staging: rtl8193*: Remove double test
The 1 element of the array is tested twice. Change the code so that the
remaining 3 element of the array is tested instead of testing the 1 element
a second time.
The sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@expression@
expression E;
* E
|| ... || E
* E
&& ... && E
Signed-off-by: Julia Lawall
drivers/staging/rtl8192e/ieee80211/ieee80211_rx.c | 2 +-
drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192e/ieee80211/ieee80211_rx.c
index aaf9b9d..9318695 100644
--- a/drivers/staging/rtl8192e/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192e/ieee80211/ieee80211_rx.c
@@ -2579,7 +2579,7 @@ static inline void update_network(struct ieee80211_network *dst,
if(src->wmm_param[0].ac_aci_acm_aifsn|| \
src->wmm_param[1].ac_aci_acm_aifsn|| \
src->wmm_param[2].ac_aci_acm_aifsn|| \
- src->wmm_param[1].ac_aci_acm_aifsn) {
+ src->wmm_param[3].ac_aci_acm_aifsn) {
memcpy(dst->wmm_param, src->wmm_param, WME_AC_PRAM_LEN);
//dst->QoS_Enable = src->QoS_Enable;
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index 192123f..c8ca9d8 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -2391,7 +2391,7 @@ static inline void update_network(struct ieee80211_network *dst,
//dst->QoS_Enable = src->QoS_Enable; |
