return rtStatus;
+		return _SUCCESS;
@@ -1573,7 +1567,7 @@ int CardDisableWithoutHWSM(struct rtw_adapter *padapter)
 	   ("<====== Card Disable Without HWSM .\n")); */
-	return rtStatus;
+	return _SUCCESS;
 void Hal_InitPGData(struct rtw_adapter *padapter, u8 *PROMContent)
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c b/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
index 3d4d7ec..88e91cd 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_phycfg.c
@@ -418,7 +418,6 @@ PHY_SetRFReg(struct rtw_adapter *Adapter, enum RF_RADIO_PATH eRFPath,
 int PHY_MACConfig8723A(struct rtw_adapter *Adapter)
 	struct hal_data_8723a *pHalData = GET_HAL_DATA(Adapter);
 	bool is92C = IS_92C_SERIAL(pHalData->VersionID);
@@ -433,7 +432,7 @@ int PHY_MACConfig8723A(struct rtw_adapter *Adapter)
 	if (is92C && (BOARD_USB_DONGLE == pHalData->BoardType))
 		rtl8723au_write8(Adapter, 0x40, 0x04);
-	return rtStatus;
+	return _SUCCESS;
BtrLinux
Privacy Overview
