staging: rtl8712: rtl871x_mlme: Clean up tests if NULL returned on failure
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Some functions like kmalloc/kzalloc return NULL on failure.
When NULL represents failure, !x is commonly used.
This was done using Coccinelle:
expression *e;
identifier l1;
e = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\)(...);
- e == NULL
+ !e
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/rtl8712/rtl871x_mlme.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl871x_mlme.c b/drivers/staging/rtl8712/rtl871x_mlme.c
index 62d4ae8..f8b1c89 100644
--- a/drivers/staging/rtl8712/rtl871x_mlme.c
+++ b/drivers/staging/rtl8712/rtl871x_mlme.c
@@ -1205,7 +1205,7 @@ sint r8712_set_auth(struct _adapter *adapter,
return _FAIL;
psetauthparm = kzalloc(sizeof(*psetauthparm), GFP_ATOMIC);
- if (psetauthparm == NULL) {
+ if (!psetauthparm) {
kfree(pcmd);
return _FAIL;
@@ -1234,7 +1234,7 @@ sint r8712_set_key(struct _adapter *adapter,
if (!pcmd)
return _FAIL;
psetkeyparm = kzalloc(sizeof(*psetkeyparm), GFP_ATOMIC);
- if (psetkeyparm == NULL) {
+ if (!psetkeyparm) {
ret = _FAIL;
goto err_free_cmd;
return _FAIL;
kfree(pcmd);
return _FAIL;
if (!pcmd)
return _FAIL;
ret = _FAIL;
goto err_free_cmd;
