staging: rtl8192u: ieee80211: rtl819x_TSProc: Replace MSECS with msecs_to_jiffies
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace driver specific macro MSECS with msecs_to_jiffies().
This was found using the following Coccinelle semantic patch:
expression e;
- MSECS(e)
+ msecs_to_jiffies(e)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
index f33c743..36a165e 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
@@ -87,7 +87,8 @@ static void RxPktPendingTimeout(unsigned long data)
if(bPktInBuf && (pRxTs->RxTimeoutIndicateSeq==0xffff))
pRxTs->RxTimeoutIndicateSeq = pRxTs->RxIndicateSeq;
- mod_timer(&pRxTs->RxPktPendingTimer, jiffies + MSECS(ieee->pHTInfo->RxReorderPendingTime));
+ mod_timer(&pRxTs->RxPktPendingTimer,
+ jiffies + msecs_to_jiffies(ieee->pHTInfo->RxReorderPendingTime));
spin_unlock_irqrestore(&(ieee->reorder_spinlock), flags);
//PlatformReleaseSpinLock(Adapter, RT_RX_SPINLOCK);
@@ -212,7 +213,8 @@ static void AdmitTS(struct ieee80211_device *ieee,
del_timer_sync(&pTsCommonInfo->InactTimer);
if(InactTime!=0)
- mod_timer(&pTsCommonInfo->InactTimer, jiffies + MSECS(InactTime));
+ mod_timer(&pTsCommonInfo->InactTimer,
+ jiffies + msecs_to_jiffies(InactTime));
@@ -590,7 +592,8 @@ void TsStartAddBaProcess(struct ieee80211_device *ieee, PTX_TS_RECORD pTxTS)
if(pTxTS->bAddBaReqDelayed)
IEEE80211_DEBUG(IEEE80211_DL_BA, "TsStartAddBaProcess(): Delayed Start ADDBA after 60 sec!!\n");
- mod_timer(&pTxTS->TsAddBaTimer, jiffies + MSECS(TS_ADDBA_DELAY));
+ mod_timer(&pTxTS->TsAddBaTimer,
+ jiffies + msecs_to_jiffies(TS_ADDBA_DELAY));
else
if(InactTime!=0)
else
