Author: Melike Yurtoglu <aysemelikeyurtoglu@gmail.com>
This patch focuses on fixing the following warning generated
by checkpatch.pl for the file rxtx.c
Prefer ether_addr_copy() over memcpy() if the Ethernet addresses
are __aligned(2)
@@ expression e1, e2; @@
- memcpy(e1, e2, ETH_ALEN);
+ ether_addr_copy(e1, e2);
struct _adapter {
struct dvobj_priv dvobjpriv; /* 0 40*/
struct mlme_priv mlmepriv; /* 40 1560*/
/* --- cacheline 25 boundary (1600 bytes) --- */
struct cmd_priv cmdpriv; /* 1600 136*/
/* --- cacheline 27 boundary (1728 bytes) was 8 bytes ago --- */
struct evt_priv evtpriv; /* 1736 96*/
/* --- cacheline 28 boundary (1792 bytes) was 40 bytes ago --- * */
struct io_queue * pio_queue; /* 1832 8*/
struct xmit_priv xmitpriv; /* 1840 912*/
/* --- cacheline 43 boundary (2752 bytes) --- */
struct recv_priv recvpriv; /* 2752 1088*/
/* --- cacheline 60 boundary (3840 bytes) --- */
struct sta_priv stapriv; /* 3840 672*/
/* --- cacheline 70 boundary (4480 bytes) was 32 bytes ago --- * */
struct security_priv securitypriv; /* 4512 4816*/
/* --- cacheline 145 boundary (9280 bytes) was 48 bytes ago --- * */
struct registry_priv registrypriv; /* 9328 968*/
/* --- cacheline 160 boundary (10240 bytes) was 56 bytes ago --- * */
struct wlan_acl_pool acl_list; /* 10296 1536*/
/* --- cacheline 184 boundary (11776 bytes) was 56 bytes ago --- * */
struct pwrctrl_priv pwrctrlpriv; /* 11832 224*/
/* --- cacheline 188 boundary (12032 bytes) was 24 bytes ago --- * */
struct eeprom_priv eeprompriv; /* 12056 508*/
/* XXX 4 bytes hole, try to pack */
/* --- cacheline 196 boundary (12544 bytes) was 24 bytes ago --- * */
struct hal_priv halpriv; /* 12568 88*/
/* --- cacheline 197 boundary (12608 bytes) was 48 bytes ago --- * */
struct led_priv ledpriv; /* 12656 304*/
/* --- cacheline 202 boundary (12928 bytes) was 32 bytes ago --- * */
struct mp_priv mppriv; /* 12960 1080*/
/* --- cacheline 219 boundary (14016 bytes) was 24 bytes ago --- * */
s32 bDriverStopped; /* 14040 4*/
s32 bSurpriseRemoved; /* 14044 4*/
u32 IsrContent; /* 14048 4*/
u32 ImrContent; /* 14052 4*/
u8 EepromAddressSize; /* 14056 1*/
u8 hw_init_completed; /* 14057 1*/
/* XXX 6 bytes hole, try to pack */
struct task_struct * cmdThread; /* 14064 8*/
pid_t evtThread; /* 14072 4*/
/* --- cacheline 220 boundary (14080 bytes) --- */
struct task_struct * xmitThread; /* 14080 8*/
pid_t recvThread; /* 14088 4*/
uint (*dvobj_init)(struct _adapter *); /*14096 8 */
void (*dvobj_deinit)(struct _adapter *);/* 14104 8 */
struct net_device * pnetdev; /* 14112 8*/
int bup; /* 14120 4*/
struct net_device_stats stats; /* 14128 184*/
/* --- cacheline 223 boundary (14272 bytes) was 40 bytes ago --- * */
struct iw_statistics iwstats; /* 14312 32*/
/* --- cacheline 224 boundary (14336 bytes) was 8 bytes ago --- * */
int pid; /* 14344 4*/
struct work_struct wkFilterRxFF0; /* 14352 32*/
u8 blnEnableRxFF0Filter; /* 14384 1*/
/* XXX 3 bytes hole, try to pack */
spinlock_t lockRxFF0Filter; /* 14388 4*/
const struct firmware * fw; /* 14392 8*/
/* --- cacheline 225 boundary (14400 bytes) --- */
struct usb_interface * pusb_intf; /* 14400 8*/
struct mutex mutex_start; /* 14408 40*/
/* XXX last struct has 4 bytes of padding */
struct completion rtl8712_fw_ready; /* 14448 32*/
/* --- cacheline 226 boundary (14464 bytes) was 16 bytes ago --- * */
/* size: 14480, cachelines: 227, members: 40 */
/* sum members: 14451, holes: 7, sum holes: 29 */
/* paddings: 1, sum paddings: 4 */
/* last cacheline: 16 bytes */
Signed-off-by: Melike Yurtoglu
drivers/staging/rtl8712/recv_linux.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8712/recv_linux.c b/drivers/staging/rtl8712/recv_linux.c
index 409c8c8..3640dd4 100644
--- a/drivers/staging/rtl8712/recv_linux.c
+++ b/drivers/staging/rtl8712/recv_linux.c
@@ -96,7 +96,7 @@ void r8712_handle_tkip_mic_err(struct _adapter *padapter, u8 bgroup)
else
ev.flags |= IW_MICFAILURE_PAIRWISE;
ev.src_addr.sa_family = ARPHRD_ETHER;
- memcpy(ev.src_addr.sa_data, &pmlmepriv->assoc_bssid[0], ETH_ALEN);
+ ether_addr_copy(ev.src_addr.sa_data, &pmlmepriv->assoc_bssid[0]);
memset(&wrqu, 0x00, sizeof(wrqu));
wrqu.data.length = sizeof(ev);
wireless_send_event(padapter->pnetdev, IWEVMICHAELMICFAILURE, &wrqu, |
else
