Staging: rtl8192u: Use put_unaligned_le16 in rtl819x_BAProc.c
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le16.
This is done using Coccinelle and semantic patch used is as follows:
@a@
typedef u16, __le16, uint16_t;
{u16,__le16,uint16_t} e16;
identifier tmp;
expression ptr;
expression y,e;
type T;
type T;
- tmp = cpu_to_le16(y);
<+... when != tmp
- memcpy(ptr, (T)&tmp, \(2\|sizeof(u16)\|sizeof(__le16)\|sizeof(uint16_t)\|sizeof(e16)\));
+ put_unaligned_le16(y,ptr);
- memcpy(ptr, (T)&tmp, ...);
? tmp = e
@@ type T; identifier a.tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
 .../staging/rtl8192u/ieee80211/rtl819x_BAProc.c    | 24 +++++++++++-----------
 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
index a9fd2cb..1b4623c 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
@@ -4,6 +4,8 @@
  * ADDBAREQ ADDBARSP and DELBA packet is still on consideration. Temporarily use MANAGE QUEUE instead of Normal Queue.
  * WB 2008-05-27
+#include <asm/byteorder.h>
+#include <asm/unaligned.h>
 #include "ieee80211.h"
 #include "rtl819x_BA.h"
@@ -110,7 +112,6 @@ static struct sk_buff *ieee80211_ADDBA(struct ieee80211_device *ieee, u8 *Dst, P
 	struct sk_buff *skb = NULL;
 	 struct ieee80211_hdr_3addr *BAReq = NULL;
 	u8 *tag = NULL;
-	__le16 tmp = 0;
 	u16 len = ieee->tx_headroom + 9;
 	//category(1) + action field(1) + Dialog Token(1) + BA Parameter Set(2) +  BA Timeout Value(2) +  BA Start SeqCtrl(2)(or StatusCode(2))
 	IEEE80211_DEBUG(IEEE80211_DL_TRACE | IEEE80211_DL_BA, "========>%s(), frame(%d) sentd to:%pM, ieee->dev:%p\n", __func__, type, Dst, ieee->dev);
@@ -149,17 +150,17 @@ static struct sk_buff *ieee80211_ADDBA(struct ieee80211_device *ieee, u8 *Dst, P
 		// Status Code
 		printk("=====>to send ADDBARSP\n");
-		tmp = cpu_to_le16(StatusCode);
-		memcpy(tag, (u8 *)&tmp, 2);
+		put_unaligned_le16(StatusCode, tag);
 		tag += 2;
 	// BA Parameter Set
-	tmp = cpu_to_le16(pBA->BaParamSet.shortData);
+	put_unaligned_le16(pBA->BaParamSet.shortData, tag);
 	tag += 2;
 	// BA Timeout Value
-	tmp = cpu_to_le16(pBA->BaTimeoutValue);
+	put_unaligned_le16(pBA->BaTimeoutValue, tag);
 	tag += 2;
 	if (ACT_ADDBAREQ == type)
@@ -196,7 +197,6 @@ static struct sk_buff *ieee80211_DELBA(
 	 struct ieee80211_hdr_3addr *Delba = NULL;
 	u8 *tag = NULL;
-	__le16 tmp = 0;
 	//len = head len + DELBA Parameter Set(2) + Reason Code(2)
 	u16 len = 6 + ieee->tx_headroom;
@@ -230,12 +230,12 @@ static struct sk_buff *ieee80211_DELBA(
 	*tag ++= ACT_DELBA;
 	// DELBA Parameter Set
-	tmp = cpu_to_le16(DelbaParamSet.shortData);
+	put_unaligned_le16(DelbaParamSet.shortData, tag);
 	tag += 2;
 	// Reason Code
-	tmp = cpu_to_le16(ReasonCode);
+	put_unaligned_le16(ReasonCode, tag);
 	tag += 2;
 	IEEE80211_DEBUG_DATA(IEEE80211_DL_DATA|IEEE80211_DL_BA, skb->data, skb->len);
BtrLinux
Privacy Overview
