Author: G Pooja Shamili <poojashamili@gmail.com>
The unnecessary parantheses on the right side of assignments were removed,
as in most cases (expect for ==, >=, <=, !=), they are futile.
This was done using Coccinelle, the semantic patch being:
expression E1,E2,E3;
binary operator bin_op = {==,>=,<=,!=};
E1 =
E2 bin_op E3
E2
Signed-off-by: G Pooja Shamili
drivers/staging/rtl8712/rtl871x_mp.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl871x_mp.c b/drivers/staging/rtl8712/rtl871x_mp.c
index 9b5a4e7..5e4fda1 100644
--- a/drivers/staging/rtl8712/rtl871x_mp.c
+++ b/drivers/staging/rtl8712/rtl871x_mp.c
@@ -235,7 +235,7 @@ static u8 set_bb_reg(struct _adapter *pAdapter,
if (bitmask != bMaskDWord) {
org_value = r8712_bb_reg_read(pAdapter, offset);
bit_shift = bitshift(bitmask);
- new_value = ((org_value & (~bitmask)) | (value << bit_shift));
+ new_value = (org_value & (~bitmask)) | (value << bit_shift);
} else {
new_value = value;
@@ -260,7 +260,7 @@ static u8 set_rf_reg(struct _adapter *pAdapter, u8 path, u8 offset, u32 bitmask,
org_value = r8712_rf_reg_read(pAdapter, path, offset);
} else {
new_value = value;
@@ -327,10 +327,10 @@ void r8712_SetTxAGCOffset(struct _adapter *pAdapter, u32 ulTxAGCOffset)
u32 TxAGCOffset_B, TxAGCOffset_C, TxAGCOffset_D, tmpAGC;
- TxAGCOffset_B = (ulTxAGCOffset & 0x000000ff);
+ TxAGCOffset_B = ulTxAGCOffset & 0x000000ff;
TxAGCOffset_C = (ulTxAGCOffset & 0x0000ff00) >> 8;
TxAGCOffset_D = (ulTxAGCOffset & 0x00ff0000) >> 16;
- tmpAGC = (TxAGCOffset_D << 8 | TxAGCOffset_C << 4 | TxAGCOffset_B);
+ tmpAGC = TxAGCOffset_D << 8 | TxAGCOffset_C << 4 | TxAGCOffset_B;
set_bb_reg(pAdapter, rFPGA0_TxGainStage,
(bXBTxAGC | bXCTxAGC | bXDTxAGC), tmpAGC);
} else {
new_value = value;
} else {
new_value = value;
