Staging: rtl8192u: Bool tests don’t need comparisons
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch removes explicit true/false comparations to bool variables.
Warning found by coccinelle:
"WARNING: Comparison to bool"
Signed-off-by: Cristina Opriceana
 drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c | 5 ++---
 drivers/staging/rtl8192u/r8192U_core.c              | 2 +-
 drivers/staging/rtl8192u/r819xU_firmware.c          | 6 +++---
 drivers/staging/rtl8192u/r819xU_phy.c               | 2 +-
 4 files changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
index 0345f1c..ea92fde 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
@@ -269,7 +269,7 @@ static PTS_COMMON_INFO SearchAdmitTRStream(struct ieee80211_device *ieee,
 	//for(dir = DIR_UP; dir <= DIR_BI_DIR; dir++)
 	for(dir = 0; dir <= DIR_BI_DIR; dir++)
-		if(search_dir[dir] ==false )
+		if (!search_dir[dir])
 			continue;
 		list_for_each_entry(pRet, psearch_list, List){
 	//		IEEE80211_DEBUG(IEEE80211_DL_TS, "ADD:%pM, TID:%d, dir:%d\n", pRet->Addr, pRet->TSpec.f.TSInfo.field.ucTSID, pRet->TSpec.f.TSInfo.field.ucDirection);
@@ -381,8 +381,7 @@ bool GetTs(
 	else
-		if(bAddNewTs == false)
+		if (!bAddNewTs) {
 			IEEE80211_DEBUG(IEEE80211_DL_TS, "add new TS failed(tid:%d)\n", UP);
 			return false;
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index b6cd7ea..c6ff2f0 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -2823,7 +2823,7 @@ static bool rtl8192_adapter_start(struct net_device *dev)
 		dm_initialize_txpower_tracking(dev);
-		if (priv->bDcut == true) {
+		if (priv->bDcut) {
 			u32 i, TempCCk;
 			u32 tmpRegA = rtl8192_QueryBBReg(dev, rOFDM0_XATxIQImbalance, bMaskDWord);
 			for (i = 0; i < TxBBGainTableLength; i++) {
diff --git a/drivers/staging/rtl8192u/r819xU_firmware.c b/drivers/staging/rtl8192u/r819xU_firmware.c
index e208c89..d27b1e2 100644
--- a/drivers/staging/rtl8192u/r819xU_firmware.c
+++ b/drivers/staging/rtl8192u/r819xU_firmware.c
@@ -281,7 +281,7 @@ bool init_firmware(struct net_device *dev)
 		if (rst_opt == OPT_SYSTEM_RESET)
 			release_firmware(fw_entry);
-		if (rt_status != true)
+		if (!rt_status)
 			goto download_firmware_fail;
 		switch (init_step) {
@@ -304,7 +304,7 @@ bool init_firmware(struct net_device *dev)
 			/* Check Put Code OK and Turn On CPU */
 			rt_status = CPUcheck_maincodeok_turnonCPU(dev);
-			if (rt_status != true) {
+			if (!rt_status) {
 				RT_TRACE(COMP_ERR, "CPUcheck_maincodeok_turnonCPU fail!\n");
@@ -318,7 +318,7 @@ bool init_firmware(struct net_device *dev)
 			mdelay(1);
 			rt_status = CPUcheck_firmware_ready(dev);
+			if (!rt_status) {
 				RT_TRACE(COMP_ERR, "CPUcheck_firmware_ready fail(%d)!\n",rt_status);
diff --git a/drivers/staging/rtl8192u/r819xU_phy.c b/drivers/staging/rtl8192u/r819xU_phy.c
index 084e04f..3451ec7 100644
--- a/drivers/staging/rtl8192u/r819xU_phy.c
+++ b/drivers/staging/rtl8192u/r819xU_phy.c
@@ -1099,7 +1099,7 @@ bool rtl8192_SetRFPowerState(struct net_device *dev,
 	if (eRFPowerState == priv->ieee80211->eRFPowerState)
 		return false;
-	if (priv->SetRFPowerStateInProgress == true)
+	if (priv->SetRFPowerStateInProgress)
 		return false;
 	priv->SetRFPowerStateInProgress = true;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
