Staging: rtl8192u: Do not add new typedefs
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch removes the dig_t and DRxPathSel type definitions in order to
avoid the following warning: "WARNING: Do not add new typedefs".
Done with coccinelle and this script:
@r@ type t; identifier id; @@
typedef struct id
t;
@script:python get_name@
t << r.t;
tdres;
coccinelle.tdres = t.replace("_t", "");
@r_match@ type r.t; identifier r.id;
identifier get_name.tdres; @@
-typedef
struct
-id
+tdres
-t
@r_replace@ type r.t; identifier get_name.tdres; @@
-t
+struct tdres
Signed-off-by: Cristina Opriceana
 drivers/staging/rtl8192u/r8192U_dm.c |  5 +++--
 drivers/staging/rtl8192u/r8192U_dm.h | 12 ++++++------
 2 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 8669162..402abdf 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -36,11 +36,12 @@ static u32 edca_setting_UL[HT_IOT_PEER_MAX] = {
 /*------------------------Define global variable-----------------------------*/
 /* Debug variable ? */
-dig_t	dm_digtable;
+struct dig dm_digtable;
 /* Store current software write register content for MAC PHY. */
 u8		dm_shadow[16][256] = { {0} };
 /* For Dynamic Rx Path Selection by Signal Strength */
-DRxPathSel	DM_RxPathSelTable;
+struct DRxPathSel DM_RxPathSelTable;
diff --git a/drivers/staging/rtl8192u/r8192U_dm.h b/drivers/staging/rtl8192u/r8192U_dm.h
index 3008f91..091fdd1 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.h
+++ b/drivers/staging/rtl8192u/r8192U_dm.h
@@ -67,7 +67,7 @@
 /*------------------------------Define structure----------------------------*/
 /* 2007/10/04 MH Define upper and lower threshold of DIG enable or disable. */
-typedef struct _dynamic_initial_gain_threshold_ {
+struct dig {
 	u8		dig_enable_flag;
 	u8		dig_algorithm;
 	u8		dbg_mode;
@@ -98,7 +98,7 @@ typedef struct _dynamic_initial_gain_threshold_ {
 	bool		initialgain_lowerbound_state;
 	long		rssi_val;
-} dig_t;
 typedef enum tag_dynamic_init_gain_state_definition {
 	DM_STA_DIG_OFF = 0,
@@ -163,7 +163,7 @@ typedef enum tag_dig_cck_cs_ratio_state_definition {
 	DIG_CS_RATIO_HIGHER = 1,
 	DIG_CS_MAX
 } dm_dig_cs_ratio_e;
-typedef struct _Dynamic_Rx_Path_Selection_ {
+struct DRxPathSel {
 	u8		Enable;
 	u8		DbgMode;
 	u8		cck_method;
@@ -177,7 +177,7 @@ typedef struct _Dynamic_Rx_Path_Selection_ {
 	u8		rf_rssi[4];
 	u8		rf_enable_rssi_th[4];
 	long		cck_pwdb_sta[4];
-} DRxPathSel;
 typedef enum tag_CCK_Rx_Path_Method_Definition {
 	CCK_Rx_Version_1 = 0,
@@ -200,9 +200,9 @@ typedef struct tag_Tx_Config_Cmd_Format {
 /*------------------------Export global variable----------------------------*/
-extern dig_t dm_digtable;
+extern struct dig dm_digtable;
 extern u8 dm_shadow[16][256];
-extern DRxPathSel DM_RxPathSelTable;
+extern struct DRxPathSel DM_RxPathSelTable;
BtrLinux
Privacy Overview
