staging: rtl8192u: Use kzalloc instead of kmalloc.
Author: Navya Sri Nizamkari <navyasri.tech@gmail.com>
This patch uses kzalloc instead of kmalloc function.
A coccinelle script was used to make this change.
Signed-off-by: Navya Sri Nizamkari
drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 878086a..d93e5fd 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -3025,12 +3025,11 @@ static int ieee80211_wpa_set_encryption(struct ieee80211_device *ieee,
ieee80211_crypt_delayed_deinit(ieee, crypt);
- new_crypt = kmalloc(sizeof(*new_crypt), GFP_KERNEL);
+ new_crypt = kzalloc(sizeof(*new_crypt), GFP_KERNEL);
if (new_crypt == NULL) {
ret = -ENOMEM;
goto done;
- memset(new_crypt, 0, sizeof(struct ieee80211_crypt_data));
new_crypt->ops = ops;
if (new_crypt->ops && try_module_get(new_crypt->ops->owner))
new_crypt->priv = |
ret = -ENOMEM;
goto done;
new_crypt->priv =
