Staging: rtl8192u: Rename struct to avoid CamelCase
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch renames struct DRxPathSel to dynamic_rx_path_sel in order to
keep the notations consistent and to remove the warning:
"CHECK: Avoid CamelCase". Done with coccinelle:
struct
-DRxPathSel
+dynamic_rx_path_sel
struct
-DRxPathSel
Signed-off-by: Cristina Opriceana
 drivers/staging/rtl8192u/r8192U_dm.c | 2 +-
 drivers/staging/rtl8192u/r8192U_dm.h | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 402abdf..12dd19e 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -40,7 +40,7 @@ struct dig dm_digtable;
 /* Store current software write register content for MAC PHY. */
 u8		dm_shadow[16][256] = { {0} };
 /* For Dynamic Rx Path Selection by Signal Strength */
-struct DRxPathSel DM_RxPathSelTable;
+struct dynamic_rx_path_sel DM_RxPathSelTable;
 /*------------------------Define global variable-----------------------------*/
diff --git a/drivers/staging/rtl8192u/r8192U_dm.h b/drivers/staging/rtl8192u/r8192U_dm.h
index 091fdd1..6cd32eb4 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.h
+++ b/drivers/staging/rtl8192u/r8192U_dm.h
@@ -163,7 +163,7 @@ typedef enum tag_dig_cck_cs_ratio_state_definition {
 	DIG_CS_RATIO_HIGHER = 1,
 	DIG_CS_MAX
 } dm_dig_cs_ratio_e;
-struct DRxPathSel {
+struct dynamic_rx_path_sel {
 	u8		Enable;
 	u8		DbgMode;
 	u8		cck_method;
@@ -202,7 +202,7 @@ typedef struct tag_Tx_Config_Cmd_Format {
 /*------------------------Export global variable----------------------------*/
 extern struct dig dm_digtable;
 extern u8 dm_shadow[16][256];
-extern struct DRxPathSel DM_RxPathSelTable;
+extern struct dynamic_rx_path_sel DM_RxPathSelTable;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
