staging: rtl8192u: use memdup_user to simplify code
Author: Teodora Baluta <teobaluta@gmail.com>
Use memdup_user rather than duplicating its implementation. Fix the
following coccinelle warnings:
drivers/staging/rtl8192u/r8192U_core.c:3792:7-14: WARNING opportunity for memdup_user
drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c:3153:9-16: WARNING opportunity for memdup_user
Signed-off-by: Teodora Baluta
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 11 +++--------
 drivers/staging/rtl8192u/r8192U_core.c                 | 11 +++--------
 2 files changed, 6 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 5fd6969..662c7e4 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -3150,14 +3150,9 @@ int ieee80211_wpa_supplicant_ioctl(struct ieee80211_device *ieee, struct iw_poin
 		goto out;
-	param = kmalloc(p->length, GFP_KERNEL);
-	if (param == NULL){
-		ret = -ENOMEM;
-		goto out;
-	if (copy_from_user(param, p->pointer, p->length)) {
-		kfree(param);
-		ret = -EFAULT;
+	param = memdup_user(p->pointer, p->length);
+	if (IS_ERR(param)) {
+		ret = PTR_ERR(param);
 		goto out;
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index 63a4cdf..c2bcbe2 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -3789,14 +3789,9 @@ int rtl8192_ioctl(struct net_device *dev, struct ifreq *rq, int cmd)
 		goto out;
-	ipw = kmalloc(p->length, GFP_KERNEL);
-	if (ipw == NULL) {
-		ret = -ENOMEM;
-		goto out;
-	if (copy_from_user(ipw, p->pointer, p->length)) {
-		kfree(ipw);
-		ret = -EFAULT;
+	ipw = memdup_user(p->pointer, p->length);
+	if (IS_ERR(ipw)) {
+		ret = PTR_ERR(ipw);
 		goto out;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
