staging: rtl8712: Remove unnecessary else after return
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
This patch fixes the checkpatch warning that else is not generally
useful after a break or return.
This was done using Coccinelle:
expression e2;
statement s1;
if(e2) { ... return ...; }
-else
         s1
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8712/rtl871x_mlme.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl871x_mlme.c b/drivers/staging/rtl8712/rtl871x_mlme.c
index 14a780e..62d4ae8 100644
--- a/drivers/staging/rtl8712/rtl871x_mlme.c
+++ b/drivers/staging/rtl8712/rtl871x_mlme.c
@@ -468,8 +468,7 @@ static int is_desired_network(struct _adapter *adapter,
 		    pnetwork->network.IELength, wps_ie,
 		    &wps_ielen))
 			return true;
-		else
-			return false;
+		return false;
 	if ((psecuritypriv->PrivacyAlgrthm != _NO_PRIVACY_) &&
 		    (pnetwork->network.Privacy == 0))  |
 		    &wps_ielen))
 			return true;
-		else
-			return false;
+		return false;
