staging: rtl8723au: Do not use comparisons on bool tests
Author: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This patch removes unnecessary comparisons to bool.
It fixes the following warning detected using coccinelle tool:
WARNING: Comparison to bool.
Signed-off-by: Roberta Dobrescu
 drivers/staging/rtl8723au/core/rtw_ap.c             | 2 +-
 drivers/staging/rtl8723au/core/rtw_cmd.c            | 2 +-
 drivers/staging/rtl8723au/core/rtw_mlme.c           | 2 +-
 drivers/staging/rtl8723au/core/rtw_mlme_ext.c       | 2 +-
 drivers/staging/rtl8723au/core/rtw_pwrctrl.c        | 2 +-
 drivers/staging/rtl8723au/core/rtw_wlan_util.c      | 2 +-
 drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c | 2 +-
 drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c   | 4 ++--
 drivers/staging/rtl8723au/hal/usb_halinit.c         | 2 +-
 drivers/staging/rtl8723au/include/rtw_mlme.h        | 2 +-
 10 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/staging/rtl8723au/core/rtw_ap.c b/drivers/staging/rtl8723au/core/rtw_ap.c
index 6a336cd..d00255f 100644
--- a/drivers/staging/rtl8723au/core/rtw_ap.c
+++ b/drivers/staging/rtl8723au/core/rtw_ap.c
@@ -1605,7 +1605,7 @@ u8 ap_free_sta23a(struct rtw_adapter *padapter, struct sta_info *psta, bool acti
 	if (!psta)
 		return beacon_updated;
-	if (active == true) {
+	if (active) {
 		/* tear down Rx AMPDU */
 		send_delba23a(padapter, 0, psta->hwaddr);/*  recipient */
diff --git a/drivers/staging/rtl8723au/core/rtw_cmd.c b/drivers/staging/rtl8723au/core/rtw_cmd.c
index 01b44a4..424d96a 100644
--- a/drivers/staging/rtl8723au/core/rtw_cmd.c
+++ b/drivers/staging/rtl8723au/core/rtw_cmd.c
@@ -1149,7 +1149,7 @@ static void rtw_chk_hi_queue_hdl(struct rtw_adapter *padapter)
 		val = rtl8723a_chk_hi_queue_empty(padapter);
-		while (val == false) {
+		while (!val) {
 			msleep(100);
 			cnt++;
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme.c b/drivers/staging/rtl8723au/core/rtw_mlme.c
index ba20130..4e2b22d 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme.c
@@ -1121,7 +1121,7 @@ void rtw_joinbss_event_prehandle23a(struct rtw_adapter *adapter, u8 *pbuf)
 		if (check_fwstate(pmlmepriv, _FW_UNDER_LINKING)) {
 			/* s1. find ptarget_wlan */
 			if (check_fwstate(pmlmepriv, _FW_LINKED)) {
-				if (the_same_macaddr == true) {
+				if (the_same_macaddr) {
 					ptarget_wlan = rtw_find_network23a(&pmlmepriv->scanned_queue, cur_network->network.MacAddress);
 				} else {
 					pcur_wlan = rtw_find_network23a(&pmlmepriv->scanned_queue, cur_network->network.MacAddress);
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
index 10f8031..2624c77 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
@@ -3999,7 +3999,7 @@ int send_beacon23a(struct rtw_adapter *padapter)
 			yield();
 			bxmitok = rtl8723a_get_bcn_valid(padapter);
 			poll++;
-		} while ((poll % 10) != 0 && bxmitok == false &&
+		} while ((poll % 10) != 0 && !bxmitok &&
 			 !padapter->bSurpriseRemoved &&
 			 !padapter->bDriverStopped);
diff --git a/drivers/staging/rtl8723au/core/rtw_pwrctrl.c b/drivers/staging/rtl8723au/core/rtw_pwrctrl.c
index 1eae885..e2d51af 100644
--- a/drivers/staging/rtl8723au/core/rtw_pwrctrl.c
+++ b/drivers/staging/rtl8723au/core/rtw_pwrctrl.c
@@ -159,7 +159,7 @@ void rtw_ps_processor23a(struct rtw_adapter *padapter)
 	if (pwrpriv->ips_mode_req == IPS_NONE)
 		goto exit;
-	if (rtw_pwr_unassociated_idle(padapter) == false)
+	if (!rtw_pwr_unassociated_idle(padapter))
 		goto exit;
 	if (pwrpriv->rf_pwrstate == rf_on &&
diff --git a/drivers/staging/rtl8723au/core/rtw_wlan_util.c b/drivers/staging/rtl8723au/core/rtw_wlan_util.c
index c0325c9..bc63d6f 100644
--- a/drivers/staging/rtl8723au/core/rtw_wlan_util.c
+++ b/drivers/staging/rtl8723au/core/rtw_wlan_util.c
@@ -866,7 +866,7 @@ int rtw_check_bcn_info23a(struct rtw_adapter *Adapter,
 	int pie_len, ssid_len, privacy;
 	const u8 *p, *ssid;
-	if (is_client_associated_to_ap23a(Adapter) == false)
+	if (!is_client_associated_to_ap23a(Adapter))
 		return _SUCCESS;
 	if (unlikely(!ieee80211_is_beacon(mgmt->frame_control))) {
diff --git a/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c b/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
index 4b41bc4..179a1ba 100644
--- a/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
+++ b/drivers/staging/rtl8723au/hal/HalDMOutSrc8723A_CE.c
@@ -612,7 +612,7 @@ static void _PHY_PathADDAOn(struct rtw_adapter *pAdapter, u32 *ADDAReg, bool isP
 	u32 i;
 	pathOn = isPathAOn ? 0x04db25a4 : 0x0b1b25a4;
-	if (false == is2T) {
+	if (!is2T) {
 		pathOn = 0x0bdb25a0;
 		PHY_SetBBReg(pAdapter, ADDAReg[0], bMaskDWord, 0x0b1b25a0);
 	} else {
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
index 8523908..1ccf60a 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
@@ -1945,13 +1945,13 @@ Hal_EfuseParseThermalMeter_8723A(struct rtw_adapter *padapter,
 	/*  ThermalMeter from EEPROM */
-	if (AutoloadFail == false)
+	if (!AutoloadFail)
 		pHalData->EEPROMThermalMeter =
 		    PROMContent[EEPROM_THERMAL_METER_8723A];
 	else
 		pHalData->EEPROMThermalMeter = EEPROM_Default_ThermalMeter;
-	if ((pHalData->EEPROMThermalMeter == 0xff) || (AutoloadFail == true)) {
+	if ((pHalData->EEPROMThermalMeter == 0xff) || AutoloadFail) {
 		pHalData->bAPKThermalMeterIgnore = true;
diff --git a/drivers/staging/rtl8723au/hal/usb_halinit.c b/drivers/staging/rtl8723au/hal/usb_halinit.c
index 6c1dcf0..adc2953 100644
--- a/drivers/staging/rtl8723au/hal/usb_halinit.c
+++ b/drivers/staging/rtl8723au/hal/usb_halinit.c
@@ -480,7 +480,7 @@ static void _InitRFType(struct rtw_adapter *Adapter)
 	pHalData->rf_chip = RF_6052;
-	if (is92CU == false) {
+	if (!is92CU) {
 		pHalData->rf_type = RF_1T1R;
 		DBG_8723A("Set RF Chip ID to RF_6052 and RF type to 1T1R.\n");
 		return;
diff --git a/drivers/staging/rtl8723au/include/rtw_mlme.h b/drivers/staging/rtl8723au/include/rtw_mlme.h
index 2ff01eb..a6751f1 100644
--- a/drivers/staging/rtl8723au/include/rtw_mlme.h
+++ b/drivers/staging/rtl8723au/include/rtw_mlme.h
@@ -270,7 +270,7 @@ static inline void _clr_fwstate_(struct mlme_priv *pmlmepriv, int state)
 static inline void clr_fwstate(struct mlme_priv *pmlmepriv, int state)
 	spin_lock_bh(&pmlmepriv->lock);
-	if (check_fwstate(pmlmepriv, state) == true)
+	if (check_fwstate(pmlmepriv, state))
 		pmlmepriv->fw_state ^= state;
 	spin_unlock_bh(&pmlmepriv->lock);
BtrLinux
Privacy Overview
