staging: rtl8712: rtl871x_ioctl_linux: Clean up tests if NULL returned on failure
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Some functions like kmalloc/kzalloc return NULL on failure.
When NULL represents failure, !x is commonly used.
This was done using Coccinelle:
expression *e;
identifier l1;
e = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\)(...);
- e == NULL
+ !e
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8712/rtl871x_ioctl_linux.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
index 1b9e249..6c02e9b 100644
--- a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
+++ b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
@@ -399,7 +399,7 @@ static int wpa_set_encryption(struct net_device *dev, struct ieee_param *param,
 		if (wep_key_len > 0) {
 			wep_key_len = wep_key_len <= 5 ? 5 : 13;
 			pwep = kzalloc(sizeof(*pwep), GFP_ATOMIC);
-			if (pwep == NULL)
+			if (!pwep)
 				return -ENOMEM;
 			pwep->KeyLength = wep_key_len;
 			pwep->Length = wep_key_len +
@@ -1793,7 +1793,7 @@ static int r871x_wx_set_enc_ext(struct net_device *dev,
 	param_len = sizeof(struct ieee_param) + pext->key_len;
 	param = kzalloc(param_len, GFP_ATOMIC);
-	if (param == NULL)
+	if (!param)
 		return -ENOMEM;
 	param->cmd = IEEE_CMD_SET_ENCRYPTION;
 	eth_broadcast_addr(param->sta_addr); |
-			if (pwep == NULL)
+			if (!pwep)
 				return -ENOMEM;
+	if (!param)
 		return -ENOMEM;
