staging: rtl8712: Drop unneeded cast on netdev_priv
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The result of netdev_priv is already implicitly cast to the type of the
left side of the assignment.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
type T;
T *x;
x =
- (T *)
  netdev_priv(...)
Signed-off-by: Julia Lawall
 drivers/staging/rtl8712/os_intfs.c            | 10 ++--
 drivers/staging/rtl8712/rtl871x_ioctl_linux.c | 70 +++++++++++++--------------
 drivers/staging/rtl8712/xmit_linux.c          |  2 +-
 3 files changed, 41 insertions(+), 41 deletions(-)
diff --git a/drivers/staging/rtl8712/os_intfs.c b/drivers/staging/rtl8712/os_intfs.c
index 78815b6..6e776e5 100644
--- a/drivers/staging/rtl8712/os_intfs.c
+++ b/drivers/staging/rtl8712/os_intfs.c
@@ -177,7 +177,7 @@ static uint loadparam(struct _adapter *padapter, struct  net_device *pnetdev)
 static int r871x_net_set_mac_address(struct net_device *pnetdev, void *p)
-	struct _adapter *padapter = (struct _adapter *)netdev_priv(pnetdev);
+	struct _adapter *padapter = netdev_priv(pnetdev);
 	struct sockaddr *addr = p;
 	if (padapter->bup == false)
@@ -187,7 +187,7 @@ static int r871x_net_set_mac_address(struct net_device *pnetdev, void *p)
 static struct net_device_stats *r871x_net_get_stats(struct net_device *pnetdev)
-	struct _adapter *padapter = (struct _adapter *) netdev_priv(pnetdev);
 	struct xmit_priv *pxmitpriv = &(padapter->xmitpriv);
 	struct recv_priv *precvpriv = &(padapter->recvpriv);
@@ -221,7 +221,7 @@ struct net_device *r8712_init_netdev(void)
 		strcpy(ifname, "wlan%d");
 		dev_alloc_name(pnetdev, ifname);
-	padapter = (struct _adapter *) netdev_priv(pnetdev);
+	padapter = netdev_priv(pnetdev);
 	padapter->pnetdev = pnetdev;
 	pr_info("r8712u: register rtl8712_netdev_ops to netdev_ops\n");
 	pnetdev->netdev_ops = &rtl8712_netdev_ops;
@@ -384,7 +384,7 @@ static void enable_video_mode(struct _adapter *padapter, int cbw40_value)
 static int netdev_open(struct net_device *pnetdev)
 	mutex_lock(&padapter->mutex_start);
 	if (padapter->bup == false) {
@@ -452,7 +452,7 @@ netdev_open_error:
 static int netdev_close(struct net_device *pnetdev)
 	/* Close LED*/
 	padapter->ledpriv.LedControlHandler(padapter, LED_CTL_POWER_OFF);
diff --git a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
index c39d031..42fba3f 100644
--- a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
+++ b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
@@ -363,7 +363,7 @@ static inline char *translate_scan(struct _adapter *padapter,
 static int wpa_set_auth_algs(struct net_device *dev, u32 value)
-	struct _adapter *padapter = (struct _adapter *) netdev_priv(dev);
+	struct _adapter *padapter = netdev_priv(dev);
 	int ret = 0;
 	if ((value & AUTH_ALG_SHARED_KEY) && (value & AUTH_ALG_OPEN_SYSTEM)) {
@@ -395,7 +395,7 @@ static int wpa_set_encryption(struct net_device *dev, struct ieee_param *param,
 	int ret = 0;
 	u32 wep_key_idx, wep_key_len = 0;
 	struct NDIS_802_11_WEP	 *pwep = NULL;
-	struct _adapter *padapter = (struct _adapter *)netdev_priv(dev);
 	struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
 	struct security_priv *psecuritypriv = &padapter->securitypriv;
@@ -629,7 +629,7 @@ static int r8711_wx_get_name(struct net_device *dev,
 			     struct iw_request_info *info,
 			     union iwreq_data *wrqu, char *extra)
 	u32 ht_ielen = 0;
 	char *p;
 	u8 ht_cap = false;
@@ -685,7 +685,7 @@ static int r8711_wx_set_freq(struct net_device *dev,
 	struct iw_freq *fwrq = &wrqu->freq;
 	int rc = 0;
@@ -721,7 +721,7 @@ static int r8711_wx_get_freq(struct net_device *dev,
 	struct ndis_wlan_bssid_ex *pcur_bss = &pmlmepriv->cur_network.network;
@@ -740,7 +740,7 @@ static int r8711_wx_set_mode(struct net_device *dev,
 			     struct iw_request_info *a,
 			     union iwreq_data *wrqu, char *b)
 	enum NDIS_802_11_NETWORK_INFRASTRUCTURE networkType;
 	switch (wrqu->mode) {
@@ -771,7 +771,7 @@ static int r8711_wx_set_mode(struct net_device *dev,
 static int r8711_wx_get_mode(struct net_device *dev, struct iw_request_info *a,
 	if (check_fwstate(pmlmepriv, WIFI_STATION_STATE) == true)
@@ -790,7 +790,7 @@ static int r871x_wx_set_pmkid(struct net_device *dev,
 	struct iw_pmksa *pPMK = (struct iw_pmksa *) extra;
 	u8 strZeroMacAddress[ETH_ALEN] = {0x00};
@@ -1061,7 +1061,7 @@ static int r8711_wx_set_wap(struct net_device *dev,
 			 char *extra)
 	int ret = -EINPROGRESS;
 	struct  __queue *queue = &pmlmepriv->scanned_queue;
 	struct sockaddr *temp = (struct sockaddr *)awrq;
@@ -1110,7 +1110,7 @@ static int r8711_wx_get_wap(struct net_device *dev,
@@ -1128,7 +1128,7 @@ static int r871x_wx_set_mlme(struct net_device *dev,
 	int ret = 0;
 	struct iw_mlme *mlme = (struct iw_mlme *) extra;
 	if (mlme == NULL)
@@ -1160,7 +1160,7 @@ static int r8711_wx_set_scan(struct net_device *dev,
 	u8 status = true;
@@ -1209,7 +1209,7 @@ static int r8711_wx_get_scan(struct net_device *dev,
 	struct wlan_network *pnetwork = NULL;
@@ -1263,7 +1263,7 @@ static int r8711_wx_set_essid(struct net_device *dev,
@@ -1326,7 +1326,7 @@ static int r8711_wx_get_essid(struct net_device *dev,
 	u32 len, ret = 0;
@@ -1346,7 +1346,7 @@ static int r8711_wx_set_rate(struct net_device *dev,
 	u32 target_rate = wrqu->bitrate.value;
 	u32 fixed = wrqu->bitrate.fixed;
 	u32 ratevalue = 0;
@@ -1418,7 +1418,7 @@ static int r8711_wx_get_rate(struct net_device *dev,
 	struct ieee80211_ht_cap *pht_capie;
@@ -1475,7 +1475,7 @@ static int r8711_wx_get_rts(struct net_device *dev,
 	wrqu->rts.value = padapter->registrypriv.rts_thresh;
 	wrqu->rts.fixed = 0;	/* no auto select */
@@ -1486,7 +1486,7 @@ static int r8711_wx_set_frag(struct net_device *dev,
 	if (wrqu->frag.disabled)
 		padapter->xmitpriv.frag_len = MAX_FRAG_THRESHOLD;
@@ -1503,7 +1503,7 @@ static int r8711_wx_get_frag(struct net_device *dev,
 	wrqu->frag.value = padapter->xmitpriv.frag_len;
 	wrqu->frag.fixed = 0;	/* no auto select */
@@ -1529,7 +1529,7 @@ static int r8711_wx_set_enc(struct net_device *dev,
 	struct NDIS_802_11_WEP	 wep;
 	enum NDIS_802_11_AUTHENTICATION_MODE authmode;
 	struct iw_point *erq = &(wrqu->encoding);
 	key = erq->flags & IW_ENCODE_INDEX;
 	memset(&wep, 0, sizeof(struct NDIS_802_11_WEP));
@@ -1621,7 +1621,7 @@ static int r8711_wx_get_enc(struct net_device *dev,
 				union iwreq_data *wrqu, char *keybuf)
 	uint key, ret = 0;
 	struct	mlme_priv	*pmlmepriv = &(padapter->mlmepriv);
@@ -1693,7 +1693,7 @@ static int r871x_wx_set_gen_ie(struct net_device *dev,
 	return r871x_set_wpa_ie(padapter, extra, wrqu->data.length);
@@ -1702,7 +1702,7 @@ static int r871x_wx_set_auth(struct net_device *dev,
 	struct iw_param *param = (struct iw_param *)&(wrqu->param);
 	int paramid;
 	int paramval;
@@ -1849,7 +1849,7 @@ static int r8711_wx_read32(struct net_device *dev,
 	u32 addr;
 	u32 data32;
@@ -1866,7 +1866,7 @@ static int r8711_wx_write32(struct net_device *dev,
 	u32 addr;
 	u32 data32;
@@ -1894,7 +1894,7 @@ static int r871x_mp_ioctl_hdl(struct net_device *dev,
 	struct iw_point *p = &wrqu->data;
 	struct oid_par_priv oid_par;
 	struct mp_ioctl_handler *phandler;
@@ -1973,7 +1973,7 @@ static int r871x_get_ap_info(struct net_device *dev,
 	struct iw_point *pdata = &wrqu->data;
@@ -2044,7 +2044,7 @@ static int r871x_set_pid(struct net_device *dev,
 	if ((padapter->bDriverStopped) || (pdata == NULL))
@@ -2059,7 +2059,7 @@ static int r871x_set_chplan(struct net_device *dev,
 	int ret = 0;
 	int ch_plan = -1;
@@ -2079,7 +2079,7 @@ static int r871x_wps_start(struct net_device *dev,
 	u32   u32wps_start = 0;
@@ -2103,7 +2103,7 @@ static int r871x_wps_start(struct net_device *dev,
 static int wpa_set_param(struct net_device *dev, u8 name, u32 value)
 	switch (name) {
 	case IEEE_PARAM_WPA_ENABLED:
@@ -2155,7 +2155,7 @@ static int wpa_set_param(struct net_device *dev, u8 name, u32 value)
 static int wpa_mlme(struct net_device *dev, u32 command, u32 reason)
 	switch (command) {
 	case IEEE_MLME_STA_DEAUTH:
@@ -2176,7 +2176,7 @@ static int wpa_supplicant_ioctl(struct net_device *dev, struct iw_point *p)
 	struct ieee_param *param;
 	int ret = 0;
 	if (p->length < sizeof(struct ieee_param) || !p->pointer)
 		return -EINVAL;
@@ -2329,7 +2329,7 @@ static iw_handler r8711_private_handler[] = {
 static struct iw_statistics *r871x_get_wireless_stats(struct net_device *dev)
 	struct iw_statistics *piwstats = &padapter->iwstats;
 	int tmp_level = 0;
 	int tmp_qual = 0;
diff --git a/drivers/staging/rtl8712/xmit_linux.c b/drivers/staging/rtl8712/xmit_linux.c
index 039b598..d15fb1a 100644
--- a/drivers/staging/rtl8712/xmit_linux.c
+++ b/drivers/staging/rtl8712/xmit_linux.c
@@ -162,7 +162,7 @@ void r8712_xmit_complete(struct _adapter *padapter, struct xmit_frame *pxframe)
 int r8712_xmit_entry(_pkt *pkt, struct  net_device *pnetdev)
 	struct xmit_frame *pxmitframe = NULL;
 	int ret = 0;
BtrLinux
Privacy Overview
