Staging: rtl8712: Remove zero-testing pointer typed value
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Removes variable comparison with 0 by using !. Done using following
coccinelle script.
@ disable is_zero,isnt_zero @
expression *E;
expression E1,f;
E = f(...)
- E == 0
+ !E
- E != 0
+ E
- 0 == E
+ !E
- 0 != E
+ E
?E = E1
expression *E;
E ==
- 0
+ NULL
E !=
- 0
+ NULL
- 0
+ NULL
== E
- 0
+ NULL
!= E
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/rtl8712/rtl871x_security.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8712/rtl871x_security.c b/drivers/staging/rtl8712/rtl871x_security.c
index a178c23..bcd1a51 100644
--- a/drivers/staging/rtl8712/rtl871x_security.c
+++ b/drivers/staging/rtl8712/rtl871x_security.c
@@ -153,7 +153,7 @@ static u32 getcrc32(u8 *buf, u32 len)
u8 *p;
u32 crc;
- if (bcrc32initialized == 0)
+ if (!bcrc32initialized)
crc32_init();
crc = 0xffffffff; /* preload shift register, per CRC-32 spec */
for (p = buf; len > 0; ++p, --len) |
u8 *p;
u32 crc;
crc32_init();
