Staging: rtl8192u: using random_ether_addr() to generate random MAC
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using random_ether_addr() to generate a random Ethernet
address (MAC) that is not multicast and has the local
assigned bit set. Not need to duplicating its implementation.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 8 +-------
 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 6721ed9..9f625bc 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -2288,13 +2288,7 @@ void ieee80211_stop_queue(struct ieee80211_device *ieee)
 inline void ieee80211_randomize_cell(struct ieee80211_device *ieee)
-	get_random_bytes(ieee->current_network.bssid, ETH_ALEN);
-	/* an IBSS cell address must have the two less significant
-	 * bits of the first byte = 2
-	ieee->current_network.bssid[0] &= ~0x01;
-	ieee->current_network.bssid[0] |= 0x02;
+	random_ether_addr(ieee->current_network.bssid);
 /* called in user context only */
BtrLinux
Privacy Overview
