staging: rtl8192u: Removed redundant bool comparisons in r8192U_dm.c
Author: Harisangam Sharvari <sharisan@visteon.com>
This patch was detected with the help of coccinelle tool.
The redundant comparisons of bool variables are removed in r8192U_dm.c.
Signed-off-by: Harisangam Sharvari
drivers/staging/rtl8192u/r8192U_dm.c | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 416a1dd..7ca5d8f 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -563,7 +563,7 @@ static void dm_TXPowerTrackingCallback_TSSI(struct net_device *dev)
break;
- if (viviflag == true) {
+ if (viviflag) {
write_nic_byte(dev, 0x1ba, 0);
viviflag = false;
RT_TRACE(COMP_POWER_TRACKING, "we filtered the data\n");
@@ -766,7 +766,7 @@ void dm_txpower_trackingcallback(struct work_struct *work)
struct r8192_priv *priv = container_of(dwork, struct r8192_priv, txpower_tracking_wq);
struct net_device *dev = priv->ieee80211->dev;
- if (priv->bDcut == true)
+ if (priv->bDcut)
dm_TXPowerTrackingCallback_TSSI(dev);
else
dm_TXPowerTrackingCallback_ThermalMeter(dev);
@@ -1301,7 +1301,7 @@ void dm_initialize_txpower_tracking(struct net_device *dev)
struct r8192_priv *priv = ieee80211_priv(dev);
+ if (priv->bDcut)
dm_InitializeTXPowerTracking_TSSI(dev);
else
dm_InitializeTXPowerTracking_ThermalMeter(dev);
@@ -1357,7 +1357,7 @@ static void dm_check_txpower_tracking(struct net_device *dev)
#ifdef RTL8190P
dm_CheckTXPowerTracking_TSSI(dev);
#else
+ if (priv->bDcut)
else
dm_CheckTXPowerTracking_ThermalMeter(dev);
@@ -1467,7 +1467,7 @@ void dm_cck_txpower_adjust(struct net_device *dev, bool binch14)
{ /* dm_CCKTxPowerAdjust */
+ if (priv->bDcut)
dm_CCKTxPowerAdjust_TSSI(dev, binch14);
else
dm_CCKTxPowerAdjust_ThermalMeter(dev, binch14);
@@ -3062,7 +3062,7 @@ static void dm_dynamic_txpower(struct net_device *dev)
priv->bDynamicTxLowPower = false;
} else {
/* high power state check */
- if (priv->undecorated_smoothed_pwdb < txlowpower_threshold && priv->bDynamicTxHighPower == true)
+ if (priv->undecorated_smoothed_pwdb < txlowpower_threshold && priv->bDynamicTxHighPower)
priv->bDynamicTxHighPower = false;
/* low power state check */ |
break;
+ if (viviflag) {
viviflag = false;
+ if (priv->bDcut)
else
+ if (priv->bDcut)
else
#ifdef RTL8190P
#else
+ if (priv->bDcut)
else
+ if (priv->bDcut)
else
} else {
