Staging: rtl8712: Use del_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use timer API function del_timer instead of driver
specific function _cancel_timer_ex as it is a standard
way for deactivating a timer.
This is done using Coccinelle and semantic patch used for
this is as follows:
@@ expression x; @@
- _cancel_timer_ex (&x);
+ del_timer (&x);
Signed-off-by: Vaishali Thakkar
 drivers/staging/rtl8712/rtl8712_recv.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8712/rtl8712_recv.c b/drivers/staging/rtl8712/rtl8712_recv.c
index 546414d..0ec0bda 100644
--- a/drivers/staging/rtl8712/rtl8712_recv.c
+++ b/drivers/staging/rtl8712/rtl8712_recv.c
@@ -609,7 +609,7 @@ static int recv_indicatepkt_reorder(struct _adapter *padapter,
 		spin_unlock_irqrestore(&ppending_recvframe_queue->lock, irql);
 	} else {
-		_cancel_timer_ex(&preorder_ctrl->reordering_ctrl_timer);
+		del_timer(&preorder_ctrl->reordering_ctrl_timer);
 	return _SUCCESS;
 _err_exit:
BtrLinux
Privacy Overview
