staging: rtl8723au: core: Remove uneeded return variable
Author: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This patch removes uneeded return variables, using only
'return _SUCCESS' instead.
It fixes the following warning detected by coccinelle:
Unneeded variable.
It was done using the following semantic patch:
identifier ret;
type T;
expression e;
-T ret = e;
... when != ret
when strict
-return ret;
+return e;
Signed-off-by: Roberta Dobrescu
drivers/staging/rtl8723au/core/rtw_mlme.c | 3 +--
drivers/staging/rtl8723au/core/rtw_mlme_ext.c | 3 +--
drivers/staging/rtl8723au/core/rtw_recv.c | 4 +---
3 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme.c b/drivers/staging/rtl8723au/core/rtw_mlme.c
index 4e2b22d..85d1eca 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme.c
@@ -50,7 +50,6 @@ static void rtw_init_mlme_timer(struct rtw_adapter *padapter)
int rtw_init_mlme_priv23a(struct rtw_adapter *padapter)
struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
- int res = _SUCCESS;
pmlmepriv->nic_hdl = padapter;
@@ -68,7 +67,7 @@ int rtw_init_mlme_priv23a(struct rtw_adapter *padapter)
rtw_clear_scan_deny(padapter);
rtw_init_mlme_timer(padapter);
- return res;
+ return _SUCCESS;
#ifdef CONFIG_8723AU_AP_MODE
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
index 2624c77..0e0f73c 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
@@ -567,7 +567,6 @@ static u8 init_channel_set(struct rtw_adapter *padapter, u8 cplan,
int init_mlme_ext_priv23a(struct rtw_adapter *padapter)
struct registry_priv *pregistrypriv = &padapter->registrypriv;
struct mlme_ext_priv *pmlmeext = &padapter->mlmeextpriv;
@@ -594,7 +593,7 @@ int init_mlme_ext_priv23a(struct rtw_adapter *padapter)
pmlmeext->mlmeext_init = true;
pmlmeext->active_keep_alive_check = true;
- return res;
+ return _SUCCESS;
void free_mlme_ext_priv23a (struct mlme_ext_priv *pmlmeext)
diff --git a/drivers/staging/rtl8723au/core/rtw_recv.c b/drivers/staging/rtl8723au/core/rtw_recv.c
index 6cdfc23..de98da5 100644
--- a/drivers/staging/rtl8723au/core/rtw_recv.c
+++ b/drivers/staging/rtl8723au/core/rtw_recv.c
@@ -1554,8 +1554,6 @@ static int wlanhdr_to_ethhdr (struct recv_frame *precvframe)
u16 eth_type, len, hdrlen;
u8 bsnaphdr;
u8 *psnap;
- int ret = _SUCCESS;
struct rtw_adapter *adapter = precvframe->adapter;
struct mlme_priv *pmlmepriv = &adapter->mlmepriv;
@@ -1616,7 +1614,7 @@ static int wlanhdr_to_ethhdr (struct recv_frame *precvframe)
- return ret;
+ return _SUCCESS;
/* perform defrag */ |
- return res;
+ return _SUCCESS;
- return res;
+ return _SUCCESS;
u8 bsnaphdr;
u8 *psnap;
- return ret;
+ return _SUCCESS;
