staging: rtl8723au: core: Remove unnecessary else after return
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
This patch fixes the checkpatch warning that else is not generally
useful after a break or return.
This was done using Coccinelle:
expression e2;
statement s1;
if(e2) { ... return ...; }
-else
         s1
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8723au/core/rtw_efuse.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8723au/core/rtw_efuse.c b/drivers/staging/rtl8723au/core/rtw_efuse.c
index f174b4d..359ef41 100644
--- a/drivers/staging/rtl8723au/core/rtw_efuse.c
+++ b/drivers/staging/rtl8723au/core/rtw_efuse.c
@@ -269,8 +269,8 @@ u8 EFUSE_Read1Byte23a(struct rtw_adapter *Adapter, u16 Address)
 		data = rtl8723au_read8(Adapter, EFUSE_CTRL);
 		return data;
-	} else
-		return 0xFF;
+	return 0xFF;
 /* Read one byte from real Efuse. */
