staging: rtl8712: Remove unnecessary ret variable
Author: Joseph Bisch <joseph.bisch@gmail.com>
Since the variable ret is set at the beginning of the function and
never changes its value, we can just return the value it was set to.
Found using coccinelle with misc/returnvar.cocci.
Signed-off-by: Joseph Bisch
drivers/staging/rtl8712/os_intfs.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8712/os_intfs.c b/drivers/staging/rtl8712/os_intfs.c
index b89e2d3..ab19112 100644
--- a/drivers/staging/rtl8712/os_intfs.c
+++ b/drivers/staging/rtl8712/os_intfs.c
@@ -269,7 +269,6 @@ void r8712_stop_drv_timers(struct _adapter *padapter)
static u8 init_default_value(struct _adapter *padapter)
- u8 ret = _SUCCESS;
struct registry_priv *pregistrypriv = &padapter->registrypriv;
struct xmit_priv *pxmitpriv = &padapter->xmitpriv;
struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
@@ -302,7 +301,7 @@ static u8 init_default_value(struct _adapter *padapter)
r8712_init_registrypriv_dev_network(padapter);
r8712_update_registrypriv_dev_network(padapter);
/*misc.*/
- return ret;
+ return _SUCCESS;
u8 r8712_init_drv_sw(struct _adapter *padapter) |
/*misc.*/
- return ret;
+ return _SUCCESS;
