Staging: rtl8192u: Convert use of __constant_ to
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Using functions of the form __constant_ isn't preferred
outside of include/uapi/ as using the function without
__constant_ is identical when the argument is a constant.
So, this patch replaces __constant_htons with htons.
This is done using Coccinelle and semantic patch used for
this is as follows:
@@identifier x;@@
- __constant_htons(x)
+ htons(x)
- __constant_htonl(x)
+ htonl(x)
- __constant_ntohs(x)
+ htons(x)
- __constant_ntohl(x)
+ htonl(x)
Signed-off-by: Vaishali Thakkar
 drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index d2c2fb8..bd74510 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -55,7 +55,7 @@ static inline void ieee80211_monitor_rx(struct ieee80211_device *ieee,
 	skb_pull(skb, ieee80211_get_hdrlen(fc));
 	skb->pkt_type = PACKET_OTHERHOST;
-	skb->protocol = __constant_htons(ETH_P_80211_RAW);
+	skb->protocol = htons(ETH_P_80211_RAW);
 	memset(skb->cb, 0, sizeof(skb->cb));
 	netif_rx(skb);
BtrLinux
Privacy Overview
