staging: rtl8712: Make return of 0 explicit
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Delete unnecessary local variable whose value is always 0 and
return 0 as the result.
The following Coccinelle script was used:
identifier ret; expression E;
type T;
- T ret;
- T ret = 0;
... when != \(ret=E
\|ret--\|ret++\|--ret\|++ret\|ret-=E\|ret+=E\|ret|=E\|ret&=E\)
?-ret = 0;
... when != \(ret=E
return
- ret
+ 0
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/rtl8712/xmit_linux.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8712/xmit_linux.c b/drivers/staging/rtl8712/xmit_linux.c
index f708d95..695f9b9 100644
--- a/drivers/staging/rtl8712/xmit_linux.c
+++ b/drivers/staging/rtl8712/xmit_linux.c
@@ -161,19 +161,15 @@ int r8712_xmit_entry(_pkt *pkt, struct net_device *pnetdev)
struct xmit_frame *pxmitframe = NULL;
struct _adapter *padapter = netdev_priv(pnetdev);
struct xmit_priv *pxmitpriv = &(padapter->xmitpriv);
- int ret = 0;
if (!r8712_if_up(padapter)) {
- ret = 0;
goto _xmit_entry_drop;
pxmitframe = r8712_alloc_xmitframe(pxmitpriv);
if (!pxmitframe) {
- ret = 0;
if ((!r8712_update_attrib(padapter, pkt, &pxmitframe->attrib))) {
- ret = 0;
padapter->ledpriv.LedControlHandler(padapter, LED_CTL_TX);
@@ -185,11 +181,11 @@ int r8712_xmit_entry(_pkt *pkt, struct net_device *pnetdev)
pxmitpriv->tx_pkts++;
pxmitpriv->tx_bytes += pxmitframe->attrib.last_txcmdsz;
- return ret;
+ return 0;
_xmit_entry_drop:
if (pxmitframe)
r8712_free_xmitframe(pxmitpriv, pxmitframe);
pxmitpriv->tx_drop++;
dev_kfree_skb_any(pkt);
- return ret;
+ return 0;
- int ret = 0;
- ret = 0;
if (!pxmitframe) {
- ret = 0;
- ret = 0;
- return ret;
+ return 0;
_xmit_entry_drop:
if (pxmitframe)
- return ret;
+ return 0;
