Staging: rtl8712: Clean up tests if NULL returned on failure
Author: Bhumika Goyal <bhumirks@gmail.com>
Some functions like kmalloc/usb_alloc_urb/kmalloc_array returns NULL as
their return value on failure. !x is generally preferred over x==NULL
or NULL==x so make use of !x if the value returned on failure
by these functions is NULL.
Done using coccinelle:
expression e;
statement S;
e = \(kmalloc\|devm_kzalloc\|kmalloc_array
     \|devm_ioremap\|usb_alloc_urb\|alloc_netdev\)(...);
- if(e==NULL)
+ if(!e)
  S
Signed-off-by: Bhumika Goyal
 drivers/staging/rtl8712/recv_linux.c      | 2 +-
 drivers/staging/rtl8712/rtl871x_io.c      | 2 +-
 drivers/staging/rtl8712/rtl871x_mlme.c    | 6 +++---
 drivers/staging/rtl8712/rtl871x_mp.c      | 4 ++--
 drivers/staging/rtl8712/rtl871x_sta_mgt.c | 2 +-
 drivers/staging/rtl8712/rtl871x_xmit.c    | 8 ++++----
 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/rtl8712/recv_linux.c b/drivers/staging/rtl8712/recv_linux.c
index 2f5460d..be970ef 100644
--- a/drivers/staging/rtl8712/recv_linux.c
+++ b/drivers/staging/rtl8712/recv_linux.c
@@ -56,7 +56,7 @@ int r8712_os_recvbuf_resource_alloc(struct _adapter *padapter,
 	precvbuf->irp_pending = false;
 	precvbuf->purb = usb_alloc_urb(0, GFP_KERNEL);
-	if (precvbuf->purb == NULL)
+	if (!precvbuf->purb)
 		res = _FAIL;
 	precvbuf->pskb = NULL;
 	precvbuf->reuse = false;
diff --git a/drivers/staging/rtl8712/rtl871x_io.c b/drivers/staging/rtl8712/rtl871x_io.c
index fbbc635..3a10940 100644
--- a/drivers/staging/rtl8712/rtl871x_io.c
+++ b/drivers/staging/rtl8712/rtl871x_io.c
@@ -113,7 +113,7 @@ uint r8712_alloc_io_queue(struct _adapter *adapter)
 	struct io_req *pio_req;
 	pio_queue = kmalloc(sizeof(*pio_queue), GFP_ATOMIC);
-	if (pio_queue == NULL)
+	if (!pio_queue)
 		goto alloc_io_queue_fail;
 	INIT_LIST_HEAD(&pio_queue->free_ioreqs);
 	INIT_LIST_HEAD(&pio_queue->processing);
diff --git a/drivers/staging/rtl8712/rtl871x_mlme.c b/drivers/staging/rtl8712/rtl871x_mlme.c
index 1b022db..14a780e 100644
--- a/drivers/staging/rtl8712/rtl871x_mlme.c
+++ b/drivers/staging/rtl8712/rtl871x_mlme.c
@@ -64,7 +64,7 @@ static sint _init_mlme_priv(struct _adapter *padapter)
 	memset(&pmlmepriv->assoc_ssid, 0, sizeof(struct ndis_802_11_ssid));
 	pbuf = kmalloc_array(MAX_BSS_CNT, sizeof(struct wlan_network),
 			     GFP_ATOMIC);
-	if (pbuf == NULL)
+	if (!pbuf)
 		return _FAIL;
 	pmlmepriv->free_bss_buf = pbuf;
 	pnetwork = (struct wlan_network *)pbuf;
@@ -1202,7 +1202,7 @@ sint r8712_set_auth(struct _adapter *adapter,
 	struct setauth_parm *psetauthparm;
 	pcmd = kmalloc(sizeof(*pcmd), GFP_ATOMIC);
-	if (pcmd == NULL)
+	if (!pcmd)
 		return _FAIL;
 	psetauthparm = kzalloc(sizeof(*psetauthparm), GFP_ATOMIC);
@@ -1232,7 +1232,7 @@ sint r8712_set_key(struct _adapter *adapter,
 	sint ret = _SUCCESS;
-	if (pcmd == NULL)
+	if (!pcmd)
 		return _FAIL;
 	psetkeyparm = kzalloc(sizeof(*psetkeyparm), GFP_ATOMIC);
 	if (psetkeyparm == NULL) {
diff --git a/drivers/staging/rtl8712/rtl871x_mp.c b/drivers/staging/rtl8712/rtl871x_mp.c
index 44da4fe..9b5a4e7 100644
--- a/drivers/staging/rtl8712/rtl871x_mp.c
+++ b/drivers/staging/rtl8712/rtl871x_mp.c
@@ -281,10 +281,10 @@ void r8712_SetChannel(struct _adapter *pAdapter)
 	u16 code = GEN_CMD_CODE(_SetChannel);
-	if (pcmd == NULL)
+	if (!pcmd)
 		return;
 	pparm = kmalloc(sizeof(*pparm), GFP_ATOMIC);
-	if (pparm == NULL) {
+	if (!pparm) {
 		kfree(pcmd);
 		return;
diff --git a/drivers/staging/rtl8712/rtl871x_sta_mgt.c b/drivers/staging/rtl8712/rtl871x_sta_mgt.c
index 3fe45b6..e90c00d 100644
--- a/drivers/staging/rtl8712/rtl871x_sta_mgt.c
+++ b/drivers/staging/rtl8712/rtl871x_sta_mgt.c
@@ -53,7 +53,7 @@ u32 _r8712_init_sta_priv(struct	sta_priv *pstapriv)
 	pstapriv->pallocated_stainfo_buf = kmalloc(sizeof(struct sta_info) *
 						   NUM_STA + 4, GFP_ATOMIC);
-	if (pstapriv->pallocated_stainfo_buf == NULL)
+	if (!pstapriv->pallocated_stainfo_buf)
 		return _FAIL;
 	pstapriv->pstainfo_buf = pstapriv->pallocated_stainfo_buf + 4 -
 		((addr_t)(pstapriv->pallocated_stainfo_buf) & 3);
diff --git a/drivers/staging/rtl8712/rtl871x_xmit.c b/drivers/staging/rtl8712/rtl871x_xmit.c
index 506136c..c6d952f 100644
--- a/drivers/staging/rtl8712/rtl871x_xmit.c
+++ b/drivers/staging/rtl8712/rtl871x_xmit.c
@@ -89,7 +89,7 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
 	pxmitpriv->pallocated_frame_buf = kmalloc(NR_XMITFRAME * sizeof(struct xmit_frame) + 4,
 						  GFP_ATOMIC);
-	if (pxmitpriv->pallocated_frame_buf == NULL) {
+	if (!pxmitpriv->pallocated_frame_buf) {
 		pxmitpriv->pxmit_frame_buf = NULL;
 		return _FAIL;
@@ -128,7 +128,7 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
 	_init_queue(&pxmitpriv->pending_xmitbuf_queue);
 	pxmitpriv->pallocated_xmitbuf = kmalloc(NR_XMITBUFF * sizeof(struct xmit_buf) + 4,
 						GFP_ATOMIC);
-	if (pxmitpriv->pallocated_xmitbuf  == NULL)
+	if (!pxmitpriv->pallocated_xmitbuf)
 		return _FAIL;
 	pxmitpriv->pxmitbuf = pxmitpriv->pallocated_xmitbuf + 4 -
 			      ((addr_t)(pxmitpriv->pallocated_xmitbuf) & 3);
@@ -137,7 +137,7 @@ sint _r8712_init_xmit_priv(struct xmit_priv *pxmitpriv,
 		INIT_LIST_HEAD(&pxmitbuf->list);
 		pxmitbuf->pallocated_buf = kmalloc(MAX_XMITBUF_SZ + XMITBUF_ALIGN_SZ,
 						   GFP_ATOMIC);
-		if (pxmitbuf->pallocated_buf == NULL)
+		if (!pxmitbuf->pallocated_buf)
 			return _FAIL;
 		pxmitbuf->pbuf = pxmitbuf->pallocated_buf + XMITBUF_ALIGN_SZ -
 				 ((addr_t) (pxmitbuf->pallocated_buf) &
@@ -943,7 +943,7 @@ static void alloc_hwxmits(struct _adapter *padapter)
 	pxmitpriv->hwxmit_entry = HWXMIT_ENTRY;
 	pxmitpriv->hwxmits = kmalloc_array(pxmitpriv->hwxmit_entry,
 				sizeof(struct hw_xmit), GFP_ATOMIC);
-	if (pxmitpriv->hwxmits == NULL)
+	if (!pxmitpriv->hwxmits)
 		return;
 	hwxmits = pxmitpriv->hwxmits;
 	if (pxmitpriv->hwxmit_entry == 5) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
